Question about Toshiba 46LX177 46 Regza Cinema Series Lcd Tv Widescreen 1080p f
What causes popping sound on tv when stop and start DVD
    Master:
  • Toshiba Master
  • 688 Answers
Volume levels may be set too high
Posted on May 08, 2014
Can dust cause Sony Trinitron 34" tv to go black and make popping sounds?
Dust rarely affects this kind of set---this model had high voltage problems---and if popping I would unplug it.
To be honest this set weighs a ton and is expensive to fix, average repair can be well over 200 dollars.
A lot of them now are being retired and replaced with LCD sets etc.
Dec 23, 2012 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Magnavox tv makes popping sound then lose sound. What cause this
Look first to see if same issue when playing a DVD etc connected to a rear audio/video input.
It may be the audio circuit in the set---got a model number?
May 29, 2012 | Magnavox Televison & Video
Panasonic home theatre keeps making a popping
try cleaning all your connections for your speakers with isopropyl alcohol and a q-tip, if no luck it could be an internal problem
Jan 09, 2010 | Panasonic Home Theater System System
Dvd polaroid tv/dvd combo tda-o3211c dvd stop
Not worth repairing,just get a seperate DVD player hook to the tv.It very cheap these day.
Dec 05, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
THE dvd WON'T COME OUT OF THE dvd PLAYER AND THE
tere should be a little pin hole somewhere on or near the dvd player. take a paper clip straighten it out and put it in the hole you will have to push hard until the dvd holder pops out a little then pull it out until it stops. remove the dvd and push it back in then try to open the slot using the open button. it it doesn't work then you will need to take it in for repairs or replace the tv. though it would probably be cheaper to replace the tv.
hope this helped
please rate well.
Mar 06, 2009 | Emerson EWL20D6 Television
Sony Bravia XBR-2 32-inch LCD with popping noise problem
Unfortunately, we have the same problem. We hear popping and our sound goes lower. It is not the cable box for us, it's definitely the TV; however, it happens, on our set, after its been on for a few minutes and then goes away after half an hour or so -- however, this evening its been happening for the past hour and the TV has been on for the evening.
Jun 10, 2008 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Audio issue with Sony Bravia tv
Each time our TV starts the snapping sound we reboot the cable box. Problem solved.
Oct 09, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Has anyone heard of something like this where the cable box/service is causing popping sounds? yes & it is common problem. And is this something I should be concerned about causing damage to the TV's speakers? not at all. The Sony tech-support representative (over the phone) diagnosed it further to a problem not with the TV but with the cable box/service because there were no popping sounds when I played a DVD on my Playstation 2 that is attached to the TV. they are right that your problem is not due to tv. it is due to cable box/service? yes but not defective it reqires to change the way you have connected tv to cable.please call tech to get it connected in such a way so that you do not get popping sound when you you put off cable box.
Sep 23, 2007 | Sony FD Trinitron KD-36XS955 36" TV
Random codes keep poping up when it does work!
Like a vcr, t.v. signal-IN connected through the 'antenna'input, the t.v. signal should pass through the dvd recorder and u should see it even if dvd machine is off. How is dvd, Tivo, t.v. connected? Signal connected to [video input1],[s-video input]BEFORE OR AFTER tivo ? I assume that the t.v. is the last in line??!! I am sorry, my book does not have code explaned
Mar 19, 2007 | iLO DVD Recorder DVDR05
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Toshiba 46LX177 46 Regza Cinema Series Lcd Tv Widescreen 1080p f Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
