Question about KitchenAid KHWS01PMT Front Load Washer
KHWS01PWH Front Load Washer stops between cycle and will not drain out water.
  • 331 Answers
Can you hear the drain pump turn on. it maybe plugged. or failed. try here www.techray.com click on the guru guy and select your model. also there is a repair manual that can assist you in repairing the pump.
Posted on Jun 22, 2009
LG WM2277H Front Load Washer drain pump never stops
Could be the water pressure switch is faulty and/or the electronics control circuitry.
Suggest you called a qualified Technician to fix it. It will be worth it for many reasons.
Poppa
http://www.cdbaby.com/cd/poppamadison
Mar 23, 2012 | LG WM2277H Front Load Washer
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Spin cycle does not drain water. The washer just stops when it gets to the spin cycle. The washer is a 70 series heavy duty.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
My washer stops half way through the cycle and blinks????Frigidaire affinity front load washer for some reason just stop halfway through the cycle sometimes.
Take note if the drain pump is operating. If it stops halfway, it must be stopping for a problem that has arisn, Normally, the water is not being pumped out.
Jun 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Kitchen aid washing machine, stopped during cycle wont drain...
if this is a top load unit your lid switch has failed , easy and cheap fix.
get your model number under the lid of the unit and go to sears parts for easy ordering. let me know if I can help more.
Phil
Jun 11, 2009 | KitchenAid KHWS01PWH Global Horizontal...
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Timer Stalling
I would check the water hoses for twisting, make sure the water faucets are turned on all the way, and check the filters at the washer end of the hoses to make sure they are clean. I would also check the drain system to make sure it is clean and the machine is draining well.
Jul 28, 2008 | Frigidaire ATF6000ES Front Load Washer
GE Front Load washer problem
replace the water inlet valve it is seeping water through the valve even though the cycle has finished
Apr 28, 2008 | GE WSXH208A Front Load Washer
KitchenAid KHWS01PMT Front Load Washer Logo
148 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Eric Taylor
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
