How to restart siemens washing machine xl 140?
Extraklasse
3 Suggested Answers
  • 274 Answers
SOURCE: can a siemens extraklasse xls 140 run as a cold
yes any machine can
Posted on Jul 05, 2010
  • 6277 Answers
SOURCE: my siemens extraklasse t900 washing
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 21, 2011
Hi, I have a problem with machine siemens extraklasse f1000. Centrifugation is malfunctioning, the drum keeps spining slowly, and I can't extract the clothes...
Open the drum then disconnect the power in the first instance to remove your clothes. Then contact siemens for help.
Oct 28, 2017 | Siemens Washing Machines
What is an F21 error means in Siemens extraklasse WM14E391 washing machine?
its a motor tachometer fault, basically the tacho on the motor (you cant get it as a spare part it comes with the motor) is faulty or the control board is faulty and the machine is unable to detect the speed of the motor, the motor may work but if the board cant detect it moving you will get this fault, fun thing about this kind of fault is theres no easy way to determine whether its the board or the tacho
Feb 07, 2017 | Siemens Washing Machines
F 16 AND F 63
F16 occurs when you try to start machine with door open or faulty door lock, F63 is a fault with control module
Mar 22, 2013 | Siemens WM14S794GB Front Load Washer
My Siemens extraklasse xls140 isnt always doing the final spin and the water doesn't appear to be getting hot during the wash.
I have a siemens ekstraklasse xls 140 and at the stadge it must spin and drain it says drain is blocked. Is there any way i can unblock it myself and where do i find it.
Jan 27, 2011 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
