Question about Alera Technologies Cruiser (270118) DVD±RW Dual Layer Burner
Overheating spark plugs
Hi i have a vectra x18xe1 engine and i have a tapping noise also my plugs are over heating does anyone know what the problem is please
    Sergeant:
  • 280 Answers
Any general overheating problem with plugs and electrical devices might relate to a short circuit. Please check all cables and esp. the plug to ensure no short circuit happens. If it continues and if the problem is not identifiable, take it to a technician, using it might result in component damage. Get it fixed as early as possible
Posted on Jun 22, 2009
Check engine tapping noise car shuts off
Need to find out the codes on check engine light. Tapping usually is oil, spark plug, vacuum leak , or worse case valve tap but usually problems are the simple ones when it occurs all of a sudden. Check your spark plugs to make sure not loose and check to make sure any small black tubing isnt disconnected anywhere.
Dec 08, 2013 | 1999 Dodge Durango
Tapping noise when engine switched off and key withdrawn, only stops when battery is disconneced
After running/run on:carbon deposits in the combustion chambers (absorbing fuel then releasing it), low octane fuel (get's fired latter) , overheated engine (enough for self ignition), or spark plugs with too high of a heat range rate.Can be also :key ignition barrel (the inner switch),worn pistons ring/worn valve sealers (firing oil that appears in the chamber,kinda like diesel),main relay mulfunction (does not cut the fuel/ignition).Cheers,hope u share if figure out.
Oct 26, 2013 | 2004 Jaguar X-Type
Vectra 2.2
Hi my vectra did this and didn't show a fault code it's the crank shaft position sensor located behind the starter motor on the front of the engine the sensor is about 30 pound mines never cut out sins i change my spark plugs and coil pack to trying to figures out who knew it was a little sensor it through a your crank shaft outta wack and it throws through a lot of petrol otta timing cheers scott
Aug 31, 2012 | Vauxhall Vectra Cars & Trucks
Our fx35 over heated and refuse to start
Hi.
If the car overheated you may have blown the head gasket and other in the block. In that case the engine may not start anymore because of lack of compression, because piston rings are gone, valves may have been damaged etc. Another part that in many vehicles may blow with engine surge from overheating is the fuel pump. There are more parts that must be tested. If overheating drained the coolant fluid reservoir, then the head gasket usually must be replaced. Try replacing the spark plugs. If there have been overheating and engine surging the spark plugs must be replaced. If that does not do the job, then there is a major fault to troubleshoot.
Regards.
Ginko
Sep 19, 2011 | 2006 Infiniti FX35
Put new waterpump and thermostat in and still overheating got heat in car no leaks is there a bleeder for the coolant dont know if theres air or whats going on please someone help lol
Hi :) Check the gap of the spark plugs, this can cause a motor to over heat and check the compression and the oil pump pressure and the fuel filter, a engine not getting anought fuel can burn lean and over heat.
Mar 16, 2011 | Chevrolet Cavalier Cars & Trucks
Overheating
you might have a blown head casket try due a pressure test on each cylinder and sometimes you can take a spark plug out 1 by 1 and just tap the ket so it cranks and see if water comes out of the cylinder
May 20, 2009 | 1995 BMW 5 Series
Spark plugs 24v v6 sri 200 vauxhall vectra!!!!
On vectras they are hidden under a black plastic cover ontop of the engine, but you don't need new plugs for the mot
Feb 23, 2009 | Alera Technologies Cruiser (270118)...
Spark plugs on a vectra
If it the 16v engine, remove the top engine cover. In the centre of the engine there is a long black coil pack, with a plug on the right hand side. Remove plug and the couple of bolts holding it onto the engine. Spark plugs are underneath.
TL
Nov 21, 2008 | Alera Technologies Cruiser (270118)...
Radiator drain tap/plug
Thanks Guys,
Spoke to the Holden Dealer service Tech and got the information i needed.
Kindest Reagards
Ruwan
Jul 03, 2008 | 2006 GMC Acadia
Open Questions:
Get your wife husband back lost love spells caster in city of New York +27832762854 Have you ever been in a failed relationship? Did you often feel like your partner didn't 'get' you? Are you having many obstacles in your life? Is your love life falling apart? Is your life facing financial ruin? Do you need protection from your enemies? If you seek a lost lover, or want a new lover, we can help. We reunite lost lover`s If you are really in love with someone then this is the spell for you. divorce affairs all kind of witchcrafts bring back lost love spells in NHL Eastern Conference bring back lost love spells in Boston Bruins bring back lost love spells in Buffalo Sabres bring back lost love spells in Carolina Hurricanes bring back lost love spells in Columbus Blue Jackets bring back lost love spells in Detroit Red Wings bring back lost love spells in Florida Panthers bring back lost love spells in Montreal Canadiens bring back lost love spells in New Jersey Devils bring back lost love spells in New York Islanders bring back lost love spells in New York Rangers bring back lost love spells in Ottawa Senators bring back lost love spells in Philadelphia Flyers bring back lost love spells in Pittsburgh Penguins bring back lost love spells in Tampa Bay Lightning bring back lost love spells in Toronto Maple Leafs bring back lost love spells in Washington Capitals bring back lost love spells in Western Conference bring back lost love spells in Anaheim Ducks bring back lost love spells in Arizona Coyotes bring back lost love spells in Calgary Flames bring back lost love spells in Colorado Avalanche bring back lost love spells in Chicago Blackhawks bring back lost love spells in Dallas Stars bring back lost love spells in Edmonton Oilers bring back lost love spells in Los Angeles Kings bring back lost love spells in Minnesota Wild bring back lost love spells in Nashville Predators bring back lost love spells in San Jose Sharks bring back lost love spells in St. Louis Blues bring back lost love spells in Vancouver Canucks bring back lost love spells in Vegas Golden Knights bring back lost love spells in Winnipeg Jets bring back lost love spells in NBA Eastern Conference bring back lost love spells in Atlanta Hawks bring back lost love spells in Boston Celtics bring back lost love spells in Brooklyn Nets bring back lost love spells in Charlotte Hornets bring back lost love spells in Chicago Bulls bring back lost love spells in Cleveland Cavaliers bring back lost love spells in Detroit Pistons bring back lost love spells in Indiana Pacers bring back lost love spells in Miami Heat bring back lost love spells in Milwaukee Bucks bring back lost love spells in New York Knicks bring back lost love spells in Orlando Magic bring back lost love spells in Philadelphia 76ers bring back lost love spells in Toronto Raptors bring back lost love spells in Washington Wizards bring back lost love spells in Western Conference bring back lost love spells in Dallas Mavericks bring back lost love spells in Denver Nuggets bring back lost love spells in Golden State Warriors bring back lost love spells in Houston Rockets bring back lost love spells in Los Angeles Clippers bring back lost love spells in Los Angeles Lakers bring back lost love spells in Memphis Grizzlies bring back lost love spells in Minnesota Timberwolves bring back lost love spells in New Orleans Pelicans bring back lost love spells in Oklahoma City Thunder bring back lost love spells in Phoenix Suns bring back lost love spells in Portland Trail Blazers bring back lost love spells in Sacramento Kings bring back lost love spells in San Antonio Spurs bring back lost love spells in Utah Jazz bring back lost love spells in NCCA bring back lost love spells in Air Force Falcons bring back lost love spells in Alabama Crimson Tide bring back lost love spells in Arizona State Sun Devils bring back lost love spells in Arizona Wildcats bring back lost love spells in Arkansas Razorbacks bring back lost love spells in Army West Point Black Knights bring back lost love spells in Auburn Tigers bring back lost love spells in Baylor Bears bring back lost love spells in Boston College Eagles bring back lost love spells in BYU Cougars bring back lost love spells in California Golden Bears bring back lost love spells in Clemson Tigers bring back lost love spells in Colorado Buffaloes bring back lost love spells in Florida Gators bring back lost love spells in Florida State Seminoles bring back lost love spells in Fresno State Bulldogs bring back lost love spells in Georgia Bulldogs bring back lost love spells in Georgia Tech Yellow Jackets bring back lost love spells in Houston Cougars bring back lost love spells in Illinois Fighting Illini bring back lost love spells in Indiana Hoosiers bring back lost love spells in Iowa Hawkeyes bring back lost love spells in Iowa State Cyclones bring back lost love spells in Kansas Jayhawks bring back lost love spells in Kansas State Wildcats bring back lost love spells in Kentucky Wildcats bring back lost love spells in Louisville Cardinals bring back lost love spells in LSU Tigers bring back lost love spells in Maryland Terrapins bring back lost love spells in Miami Hurricanes bring back lost love spells in Michigan State Spartans bring back lost love spells in Michigan Wolverines bring back lost love spells in Minnesota Golden Gophers bring back lost love spells in Mississippi Rebels bring back lost love spells in Mississippi State Bulldogs bring back lost love spells in Missouri Tigers bring back lost love spells in Navy Midshipmen bring back lost love spells in Nebraska Cornhuskers bring back lost love spells in North Carolina State Wolfpack bring back lost love spells in North Carolina Tar Heels bring back lost love spells in Northwestern Wildcats bring back lost love spells in Notre Dame Fighting Irish bring back lost love spells in Ohio State Buckeyes bring back lost love spells in Oklahoma Sooners bring back lost love spells in Oklahoma State Cowboys bring back lost love spells in Oregon Ducks bring back lost love spells in Oregon State Beavers bring back lost love spells in Penn State Nittany Lions bring back lost love spells in Pittsburgh Panthers bring back lost love spells in Rutgers Scarlet Knights bring back lost love spells in South Carolina Gamecocks bring back lost love spells in South Florida Bulls bring back lost love spells in Southern Methodist SMU Mustangs bring back lost love spells in Stanford Cardinal bring back lost love spells in TCU Horned Frogs bring back lost love spells in Tennessee Volunteers bring back lost love spells in Texas A&M Aggies bring back lost love spells in Texas Longhorns bring back lost love spells in Texas Tech Red Raiders bring back lost love spells in UCLA Bruins bring back lost love spells in USC Trojans bring back lost love spells in Utah Utes bring back lost love spells in Vanderbilt Commodores bring back lost love spells in Virginia Tech Hokies bring back lost love spells in Washington Huskies bring back lost love spells in Washington State Cougars bring back lost love spells in West Virginia bring back lost love spells in NFL AFC bring back lost love spells in Baltimore Ravens bring back lost love spells in Buffalo Bills bring back lost love spells in Cincinnati Bengals bring back lost love spells in Cleveland Browns bring back lost love spells in Denver Broncos bring back lost love spells in Houston Texans bring back lost love spells in Indianapolis Colts bring back lost love spells in Jacksonville Jaguars bring back lost love spells in Kansas City Chiefs bring back lost love spells in Los Angeles Chargers bring back lost love spells in Miami Dolphins bring back lost love spells in New England Patriots bring back lost love spells in New York Jets bring back lost love spells in Oakland Raiders bring back lost love spells in Pittsburgh Steelers bring back lost love spells in Tennessee Titans bring back lost love spells in Super Bowl LII bring back lost love spells in NFC bring back lost love spells in Arizona Cardinals bring back lost love spells in Atlanta Falcons bring back lost love spells in Carolina Panthers bring back lost love spells in Chicago Bears bring back lost love spells in Dallas Cowboys bring back lost love spells in Detroit Lions bring back lost love spells in Green Bay Packers bring back lost love spells in Los Angeles Rams bring back lost love spells in Minnesota Vikings bring back lost love spells in New Orleans Saints bring back lost love spells in New York Giants bring back lost love spells in Philadelphia Eagles bring back lost love spells in San Francisco 49ers bring back lost love spells in Seattle Seahawks bring back lost love spells in Tampa Bay Buccaneers bring back lost love spells in Washington Redskins bring back lost love spells in MLB bring back lost love spells in AMERICAN LEAGUE EAST bring back lost love spells in Baltimore Orioles bring back lost love spells in Boston Red Sox bring back lost love spells in New York Yankees bring back lost love spells in Tampa Bay Rays bring back lost love spells in Toronto Blue Jays bring back lost love spells in AMERICAN LEAGUE CENTRAL bring back lost love spells in Chicago White Sox bring back lost love spells in Cleveland Indians bring back lost love spells in Detroit Tigers bring back lost love spells in Minnesota Twins bring back lost love spells in Kansas City Royals bring back lost love spells in AMERICAN LEAGUE WEST bring back lost love spells in Houston Astros bring back lost love spells in Los Angeles Angels bring back lost love spells in Oakland Athletics bring back lost love spells in Seattle Mariners bring back lost love spells in Texas Rangers bring back lost love spells in NATIONAL LEAGUE EAST bring back lost love spells in Atlanta Braves bring back lost love spells in Miami Marlins bring back lost love spells in New York Mets bring back lost love spells in Philadelphia Phillies bring back lost love spells in Washington Nationals bring back lost love spells in NATIONAL LEAGUE CENTRAL bring back lost love spells in Chicago Cubs bring back lost love spells in Cincinnati Reds bring back lost love spells in Milwaukee Brewers bring back lost love spells in Pittsburgh Pirates bring back lost love spells in St. Louis Cardinals bring back lost love spells in NATIONAL LEAGUE WEST bring back lost love spells in Arizona Diamondbacks bring back lost love spells in Colorado Rockies bring back lost love spells in Los Angeles Dodgers bring back lost love spells in San Diego Padres bring back lost love spells in San Francisco Giants
Aug 20, 2018 | Sun Computers & Internet
See all Alera Technologies Cruiser (270118) DVD±RW Questions
Alera Technologies Cruiser (270118) DVD±RW Dual Layer Burner Logo
247 people viewed this question
Top Alera Technologies Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Alera Technologies Computer and Internet Expert? Answer questions, earn points and help others
