Question about Electrical Supplies
TECH MANUAL FOR MATSUSHITA 2P19C3R126A AIR CONDITION COMPRESSOR
I need the cooling capacity of a matsushita cnr05-980270 compressor. can anyone please assist?
I would need more information to properly answer your question.
What are you removing this compressor from?
The cooling capacity can vary greatly depending on the Evaporator size, the Condenser size and the fan speed that is moving the air. Also there are some other figures needed.
But if you could give me the application that you are using the compressor in I might be able to better answer your question!
Oct 11, 2013 | Matsushita DD73C14GAU6 1/4 HP R134...
Whilpool relay switch electrical diagram
Here is how most are laid out.
Have questions please let me know, Thanks Sea Breeze
Nov 20, 2012 | Matsushita DD73C14GAU6 1/4 HP R134...
I need the capacitor size for a Matsushita compressor model #2P19C3R126A Thanks
It just so happens that I am about to replace the compressor,on a marine A/C unit that uses the Matsushita 2p19c3r126a compressor. I believe it uses a 30 mfd capacitor.
Jun 10, 2011 | Heating & Cooling
I'd lke know, the HP of this compressor MATSUSHITA DB91C14RAW5 thanx
According to the information you have given it is a one quarter horsepower compressor
designed for R134 refrigerant. It runs on 115 volts.
Apr 03, 2011 | Matsushita DD73C14GAU6 1/4 HP R134...
Need a replacement compressor < 8 " high for older refrigerator
How can you have a R134a Compressor that is 32 years old. That gas was not even available then. What you are asking is impossible, unless you are asking can you change from possibly R12 to R143a. The answer is yes but it would probably be too costly. you see R12 ran with mineral oil whereas R134a runs with Polyolester oil. the system would have to be completely flushed out of old oil, and the expansion device ( capilliary tube ), would have to be changed and cut to the correct length to appropriate the correct displacement of gas.
Apr 17, 2010 | Matsushita DD73C14GAU6 1/4 HP R134...
There is a buzzing noise coming from the air con unit
if everything is running may just be contactor,if compressor is running not fan turn it off call service tech out(Fan motor bad)if fan is running but no compressor turn it off call service
Jan 06, 2010 | Mitsubishi Heating & Cooling
Frigidaire r134a compressor.how can i know the horse power
It depends the model number, 452 BTU are 1/6 HP, R134a 776 BTU are 1/5 HP.
Dec 20, 2009 | Matsushita DD73C14GAU6 1/4 HP R134...
HP OF R134-ADMIRAL REF
it will be located on the compressor plate of the rateing of hourse power and amperage with the amount of freon needed to fill it.
Jun 25, 2009 | Matsushita DD73C14GAU6 1/4 HP R134...
Electrical Supplies Logo
108 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
