Question about Watches
Puma 911012001 change from military time - Watches
To be able to change to analog time from military time
Go to your events/calendar. Click the little settings symbol there. Then uncheck 24-hour time and save. How do I change my clock settings from military time to regular time.
just found this on the internet dont no if this will help you out if not let me no.
Nov 19, 2016 | Able Watches
I have a Puma Led Watch and I don't know how to change the time that displays. Can you, please, help me?
click on the top right button to view time, then click bottom right button and hold it as the time is still appears. then it will start blinking. if you press the bottom right button you will be able to swap the command you want to change (H,Min,Y,D,M) and if you press the top right button you can increase (only) the number you like. Left buttons i dont know what they do :P
Jan 18, 2011 | Puma Watches
Hello, ive got a spin puma watch, but i lost the manual and cant change the time and the day, how can i do that?? thans
I have examined their web site but they do not list manuals.
Their customer service site sounds as if they would be only too pleased to help you on this.
Try going to http://www.shop.puma.com/Contact-Us/CONTACT,en_US,pg.html and e-mailing them about your problem. They should be able to send you a copy.
Dec 27, 2010 | Puma Watches
I cannot figure out how to set the time on my Puma watch.
mcdevito75 here, You can try www.puma.com They have an overseas number but also the option to find a Puma retailer in your area.
Jul 13, 2010 | Puma Active Collection Fluctuation...
PUMA FLUX watch - reset time
Press and hold the button on the upper left until it displays "HOLD" then wait 'til the light goes out, you'll see the hour-digit blinking, set the hour you want, then for the minutes, press the lower left button. Press and hold the upper left button to set the desired time.
May 02, 2010 | Puma Digital Alarm Chromograph...
How do I change time on this watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all PUMA watch manuals.Rate me, please
Mar 15, 2010 | Puma Flow Analog W ( Pink/White) Watch for...
How do i get my athletic watch off of military time? It's a water resistant watch up to 165 ft. model # aw60447w
military time:
1. When setting the time on your watch, IF you watch can change to Military time(and most can)
2. when you are adjusting the hours go through a full 24 hour cycle. You'll notice that the 2nd time through it is on military time.. 3rd time through back to 12 hour day AM/PM cycle .. 4th time back to Military.
So you can do this as many times as it takes to get to the right time ..
In 24 hour time you will see an "H" displayed where you normally see and "A" for AM and "P" for pm.
Sep 23, 2009 | Watches
Puma Watch PU900111004 (orange heart rate watch)
I want to change the time but was not as
I could help?
Jul 20, 2008 | Puma Watches
Set watch
I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
Feb 21, 2008 | Watches
Watches Logo
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
