Question about Garden
What causes my 13.5 hp craftsman model #917270412 engine to die when i release the clutch
I have 13.5 hp craftsman model #917270412 . My son was using the mower and the drive belt broke. I replaced the drive belt, it is on as diagram shows. When the clutch is pushed in ; the belt is loose... when the clutch is let out the belt is tight. The mower will start but dies when I release clutch whether in gear or in neutral. The seat switch is disconnected. If you have any ideas, I would appreciate your input; my grass is growing quickly.
  • john grant May 07, 2014
    My mother was using the mower for the last year, i know that at some pont she bent a blade, i replaced the blade and she continued using. when i i replaced the drive belt, the deck was off, still is and it is dying when i let off the clutch
    By the way thank you for responding!!
  • 957 Answers
My question would be what caused the belt to break. Have you checked under the mower deck to make sure the blades turn freely? Could be that something is jamming them and causing the motor to die. Or even a blade that hit something hard might be bent against the top of mower deck.
Posted on May 07, 2014
My sears craftsman riding mower will crank just fine, but as soon as I try to either put it in gear and release the clutch to go forward or backward, it shuts off. It also shuts off when I attempt to...
Many folks have found that a defective relay in this mower to be the cause of the "stall when i take my foot off the clutch" issue. The relay is connected to the safety switches which turn the mower off when no one is in the seat, etc.
Aug 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Apr 18, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Mar 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Mar 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine dies off once brake/clutch is released
Your answer was perfect, when I located the saftey switch it was not working properly.
Thanks a million, Ron
Jan 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 16 hp 42 in. riding mower won't run when clutch is released
If the engine feels like it is being choked, then something might be catching or bound up...for example the blades may have been installed improperly and will not rotate. Make sure that you can rotate the blades by hand...if not they may have been tightened and are binding against the mower housing.
If there is no engine choking...then it may be electrical for example a bad fault switch...take it to your mower shop.
good luck
Sep 27, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
