Question about Scag SFZ52-26BS Freedom Z Zero Turn Rider
What is wrong when a Scag freedom z will not crank replaced battery and solenoid switch it ran and cut the yard switched off now will not crank. Clicking noise coming from the bottom of carburator. Two wires attached one ground wire and one green any ideas what the problem is???
  • banklady46 May 09, 2014
    Tool two handle switches off and put back on, took battery connection off and put back on and it cranked. Let it run awhile and turned off it would not crank. Each time we took battery connection off and put back on it would crank. Did this reset something on mower to cause it to reboot?
  • Daryl Gleaton May 09, 2014
    Do the cables get real hot? This is a sign tht the starter is drawing too many amps. The armature or field coils have to be shorting out or are open when it gets hot.
  • 656 Answers
Recheck your connection at the battery and the solenoid. The clicking noise is probably the solenoid. The starter may have a shorted out field coil or armature. This will cause a starter crank over sometimes but it will have a bad spot where it will not crank. Check connection at starter as well.
Posted on May 07, 2014
My john Deere 110- 42" cut lawn mower ran out of gas and won't crank back. Noticed the parking brake is engaged but will still roll. What is my problem?
Hi Shannon, It's either fuel OR electrical, First check electrics, If it cranks but not starting......
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 29, 2016 | John Deere Garden
I need a diagram to remove a housing on a scag freedom z
you need to figure out what you are trying to ask... if you mean dis-assemble the transaxle then you're looking in the wrong place. Scag doesn't build those. Hydro Gear does
Oct 20, 2014 | Garden
It was cranking on 1st or second pull, ran out gas half way thru yard, put in gas, it cranked and ran 10 ft& cutoff. now it will try to fire but wont crank and stay cranked??
Many issues possible. I would try a gas stabilizer. This can clean out the carb. There is a needle value which can get clogged and thus cause the lack of gas. This happen when the gas runs out and the minerals on the bottom of the gas tank get in the carb. flushing the carb or rebuilding is obviously the next option.
Aug 15, 2014 | Garden
Key will not work in scag ztr
Go through your safety switches to make sure they are all being engauged proparly first.
Jul 28, 2014 | Scag SFZ48-600FS Freedom Z Zero Turn Mower
I have a cub cadet lt104 and we replaced the battery and solenoid and it won't start
wont crank or wont start. 2 different things...
wont crank, in this order: check fuse, brake switch ( adjustment and operation ) and then ignition switch
wont start but does crank: check for spark, yes then check fuel shut off solenoid. no, disconnect kill wire to coil and check again, still no, coil is issue, if yes after disconnecting kill wire suspect a safety switch
May 16, 2014 | Yard Machines 155 Torque Briggs Stratton...
My freedom z will not start
1. Be sure the fuel shutoff valve, located behind the
operator's seat, is completely open.
2. Sit in the operator's seat, fasten seat belt and place
the steering control levers in the neutral position.
3. Engage the parking brake.
4. Place the PTO switch in the disengaged position.
5. If the engine is cold, choke the engine as needed.
6. Move the engine throttle control to about half engine
speed.
7. Turn the ignition key to the START position and
release the key as soon as the engine starts. Do
not hold the key in the START position for more
than 15 seconds at a time. Allow at least 60
seconds between each cranking attempt to prevent
overheating of the starter motor. Prolonged cranking
can damage the starter motor and shorten battery
life.
8. Allow engine to warm before operating the mower.
Apr 05, 2014 | Scag SFZ61-730FS Freedom Z Zero Turn
Won't start
The click means the starter solenoid is acting. Most starters are like GM autos where this solenoid is on the starter. Often heat adversely effects these parts. Try tapping the solenoid and try to start it. If that works then a rebuild is indicated.
Mar 26, 2014 | Scag STWC48V-25CV Wildcat Zero-Turn Rider
Blades will not engage but will remain running
It is most likely the switch. I had the same problem and that fixed. I found the switch on Amazon for less than $20. Stens 430-798 PTO Switch Replaces Scag 483957
Apr 05, 2013 | Scag SFZ52-26BS Freedom Z Zero Turn Rider
Scag SFZ52-26BS Freedom Z Zero Turn Rider Logo
651 people viewed this question
Top Scag Garden Experts
Rick Johnson
Rick Johnson
Ted Maxwell
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Scag Garden Expert? Answer questions, earn points and help others
