Bioscan ar 2000
It happened error message while do gain calibration for linerity. Error message"failed to find correct number of peaks" and High voltage is 4958.5V in results and high voltage is -548.9V in parameter
  • jongyoul jeong
    jongyoul jeong May 08, 2014
    First, output high voltage around 1850V on detector was not coming out. So, We replaced PMT tube(4479-106). And then measured high voltage 1850V on detector.
  • jongyoul jeong
    But it happend above. 4479-106 is brandenburg made in UK
SOURCE: Calibrating Scanner
I had the same problem but have solved it. What i think you might be doing wrong, is that you have the scan material the wrong way round. The womens face should be on the right side of the scanner with the colour input target centered against the ruler. Once i did this it worked first time
Posted on Jun 12, 2008
SOURCE: realtek high definition sound ac97
Intel 82801DB ICH4 - AC'97 Audio
Posted on Nov 06, 2008
  • 10 Answers
SOURCE: I am trying to calibrate the touch screen and it
Your touchscreen is defective. Please contact Panasonic official service center http://heartlandsi.com to arrange a repair. It's covered under warranty.
Posted on Sep 29, 2009
rulds2008
  • 3866 Answers
SOURCE: Ballast error status - lamp voltage too high
You need to replace the balast as the voltages are buringing the bulb out and this is caused by a balast that is bad. The baslast is what the bulb connects to this has a sensor on it that relays voltages and heat back to the main control unit.
Posted on Oct 23, 2009
SOURCE: Canon LBP-5000 Printer and Calibration
I solved this problem.
You need to bring your printer to some service, and perform cleanig of the printer's optic instruments, which are most probably coverd with dirt, and printer just can't recognize catridges, and can't give you the best print quality.
Just take it to the people who refill toners, or to some official service, they'll know what to do. I had the same problem as you, and today I can't recognize how better print quality is, and more importan, printer is not asking calibration any more.
Posted on Jun 02, 2010
E2 error solution
Precor Error E2, Lift Error Probable Cause Error would occur if the incline is unable to move or if the incline position potentiometer is not functioning. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Troubleshoot as errors 40 and 42.
Precor Error 40, No Lift Motion Detected Probable Cause 1. Blown lift fuse in lower PCA.
2. Lift motor is physically jammed and not able to move.
3. Bad lower PCA.
4. Bad lift capacitor.
5. Bad lift motor winding.
6. Bad interconnect cable between upper and lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Check the lift fuse from the lower PCA. Using an ohmmeter, the fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the fuse is open, refer to steps 3 and 4 before continuing.
  2. Disconnect the lift motor from the ramp (elliptical) or lift platform (treadmill). If the lift nut or lift tube is jammed against the motor housing, turn the lift tube or lift nut away from the motor housing. If the lift was jammed, refer to step 3 before continuing. Calibrate the lift motor per the proper procedure for the unit being serviced and reattach the lift motor to the ramp (elliptical) or lift platform (treadmill). NOTICE: You must find and repair the cause for the jammed lift. Only re-calibrating the lift motor will not solve the problem.
  3. One of two modes can cause the lower PCA to fail. The lift switch could fail in an operated condition. If this happens the lift will move (either up or down) as soon as the unit powers up. The usual result is that the lift will be physically jammed as explained above, and probably also being cause for the lift fuse to blow. The lift switch could also fail in an open condition. If this happened, the lift would not operate in one direction. If either of these conditions occur the lower PCA needs replaced.
  4. Most units have the lift capacitor mounted inside the lift motor, and others use external lift capacitors. This information applies to units with the external lift capacitors. If the lift capacitor is shorted the lift fuse blows. Check the capacitor for a short using an ohm meter. Disconnect the capacitor from the lift motor and test. A good capacitor reads in the millions of ohms. Replace the capacitor if the reading is significantly low. Capacitor can also fail in the open condition which would result with the lift motor trying to run but not having normal power. Test the capacitor by measuring AC voltage across it. A good capacitor will read AC peak voltage while an open capacitor reads AC RMS voltage.
  5. When a lift motor winding is bad the lift will not operate in one or both directions depending upon the exact fault in the motor. Check the lift motor winding with an ohm meter. AC lift motors have a split winding (3 wires) and DC lift motors will have a single winding. Both windings must be checked on an AC lift motor. Normal winding readings could vary anywhere between 1 and 60 ohms, depending on the lift motor being tested. See the proper service manual for the motor being tested.
  6. Test unit with a known good interconnect cable. Replace the interconnect cable if necessary.
  7. Test unit with a known good upper PCA. Replace the lower PCA if necessary.
Precor Error Code 42 Error Code: 42 Manufacturer: Precor
Model: All Models
Error Description: Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40. Possible Reason:
  1. Bad or intermittent connection in the lift motor controller.
  2. The lift motor requires calibration.
  3. The lift motor potentiometer is bad.
  4. The lower PCA to upper PCA cable is bad.
  5. The lower PCA is bad.
  6. The upper PCA is bad.
Recommended Action:
  1. Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
  2. Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
  3. If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
  4. Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
  5. Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
  6. Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Precor Error Code E2
Precor Error Code 40
Lift Position Value Out of Range Precor Error 42
Apr 22, 2015 | Exercise & Fitness
Err 2 what does it mean
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Model: All Models
Recommended Action:
Dec 14, 2013 | Precor Exercise & Fitness
Precor treadmill has Error 42
Model: All Models
Recommended Action:
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Apr 04, 2012 | Precor 9.31 Treadmill
Precor treadmill error message 41
Precor Error 41, Lift has not Responded in Acceptable Time Probable Cause Error 41 was present in early software versions and is no longer being used.
Corrective Action If you encounter a unit that has software with an error 41, diagnose the same way you would if getting an error 40.
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Jan 11, 2011 | Precor 9.21 Treadmill
Hello from Spain I have a problem with a Precor 546 marks several errors. error 40, error 42 and error 45. Please let me help you find a solution. thanks
3. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
Model: All Models
Recommended Action:
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Sep 25, 2010 | Precor EFX 546i Elliptical Version 4
Code message
improper cartridge (destination error,life cycle error )
identification error
model error
type error
destination error
data abnormality
misc error
Nov 19, 2009 | Sharp AR-C260M All-In-One Printer
I keep getting a service required message, why is that? How do I correct the problem? Susan
I have the same problem. I chatted with Bel and here's the transcript, FYI:
chatinfo.gifWelcometoBeltronics.! An online representative will be with you shortly. Youarenumber 1 in the queue. Your wait time will be approximately 1 and9seconds. Thank you for waiting.
chatinfo.gifYou are now chatting with 'Brian'
Brian: Welcome to Beltronics Live Chat. How may I assist you today?
you: Hi Brian, I
you: own a Bel pro rx65
you: and it gave an error
you: that said
you: selfcal4
you: or something like that
you: then it said service
you: required
you: what does this mean?
Brian: Therearea number of things that may cause this ERROR message. Please besurethat you are getting consistent voltage (does the lighter socketstay ONall the time? Does it do the same thing in other vehicles?). If thedisplay reads "Service Required" not caused by the above, itmeans ithas failed it's self-calibration and requires service. Pleasecall ourCustomer Service Department at 800-341-2288 and they will giveyou arepair authorization number and instructions on how to return itto usso we can take a look at your detector.
you: Oh i see. what's the cost for repair?
Brian: That is a $59.95 repair fee. To set that up, please call Customer Service at 800-964-3138, option 2.
you: and what cause calibration to fail?
Brian: If the reasons listed above don't sound like what's happening, then it would be up to a repair tech to figure out why.
you: I had left it in the car in hot weather. would this be a cause?
Brian: It's possible, over a long time in the heat to develop.
you: I can call either number correct?
Brian: Correct.
you: ok thanks
Icalled the number and they were helpful, told me to use a packingservice like UPS and such. Insure it. And it would take about 5-7 daysfor them to work on it, another 3-4 days of shipping time.
Consideringthe reviews on the rx65 and the prices for detectors out there, andconsidering that they will also apply any software updates (bought minein '06) the $60 repair fee is worth it for me.
Mar 22, 2009 | Pro RX65 Radar Detector
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
AR-151
Messing with the optics involves timing and calibration programs to happen by a service technician. If it isn't place correctly. It will cause copy quality problems to happen.
Sep 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
AR-207 on a network
Driver - Download correct driver for your model and install after deleting old.
http://www.driverskit.com/Printer/Sharp_Electronics/page2.html
Nov 08, 2007 | Sharp AR-207 Copier
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
