Question about Karcher PSI Electric Pressure Washer
I am trying to remove tne nozzle so I can attah the scrubber. Cannot remove nozzle. I have pushed in on it , it turns now how do I remove. Very FRUSTRATING
    Scholar:
  • 63 Answers
PUSH IN TURN LEFT AND WHEN IT STOPS PULL OUT. I just see an image no description, your talking about a kercher pressure washer I hope. Hope this helps let me know ! dcgun
Posted on Jun 22, 2009
My 2000 chevy suburban interior rear view mirror is loose at the adjustment section it drops down and seems loose to the touch when trying to move it up but secure at the section that is attached to the...
If you are referring to the mirror mount on tne windshield..there is a small hex screw on tne underside of tne mount that tightens the mirror to tne mount..just find the size very small and tighten it..ask at any of the auto parts stores..the screws are pretty much the same..Good luck...
Mar 04, 2015 | Cars & Trucks
How do I remove burnt rice stain in saucepan ?
Metal wool scrubbers available from the local poundland will remove anything that is hard to remove on virtually any surface.
May 06, 2014 | Computers & Internet
No water or cleaner at nozzle
Did not work. Already filled
Jan 08, 2014 | Hoover Spot Scrubber
Trouble attaching nozzle to xl
Oreck is junk, despite the ads. trade it in on a Royal and yuu problems are over.
been in the vac repair business for 20 yrs
Jan 05, 2014 | Oreck XL Shield Power Scrubber Floor And...
I have HP Photosmart 3210 All in one. I use nebs
Solution for 3200 series HP prints that no longer print black.
I have followed the directions on using "Non-Acetone" nail polish remover and it works.
I will add a few more details on working this solution. READ all these instructions before you attempt this.
1. The brand of nail polish remover that I used was "Cutex" but the bottle should say, right on the outside, "Non-Acetone" or "Acetone Free." This is what you need to clear the blocked ink receiving nozzle and or ink feeding tube.
2. The best syringe to use is a small "3 cc" type. I started with a "10 cc" but the diameter size of the syringe hit up against a square piece of the plastice molding on the printer. The smaller one does not.
3. Pull the ink cartridge out, locate the two ink receiving nozzles on the printer. They are small, less than 1/4 inch long. The bottom receiving nozzle on the black was plugged on my 3210 HP printer.
(The nozzle fits into the stem on the syringe.)
4. Pour some the "Non acetone" nail polish remover into the cap of the polish remover bottle. **** up 2 cc's of nail polish remover, hold up the syringe and remove any air until some nail polish remover comes out the end.
5. Get a flash light in one hand and illuminate the nozzle and the syringe in the other hand and insert the nozzle into the end of the syringe (no not try to have a needle or filler needle on the end of the syringe-it makes a mess).
a. Slowly apply pressure to the punger of the syringe. Very little will go in initially but when it does--slowly pull the plunger back. The solution will turn black.
b. Do this process 3-5 times until you can inject get about 1cc into the nozzle. Once this happens you can try to **** it back out. You will not get it all back but it helps break down the clog.
6. Once you can get 2cc's into the nozzle try the other nozzle to see if it is plugged as well. The nozzle that is plugged will offer a lot of resistance and you may have to push hard to get the initial amount in, BE CAREFUL not to push the clog way into the tube--repeat process 5b until it pushes a little easier.
a. The nozzle that is not plugged will offer very little resistance when pushing on the plunger.
7. Once you are at this point, run a "Clean print heads" and then "Align printer" from the printer menu. a. Push "set up" button on left side on menu panel. b. Push down arrow to item 2 on the display window "tools" and you will find "Clean print head" & "Align printer."
Run this a couple of times you should start to see some black ink printing on your paper (make sure there is ink in your cartridge)
8. Initially, the color will be gray. Next, go to your word processing program and make a document that has one inch wide lines on it. Run about 8-10 lines on a single piece of paper, adjust the ink flow to auto/600 dpi on the properties menu of "print" and print 10-15 pages of this to get rid of all the nail polish remover in your print tubes that lead to the print head. The color will start with grey and eventually turn black. You will know the nail polish remover is coming out because the paper will smell like finger nail polish remover.
Try this and it should work for you as well.
Feb 17, 2010 | HP Photosmart 3210 Printer
Uninstall Problem
If you are installing the software using Windows and the software was not successfully installed or the uninstaller could not be found, run the Scrubber Utility to perform a clean driver uninstallation Use the Scrubber Utility Use the following steps to run the Scrubber Utility.
  1. Disconnect the printer from the computer.
  2. Restart the computer.
  3. Insert the Starter CD into the CD drive. If the CD menu displays, close the CD menu.
  4. Locate the Utils\Scrubber folder on the Starter CD.
    • For Windows 98 and Windows Me, use the scrub9x.exe file located in the Utils\Scrubber\Win9x_Me folder.
    • For Windows 2000 and later, use the scrub2k.exe file located in the Utils\Scrubber\Win2k_XP folder.
  5. Double-click the file to run the Scrubber Utility.
  6. The following message will display: This utility will attempt to remove all HP DeskJet 460 Series devices from your system. It is recommended that you disconnect the device and restart before continuing. Do you want to continue without rebooting?
  7. Click Yes . A message stating Successfully removed the devices(s)! This system is ready for installation displays after the scrubber utility finishes running.
  8. Click OK .
  9. Restart your computer, and then reinstall the printer software
Apr 27, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Karcher PSI Electric Pressure Washer Logo
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
