Question about Refrigerators
Freezer not getting extra cold
I have a Viking VCSB483SS and recently the alarm for high temeperature is sounding (about every day or so) and I have tried reducing the freezer temperature . One thing noticable is that frozen food stays frozen but new packets )(say peas etc) do not go hard with freezing) I took off the kick plate and the condensor tray seems fine with a little water in it and the condenser coils clean. ONe strange thing is that I notice a 24vdc fan at the front (obviously for the condenser coil above the tray is not connected (and I presume never has been since I purchased the house with the refrigerator/freezer)...why would that be ?...the cable and connector are just wound in a coil and not plugged inot anything?
  • 957 Answers
This one is a puzzle. I have never worked on a Viking fridge but if the alarm is coming on it may have something to do with the fan not being connected because that would cool the coil. You might go on line and contact Viking and ask them this question. I don't want to tell you to hook it up and it not suppose to be. good luck
Posted on May 07, 2014
Noggin
  • 944 Answers
SOURCE: Food in the freezer of 52603 is too cold/frozen.
This would usually indicate that some refrigerant gas has leaked out - the effect at certain percentages is to allow the gas to expand too much when it first enters an evaporator (the plate in the freezer that gets cold), thus making it much colder than the thermostat is set too. due to environmental laws you cannot top this up yourself, it must be done by a qualified fridge guy. get him to check for leaks as well, usually they can be fixed if there is one, but a tiny amount of refrigerant can leak out over time with no actual major leak. Try first defrosting completely - occasionally ice crystals can form inside the refrigerant system which may be causing the problem, once defrosted, this water should be dealt with by the filter/drier. Probably still needs refrigerant gas, but is worth trying. once the gas is topped up then ask the guy to check that the freezer thermostat is working correctly - it could possibly be faulty, no way to tell easily without just replacing it or topping up the refrigerant gas first. Hope this helps, please post again if not :)
Posted on Mar 26, 2007
  • 27 Answers
SOURCE: Freezer keeps loosing its temperature and then freezes again
Sounds like a pc board problem. I have come across many units like these (although I don't know the Samsungs!) which have similar symptoms...it would seem like the freezer gets stuck in "defrost" mode and the ice would melt etc.etc.... In most cases replacing the electronics module solved the problem...in hindsight I have figured out that it was moisture on the pc board components that were to blame! So as a first resort I would locate the main electronics board and use a hairdryer to dry out thouroughly (even if it seems dry!) Also check values for temperature sensors....don't know what the specific values for the Samsung NTC's are, but normally they are in the low kOhm's.... Oshie
Posted on Jun 26, 2007
turbo5280
SOURCE: Kenmore refrigerator freezer not freezing
The problem is in the defrost system.. You have a defrost heater in your freezer that comes on 3 times a day & melts the frost to keep your freezer frost free. That frost turns to water & runs down a drain & eventually goes to a drain pan located under the unit. On these models the hole for the drain is located directly under the evaparator fan. The drain hole is to far from the heater so the water settles & then freezes around the fan blades causing it to stop spinning. Its that fans job to circulate cold air from the freezer to the fridge, so now all the cold air is staying in your freezer. Last I knew they were workin on a solution to this but you need to contact the manufacturer. A temporary fix would be to unplug & then defrost the freezer by taking out the freezer panel & melting all the ice. Boiling water is effective. When you get the ice gone from around the fan you should be able to see the drain hole & be sure water runs freely down the hole. Put it back together then adjust the front legs of the fridge so the whole unit slopes back slightly causing the water to run back to that drain hole without settling.
Posted on Apr 27, 2009
  • 1810 Answers
SOURCE: fan and I presume condenser
you have a coolant leak or a failing compressor
time to call the service tech out br you cook somthing else
Posted on Jul 29, 2009
heatman101
  • 43501 Answers
SOURCE: No cold air to refrigerator; extra cold air to
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 31, 2010
My built in Viking frig/bottom pull out freezer overflowed water recently. The alarm keeps going off with "freezer temp" light coming on. Please see details below.
that guy is ripping you for service calls it need recharged with gas and he knows it . being that only certified tech can do that task
Jun 08, 2015 | Viking DFBB363 Bottom Freezer Refrigerator
"high alarm" freezer not freezing
Check condenser coil to make sure it is not clogged with dust and lint . Make sure condenser fan is operating. Hope this helps.
Dec 24, 2013 | Refrigerators
Refrigerator not cold / freezer not cold as should be. room is not hot. motor running fine, interior light goes on. temperature alarm beeps to signal too warm at least once a day. if shut top part of...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Viking Professional Series VCBB36 Bottom...
MY viking side by side refrigerator isent working
If only a year old it will be fully covered by warranty. Meantime try disconnecting from the mains power supply for 30mins (dont worry the frozen items wont be affected for this short a period) then switching on again, as this may trigger the motherboard into normal mode
Good luck
Mar 20, 2010 | Viking DDBB363 Bottom Freezer Refrigerator
Viking freezer and fridge won't get cold enough.
I had the same problem with my side by side. Make sure the vents are not covered inside both the fridge and freezer between the bottom and top so the cold air is able to circulate between them. My freezer had ice covering the bottom vent.
May 27, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Viking freezer and fridge power on but not getting cold.
Are you sure the compressors are running, it could just be that the fans are starting but the compressor does not start.
It sounds as though you may have fried the boards again.
Remove the top grille and reach in to the compressor, to see if it is running, you should be able to feel it vibrating, there should also be some heat to it, not neccessarily hot.
have you tried putting surge protectors on the outlets, to save the boards in the future?
Dec 11, 2008 | Viking 15.9 cu. ft. Upright Freezer...
Viking VCBB363RSS Fridge Orange High Temp light on
I am not sure if I have the same model, but the VIKING fridge that I purchased in Chicago is a stainless steel bottom freezer design that is horrible. I paid alot for it and it looks great on the outside - like a pretty girl that has nothing to say.....The alarm goes off constantly and tonight the freezer wasn't working! This thing is not even 5 years old and my GE fridge in the basement that I use to store drinks for the pool and things that I don't want to spoil is probably 40 years old (I got it from my parents and has NEVER been a problem). What is up VIKING? Where are your engineers??
Jul 07, 2008 | Viking VCBB363L Bottom Freezer...
ARISTON FRIDGE FREEZER MBA 3842C PROBLEM
It should work the same as before. Does the compressor get really hot after running a while? If so it could be low on charge, or there could be a restriction inside the refrigeration system. Either way a professional would have to look at it.
Jan 07, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Viking Refrigerator problem
Try this my Mother had a similar problem, make sure the vents are not covered inside the fridgerator between the bottom and top so the cold air is able to circulate between them.
Oct 21, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
