Question about D-Link DIR-600L Wireless N 150 Home Cloud Router
Why my d link dir 600 has no wifi signal
I have a wireless modem wi tribe,then i bouht a d link dir 600, but the problem is, when i connected it to my wireless modem the signal to my pc is ok but the wifi signal is not working or no light pls. help how to fix it
    Habit-Forming:
    New Friend:
  • 33 Answers
What is colors of lights in your dlink box
skype id : johnwalker800969@gmail.com
Posted on Sep 13, 2016
  • 10 Answers
SOURCE: Problem with the wireless d link DIR- 635
I'd try doing a power cycle. Power off all the equipment. Plug in the Modem untill the online light is solid, then plug in the router, then i'd turn on your laptop.
Ensure that your connecting to the right network. Under the network settings the SSID is your Network name. Make sure it's not a generic name.
If you have a cable provider, you can just bring it to Geek Squad. They'll setup the router and setup all the security features in the store within about 10-15minutes.
Posted on Jun 19, 2008
  • 1341 Answers
SOURCE: Really unstable Dlink dir-655 router
I would suggest you try to change the channel to a higher one and this solves this problem most of the times...You need to go to your router configuration to do that usually by opening a browser and type 192.168 ... and log in into your router...Hope this helps.
Posted on Jun 25, 2009
SOURCE: dlink DIR-615 wireless connection problem
hi. with regards to your concern. there is a possibility that the wireless network adapter driver is corrupted.. try uninstalling the driver for your wireless adapter and reinstall again. once setup is done, view the available wireless connection and connect.. it will ask u the password if there is..then it will connect. if this solution dont work.. try to check your wireless settings, maybe there is a problem on the settings..
Posted on Aug 08, 2009
marked
  • 6487 Answers
SOURCE: No WIFI on D-link Router
If the wifi light is off its a sign that there's something wrong with it, so the first thing you can do here is to reset the router, To reset it press and hold the reset button of the router for 30 seconds and then power off the router for 10 seconds....
Posted on Aug 09, 2009
  • 3 Answers
SOURCE: Using a HN9000 modem and D-Link dir 615 together
change your routers IP address to IP address. 192.168.1.1.
Posted on Sep 16, 2009
At first my d link dir 600 was working when i connect it to my wi tribe modem, after a few days the signal on my d links was lost but my wi tribe connection is still working when itry to connect aga
You will need to configure your router setting according to your ISP.
second, Contact your ISP if again and keep in mind that firmware uptodate. if problem is still remain use Linksys Home Support http://support.linksys.com/en-apac/support/linksys?icid=global-header-support-link and if use some other resources that will handle your router http://www.techsupportrouter.com/support-for-linksys-router.html
May 07, 2014 | D-Link DIR-600 Router
Low wireless signal
Here is 10 tips to boost your router signal...
http://lifehacker.com/5931743/top-10-ways-to-boost-your-home-wi+fi
Feb 26, 2013 | D-Link DIR-600 Router
I purchased a D-Link Wireless N 150 Router, Dir 600L. I am unable to setup the same. Do I need a Modem also to setup this router or I can setup without a modem?
You can setup a wireless network without a modem. It will allow you to share printers, files ect. The modem is required for an internet connection only. The modem basically translates the Ethernet traffic in to a signal that can be carried over your respective service, DSL over a POTS line or broadband over a coax cable. The word modem stands for MOdularDEModular note the word MODEM in there.
Dec 24, 2012 | D-Link DIR-600 Router
I cannot connect to the internet using my dlink dir-600 router
  • Check the cable modem status light. If this cable is loose at either connection point, you must tighten it before hoping to attain your Wi-Fi signal again.
  • Verify that the Internet light on your Netgear wireless router is solid or blinking green.
  • Press the "Reset" button that is located on the front face, top or rear of the broadband modem. This button allows your modem to re-initialize, and this may solve your problem once it boots back up.
Find here-setting up d-link router
Aug 30, 2012 | D-Link Computers & Internet
D-Link DIR 600 connection problems
If this is the case, there is no problem with the router. the problem is with the modem.MAke sure that the cable from the modem goes into the WAN(Internet) port of the router.And also, what kind of internet are you using? is your router set up properly to work with your provider?
Is there any problems when you connect your pc to the modem directly with the cable, or does the problem occur only in the wifi connection?
Feb 18, 2012 | D-Link DIR-600 Router
I have a full signal on my pc via DIR-412 but no internet connection
Is this the first time you set your router? Make sure that the cable from your modem to your router is connected properly. You can also try connecting the modem directly into your PC just to make sure your modem is connected to the internet. If it is working without the router, reset your router then connect the modem again to your router.
Sep 15, 2011 | D-Link Network Router DIR-412 Mobile 3GB...
How to connect my Linksys router with my wi tribe modem?? my laptop pick up the wireless signal and can connect,,it says "connected" but when you open a page it says either "invalid server...
The Linksys Wireless router is fine, but your latop is not configured for DHCP (Dynamic Host Configuration Protocol). The computer is connected to the router at layer 2, whereas HTTP (Hypertext Transfer Protocol), sits
atop the TCP/IP (Transmission Control Protocol/Internet Protocol) layer, and seems to be trying to
query the ISP's (Internet Service Provider) network for a nameserver (via DNS (Dynamic Name Service) protocol) that doesn't exist on the ISP's network. Configuring the laptop for DHCP and specifying no nameserver will fix this (the ISP's network will dynamically assign a DNS).
Its also possible (though a remote possibility) that your Linksys wifi router may be configured to disallow TCP/IP virtual circuits to/from your computer's IP address - but this is a really advanced
capability of your Linksys wifi router - few know this capability even exists.
Connecting multiple wifi devices to the Linksys router should be no problem, just configure them all to interact with the router using DHCP.
Jul 04, 2011 | Linksys WRH54G Wireless Router
I want to use my wifi router D-link dir-600 for internet wifi. After I set everything according to manual guide, I can detect the wifi signal, eventhough I have enable the wifi in the router.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router. For Internet access you need to connect your DSL or cable modem to the WAN/Internet port on the D-Link.
Apr 08, 2011 | D-Link DIR-600 Router
How to connect my tp link wireless router with my wi tribe modem?? my laptop pick up the wireless signal and can connect,,it says "connected" but when you open a page it says either...
if you were using Fariya before wi tribe or any other dialer to connect internet, you have to first remove that one.
To remove the dialer or connection you have to go to run, type ncpa.cpl there and then in new opened window remove the old connection (e.g Fariya)
Dec 04, 2010 | Linksys WRH54G Wireless Router
D-Link DIR-600L Wireless N 150 Home Cloud Router Logo
79 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
