My LG ls-h246tnbo split system air conditioner intermittently turns itself on and off. Is there a part that I may replace to rectify?
It cools very well when working. Sometimes works fine. Othertimes it turns itself on and off (or just beeps) every couple of seconds. Is there a solution to this please
  • Rowan Gorringe
    Rowan Gorringe May 12, 2014
    Thanks for that. Have had PCB tested and cant find a fault. Could it be the external BCB soft start and not the internal PCB at fault? Thanks again for your help.
  • 2,133 Answers
PCB malfunctioned. Call technician to remove and repair the PCB
Posted on May 07, 2014
Therinnaiguy
  • 1420 Answers
SOURCE: lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Posted on Aug 30, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Therinnaiguy
  • 1420 Answers
SOURCE: Air Conditioner unit won't switch on outdoors
can you give us some model numbers and a make? Get both the inside and outdoor unit numbers please. Thanks.
Posted on Oct 10, 2007
  • 7 Answers
SOURCE: Remote Problems
you dont leve the remote in the sun do you? could be an issue
Posted on Jan 25, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
My LG 1.5 ton split ac shows F10 error can u pls suggest wht to be done
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Bulance AC Cleaning Repair Services
May 06, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
Not cooling and shutting off, indicator light flashes
the outdoor indictor light on my lg split comes on after some minutes on the one inside and the cooling has reduced please can any1 tell me what the problem is
Jan 18, 2013 | LG LSC121PMA Split System Air Conditioner
Froze up now won't cool
turn system off or leave the fan only on and thaw system out, when it is dry, check filter, if not the problem more than likely it was turned down to low or the freon charge is low and should be check by technician.
Dec 09, 2012 | LG LS-L1210CL Mini Split Air Conditioner
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
I have a LG split system model no LS-H246TNBO have lost the manual and would like to set the timer.
Since your model has been discontinued, you will need to contact LG Customer Support
(800) 243-0000, to obtain a manual. They can probaly email you one as an attachment.
Hope this helped you and thanks for choosing FixYa.
Aug 11, 2011 | Heating & Cooling
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
Jun 15, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
5mint cooling 5minuts heating
The reverse valve and silenoied are bad, you need to change them or replace the condencer.
May 04, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
My LG LAN125 mini split heat pump occasionally shuts down in cooling mode while displaying the code CA. The LG tech tells me there is no such code. When this happens, I have to cycle power off and back on...
Wash out your outside coil and monitor the outside fan. sounds like a lockout due to dirty condenser or intermittent motor operation. Could mean condencer air problem.
Jun 28, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
150 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
