Question about Boating
Timing adjustment on 1998 sea horse 55 hp - Boating
2 Suggested Answers
AndrexT
  • 14804 Answers
SOURCE: trim motor will not work on my 1998 sea ray 100 horse power boat
CHECK YOU HAVE POWER TO THE MOTOR USING A TEST METER OR A BULB.
If you have power to it remove it, strip it down and see if you can see what is wrong, or take the unit to a marine engineer.
Posted on Jun 18, 2017
Trim motor will not work on my 1998 sea ray 100 horse power boat
Jun 17, 2017 | Boating
I have a Johnson super sea horse 33 hp electric serial number j2624883 I have no spark due to the harness being cut by last owner is there a way to wire it to get it running
carefully re splice wires together as they should be color coded and gauged differently, use a solder iron or gun and wire shrink wrap(sleeves) over joints.
Auto Install How to solder and heat shrink wires together
Jan 21, 2016 | Boating
205cc =what horse power
1 hp= amount of work perfomed to raise 33,000 lbs 1 ft over 1 minute.P.L.A.N is mean effecftive Pressure x the Lenght of stoke x the mean effective Area of the piston x the Number of Strokes per minute= horse power..so about 9 horse power 10 at sea level at 15C and 2800 rpm
Aug 21, 2014 | Garden
Adjustment for belt for 8 horse power horse. Really need to find a manual. Where can I locate one?
http://www.hammerwall.com/Manuals/Troy-Bilt/Description/21A682J766/Troy-Bilt%208%20HP%20Rear%20Tine%20Tiller%208%20HP%20680%20Series%20Briggs%20and%20Stratton%20Engine%20Manual/275092/
May 29, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
How much horse power does A 1998 kawasaki kx 250 have
There is reputed and there is actual horsepower!
A reputed 52.5 Hp for the 1990 is not right.
A reputed 57.5 Hp for the 2007 maybe right...at the crank.
You lose 8%-10% at the wheel, 5% more with an O-ring chain.
Standard KX250 would be around 42-45 Hp in peak condition. Intake mods, jets, expansion chamber and some porting changes may give you more but it's give and take...you will lose bottom or mid-range and tractibility will go out the window with a very peaky motor. Computer search KX250 forums and canvas the responses and also look for generic KX250 link's.
Cheers.
May 17, 2010 | Motorcycles
Chamberline 1/2 horse truble shoot
check the infared sensors make sure those are working right. Yo may have to adjust the tension for bring down the door.usually a screw on the motor to adjust the senisitivity.
Oct 09, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
HP increase at elevation using a Dyno Jet Dyno?
same dyno? same operator? theres something wrong. the lower altitude the better, as far as I know. But someone thats smarter than me and has high altitude /dyno experience would be better to answer the question.
Oct 01, 2009 | 1983 Mazda RX-7
Wanted to know horse power 1100 yamaha 2006 v star silverado
Engine Air-cooled, SOHC, 4-valve, 75°, V-twin
Displacement 1,063cc
Bore and Stroke 95 x 75mm
Compression Ratio 8.3:1
Maximum Torque 8.7kg-m (63 ft-lb)@ 2,500 rpm
Fuel Delivery Mikuni BSR37 x 2
Ignition Digital TCI
Transmission 5-speed
Final Drive Shaft
Stock: 55-58 hp.(Yamaha claims 50-52) rear wheel
Exhaus Mod, mid cams & ignition kit: 72-74 hp. rear wheel
hope this helps.
Regards
Voodoo
May 07, 2009 | 2006 Yamaha V Star Classic
Lights wont work on my escort van
yes its a europeon model ,and its a right work horse ,sounds like its the switch on the steering coloumn
Jan 07, 2009 | 1998 Ford Escort
Boating Logo
79 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
