Question about Panasonic Lumix DMC-FS5 Digital Camera
Dmc-fs5 when open the the clock needs to be set then after a while it asks that the camera should be turn off
SOURCE: Panasonic Lumix camera, DMC FS5
I had same problem. I just got the camera working again. Not sure how it exactly happened but while I had it on and it was zooming in and out, I changed the mode and tried to take a pic. It would ask me to turn off and on again which I would do quickly and change the mode to something else like "portrait" or "landscape", etc. and try to take a pic. After a few times it stopped and focused on something. So not very scientific but doing that must have kicked it in the head or something.
Posted on Jun 18, 2009
  • 11967 Answers
SOURCE: My Lumix DMC-FS5 camera had locked memory card,
Move the slide switch on the side of the card.
Posted on Oct 21, 2009
SOURCE: Hi, I have a panasonic Lumix, DMC-FS5 digital
I had this same problem. I have just pulled the lense (not with any major strength) when it was fully extended. This seems to have solved it for me!!
Posted on Oct 27, 2009
  • 11967 Answers
SOURCE: Panasonic Lumix DMC-FS5 camera. Condensation
You can't. In the future, when coming in from the cold with your camera, place it in a 6-pack cooler that is the same temperature as the outside. Put some silica gel packets in the bottom and don't open it for a while to let it slowly come up to room temp. Cleaning the lens on your present camera could be expensive depending where you take it. Use your computer to ask for estimates.
Posted on Jan 17, 2010
  • 11967 Answers
SOURCE: Lens won't retract, cannot focus when taking pic.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 19, 2010
How to turn off the flash on a panasonic dmc-fs5
Press cursor-right (marked with a lightning bolt). Use cursor-up/down to select "FORCED FLASH OFF" and press the MENU/SET button.
Jul 11, 2012 | Panasonic Lumix DMC-FS5 Digital Camera
I need driver for Panasonic Lumix DMC-FS5
Having gone over a month without a response to my query, I assume my suggestion to use a card reader obviated the need for a driver.
Jul 15, 2011 | Panasonic Lumix DMC-FS5 Digital Camera
Where did i buy a charger of panasonic lumix dmc f55,,,
You can buy it on Amzon:
http://www.amazon.com/Pansonic-DMC-FS3-DMC-FS5-DMC-FS20-DMC-FX35/dp/B0018AMGNK/ref=pd_cp_e_0
Mar 01, 2011 | Panasonic Lumix DMC-FS5 Digital Camera
Lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
Feb 19, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
Panasonic Lumix DMC-FS5 camera. Condensation inside lens has dried leaving two blotches behind that show on every picture. How can I clean this inside once blotches are dried there?
Jan 17, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
Panasonic DMC-FS5 Instruction book
http://www.panasonic.co.uk/html/en_GB/Products/DMC-FS5/Manuals/539427/index.html
cheers ..
Jun 05, 2009 | Panasonic Lumix DMC-FS5 Digital Camera
Lost cd to down load images from camera to p c
Hi
Im sorry but I don't have software available for Panasonic cameras at this time, and we don't sell cables. If you go on ebay and search 'dmc-fs5 usb' you will find the cable you need for $5. Wish I could offer more help than that, sorry.
Thomas
Darntoothysam com
Oct 21, 2008 | Panasonic Lumix DMC-FS5 Digital Camera
Panasonic Lumix DMC-FS5 Digital Camera Logo
21 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
