Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Humming during cd playing only.
My Sony Bravia KDL-40L130 has a large static hum whenever I paly a cd in video 1. It does not happen when watching cable/tv.
  • 61 Answers
Re: Humming during cd playing only.
Try turning down the volume on whatever you are playing the CD on, this sounds like an overdriven amp...too much signal for the TV to handle.
Posted on Feb 17, 2008
0 characters
3 Points
My sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Nov 08, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have a sony Bravia 46" When I first turn the TV on it has vertical lines on the left side of the TV after babout 5 min they go away?
its called burn in and yes it can go away over time. Be sure to not leave a static image on the screen (like a paused video) and leave it for an extended period of time.
playing video with high brightness and fast moving action can further help the problem go away.
Oct 23, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-46Z4500 Captions
Try pressing the 'Display' button on top left of TV remote.
Jan 31, 2009 | Sony BRAVIA KDL-46W3000 Television
Sound problem
Go into your TV settings and change the Automatic Volume Control Sound Mode. It's probably at Dynamic and the TV is trying to adjust the volume. The popping sound may be caused by static electricity building up on the circuits of your TV or cable.
Does this also happen when you are watching a video/DVD?
Nov 27, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Humming sounds
You have a ground loop in the system. Unhook everything and then slowly add one cable back at a time. You will find the problem that way. Good luck.
Mar 22, 2008 | Flat Panel Televisions
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
98 people viewed this question
Top Sony Flat Panel Televisions Experts
Brian Sullivan
Brian Sullivan
Paul Bade
Are you a Sony Flat Panel Television Expert? Answer questions, earn points and help others
