Question about Garden
MOWER will not do anything; have checked "kill" switches. key will not operate starter, but starter can be jumped. jumped starter will not "start" engine with key on. any ideas? ron
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 82 Answers
Check headlamps (with key on.) If there's no power, the switch could be bad, or a fusible link may have self-sacrificed. If lights have power, I'd test voltage from the switch to the starter.
Posted on May 07, 2014
Testimonial: "good idea and thanks. ron"
  • Ronald Baker May 08, 2014
    the fuse was blown. i failed to check as the mower was just sitting at idle. great help and thanks again. ron
Riding mower won't turn over
Key switch may not be operating the solenoid for the starter. Getting off the seat engages a safety switch that kills the engine go you won't have to go chasing it if it were to slip into gear while you're standing next to it.
Sep 01, 2016 | John Deere D110 42 in. 19.5 HP...
While mulching leaves mower suddenly stopped. I turn the key and nothing. Any ideas?
A riding mower has an interlock that prevents starting if no one is in the seat or if it is in gear or blade is engaged. Check these interlock switches. One of them may be shorted. Sometimes, the way they work is to kill the engine by shorting out the ignition. Other systems may prevent the starter from operating.
Nov 30, 2015 | Garden
All safety switches are engaged still cannot start with key. Able to jump start from mower battery to starter and shut off with key. Help ?
Sounds like it could be either the starter solenoid or the wire from the key to the starter solenoid. Try to energize the S pole on the starter solenoid and see if it cranks and starts. If it starts, the solenoid is not the problem so it could be the wire that goes to the start position on the key switch. If it doesn't start, it's the solenoid.
Jun 11, 2014 | Husqvarna Zero Turn Mower Z5426
Toro lx 500 riding lawn mower
check the connections from the battery to starter-check the fuses -and relays than start with the safety switches --seat-clutch-and cutter deck the safety switches are a kill switch
May 24, 2013 | Garden
Mower won't start
If you have jumper cables or a jump box you can put the positive lead on the hot wire running to the starter and the ground to any clean (unpainted) surface on the mower and the starter will get power. Place your key in the on position and the unit should start if it is getting fuel.
Apr 06, 2013 | Husqvarna Yth 150 Riding Mower Illustrated...
A safety feature appears to be stopping my mower from turning over
You will have at least 2 safety switches. One is the clutch/brake pedal activitated and the other is the seat switch. It sounds like the clutch/brake pedal switch is not allowing the starter to engage the flywheel and start the mower. Check for the switch under the footrest or near the back of the mower. Should be easy to find. Check it with an ohm meter and verify it is working. you could use a wire with 2 aligator clips to jump the switch but dont make this a permanent solution. Replace the switch if it is bad. One thing to consider is the ignition switch. Since you can jump the solenoid and the engine turns but wont run, you may have no power to the ignition/coil to fire a spark to the sparkplug. You need to turn the key to RUN and then jump the solenoid to confirm this. I think it will be one of those as the seat switch only kills the motor if the deck is engaged and the seat raises up. Let us know.
Apr 07, 2012 | Husqvarna Garden
Try to start riding mower. it just clicks. I've got 12V to the starter. I thought starter was done so replaced it and no luck> still just clicks. I'd appreciate some help. OHVB 15hp...
hi jerry396
you say you replaced the starter - do you mean starter solenoid or starter motor ?
if you run battery jump lead from bat + to s/motor terminal and connect neg jumper lead to engine earth and other end of neg jump lead to negative bat post with key on - will the engine crank over easily and start - if so your starter motor is good if not problem is elsewhere.
check your battery - it could be a faulty battery , and earths, also 12 must be present @ solenoid from the key switch in start mode and check that the solenoid has a good ground
check the starter solenoid as well - it could have burned contacts adding very high resistance to starter cable , also check your starter cable - for resistance - it should have no more than 0.3 or 0.4 ohms
make sure all interlocks are operating - ie clutch brake, cutter attachment , nuetral switch , seat switch ,
cheers hope it helps
pauly46
May 20, 2011 | Garden
Starter, starter switch and kill switch not working
when he jumped it with the charger he probably fan too much curent through the system witch made a relay stick so when you hit the start button it dosnt shut off the kill switch probably went bad because of it also trace the wires from the start button and find the relay that they go to and check it with a multimeeter how they work is it uses a little amount of curent to controle a big amount
Jun 04, 2009 | Yumbo Dakar 200 Motorcycles
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
