Question about LG WM Washing Machines
WF-T7030TP washes, drains but drum does not spin. I think it may be the 5307d solenoid(?) and if so, where do I get one in Australia?
It seems to have run a complete cycle but laundry still wet although there is no water in the drum. I removed all laundry and selected "spin" only cycle. The "agitator" inside the drum spins but the actual rum does not spn. I turned the macine on it' s side and repeated the spin cycle. The motor spins but it seems there is a linkage that engages the drum, via the solenoid , that is not kicking in. I don't have a service manual so this is all just based on observation.
    Habit-Forming:
  • 88 Answers
Unplug take the top of an check for broken belt from motor to drum
Posted on May 09, 2014
SOURCE: Will fill with water but during rinse and spins it won't drain.
I fixed it on my own. By taking off the suction hose and spinning the fan inside it apparently dislodged something and is working now. Hopefully the problem won't come back, I was unable to find the foreign object.
Posted on Oct 23, 2006
  • 351 Answers
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Posted on Mar 08, 2008
SOURCE: Roper washer leaves clothes wet after spin cycle.
Thanks, Master Tech; I was having the same problem as Jason. When I put the pen in place, I realized that the motor was running, but the tub wasn't spinning (which I thought it was because of the sound of the motor). So, I put my hand in and gave it a push/spin and it started turning on its own after I did that.. So, I'm going to let it run and see what happens when the cycle is done. At least its a start in the right direction!
Posted on Aug 04, 2008
  • 64 Answers
SOURCE: Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Posted on Sep 21, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
My top loader lg WF 8071TTP turbo drum does not drain and spin
Drain pump may be defective or something is obstructing it.
Nov 01, 2017 | LG Washing Machines
My LG Turbodrum WF-T7030Tp will not spin.
The LG's typically have a "gearbox" that cannot be fixed if it breaks. You'll have to check with an official dealer. I had a similar problem and in the end it turned out the gearbox would cost more than the whole machine (distribution network fail??).
How old it your machine?
Dec 06, 2014 | LG Washing Machines
REQUIRES MANUAL FOR LG FUZZY LOGIC TOPLOAD WASHING MACHINE MODEL NO WF-T7030TP
The service manual is hidden inside the unit or inside the console.
Oct 22, 2013 | Washing Machines
Hi there ! I have a LG Top loader WF-T7030TP that wash the clothes but do not want to rinse,spin and drain the water.
you have blockage in your drain in the machine-possibly something stuck in the drain pump like a sock or a paper clip-tear it down-have a couple of old towels handy for the mess-cheers Denny
Oct 21, 2013 | LG WM Washing Machines
Hi-i have an lg wasshing machine 5.5kg wf-t552c.wont spin outside drum-lower plastic disc in drum spins only-drains water ok.
Now you meant that the agitator shaft works but the drum does not work. So the fault seems associated with the motor drive and could be a belt failure or a drive failure.
In this case it is important that an observsation into the fault from the motor drive is important to confirm the cause as it seems mechanically related.- since all other functions works according to the cycle.
Oct 06, 2011 | Washing Machines
Wf-t7030tp - Pump does not work!
possibly a problem with the fill switch
Aug 22, 2009 | LG Washing Machines
Washing Machines Logo
149 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
