Question about Panasonic VIERA TH-42PX60U 42 in. Plasma HDTV
How easy to repair the power supply - Panasonic VIERA TH-42PX60U 42 in. Plasma HDTV
    Top Expert:
  • Panasonic Master
  • 74,106 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on May 07, 2014
My 16 channel Yamaha mixer board will not power on as if power switch is messed up I'm wondering if there is an easy fix
It depends. If if has an external power supply, you can try a different supply of the same rating. Beyond that, it may be a blown fuse, which may be internal on the power supply board, or as you say perhaps a broken power switch. Whether it's easy or not will depend on your diagnostic skills, how much you know about electronic repairs, and your availability of parts.
Generally, i suggest people take their repairs to professionals as poking around inside electronic gear can cause more damage, both to the gear and to themselves.
Apr 28, 2016 | Yamaha Music
Tv dead. bad power supply for 17lcd tv model ch hgl 1710 ps 12v 130 watts
A very interesting artical to read first:
http://ezinearticles.com/?Repair-LCD-Power-Supply-The-Easy-Way&id=450399
We unfortunately do not sell these parts. After reading the artical and knowing which power supply you need, I may recommend ebay.com or go to your local electronic store. Some power supplies are very common and easy to find. Good Luck
Nov 16, 2007 | Televison & Video
P191w
The Acer p191w uses the same power supply as the Viewsonic VX1962wm that your problem is a well known issues with that power supply. The filter capacitors go out and that causes the power supply to shut down within a few seconds. The monitor is easy to repair, you will just need to replace the bad capacitors on the power supply board. Here is a link to a repair guide for the Viewsonic VX1962wm and the information will be the same since the boards are the same in both units.
http://www.ccl-la.com/blog/index.php/viewsonic-vx1962wm-monitor-repair/
Dec 22, 2012 | Acer P191W 19" LCD Monitor
Blank White screen
A blank white screen is one of the symptoms of a failure in the power supply board. The power supply board is not putting out all of the correct voltages to power up the TV. These types of problems are caused by parts called capacitors. They filter the output power and when they die the power supply can not operate correctly. This is easy to repair if you can do a little soldering. Here is a link to a repair guide for this model.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-fla-01911c-with-a-bad-power-supply/
I hope this helps get your TV back running,
BuddyMc
Apr 09, 2012 | Polaroid TLA-01911C TV
The backligt stay fickers contineu
Flickering or wavy picture is a very common symptom of failing capacitors in the power supply board. This is a very easy repair, it just requires replacing the 6 capacitors on the power supply board. Here is a link to a repair guide for the SyncMaster 214T which uses the same NP-20 power supply board so the repair information will be the same.
http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps,
BuddyMc
Dec 22, 2011 | Samsung 215TW SyncMaster 21" LCD Monitor
I have a blank white screen
Hello Patrick,
A blank white screen is a very common symptom of a failure in the power supply board. There are parts called capacitors that filter the output power and when the die the power supply does not put out all of the voltages needed by the TV. You are getting the backlight power but not the control voltages. This is an easy repair if you can do a little soldering. Here is a link to a repair guide that shows what to look for and replace on the power supply board.
I hope this helps,
BuddyMc
Nov 10, 2011 | Polaroid TLA-01911C TV
My TV has a white/gray screen when I turn it on. I get nothing else, no sound either.
A white or gray screen usually means the power supply board is not functioning correctly. Below is a repair guide showing what to look for on your power supply board. Open the back of your TV and look at the power supply board as shown in the repair guide. If the capacitors are bulging on the top then they have failed and replacing them should get the board and TV back up and running. This is a very easy repair if you can do a little soldering.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
Sep 12, 2011 | Polaroid TLA-01911C TV
My tv wont turn on
This is a common issue with this model. They used cheap components in the power supply board and these cheap capacitors fail and keep the unit from powering up. It is an easy repair to replace the bad capacitors with better quality parts and this should bring the unit back to life. Here is a repair guide for this model that shows what to look for and replace on the power supply board.
I hope this helps,
BuddyMc
Aug 29, 2011 | Polaroid TLA-01911C TV
My HP Pavilion computer unit will not turn on. Have tried unplugging, replugging; all the cords/plugs look good. Unit is quite old (at least 10 years). Monitor still seems to work. Is it dead?
Could simply be your power supply. Please check that the power cord is connected to the computer and that the power supply switch (located in the back next to where the power cord plugs into the computer) is in the on position( I = on 0= off). IF the power cord is plugged into a working outlet and the power supply is on then it can only be one of two things. You have a bad power supply( easy fix that will only cost you about $50 or less) or your motherboard is bad. If you took this into a shop for repair they would pull out the power supply and replace it with a know working one. If that does not fix the problem then they would tell you your motherboard is bad. Power supplies are fairly easy to replace and, for your unit, very cheap, about $15 from newegg.
Jul 20, 2009 | HP Hewlett Packard Pavilion Slimline...
Panasonic VIERA TH-42PX60U 42 in. Plasma HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
