Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
WHY DOES MY TV HAVE A BLACK SCREEN? I have a Westinghouse flat screen. One day it stopped powering on, so I unplugged it, and put it in the garage. I brought it back in thinking that maybe it would work after being off for some time. Anyway, I plugged it and turned it on. The light on the bottom lit up blue for a few seconds, and then it turned orange and stayed that way. The screen is completely black...PLEASE HELP!!
    Top Expert:
  • Westinghouse Master
  • 45,112 Answers
Power supply failure
Posted on May 07, 2014
  • 10 Answers
SOURCE: westinghouse LTV30w2 has blank screen and audio
What you have is a darfon V144 board (junk). it's a simple fix if you know how to use some basic tools and a soldering iron. Get an led (i used digikey's PN: L10041-ND) and solder it from pin 10 to pin 16 on the OZ960 chip on the inverter board. If you need the chip layout type "OZ960 pdf" in google. Hope this helps.
Posted on Dec 31, 2009
Ajkill
  • 2035 Answers
SOURCE: Westinghouse Green Screen
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Posted on Jun 10, 2008
SOURCE: westington LTV-27w7 HD black screen
If the power light stays on green, I would look tward a backlight issue. If you can see any image at all then the backlight controler or the backlights are bad. If there is nothing then if could be a power supply overheating or an inverter failure. More than likely as the unit heats up a failed solder connection is loosing contact causing the screen to go black.
Posted on Feb 10, 2008
Adolph
  • 137 Answers
SOURCE: Blue screen for a second after power on and then black screen again
Check where your plug go's in to your powersupply if it is well fitted. ////sometimes it dosnt make well connection then you will struggle to get it on.
Posted on Dec 22, 2007
  • 187 Answers
SOURCE: seems as if LCD screen is not recieving any power, I have no picture or sound right now but can faintly hear speakers power up when I turn the unit on.
Mainboard damaged.
Posted on Jun 02, 2009
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
My Westinghouse TV was working just fine, but stopped turning on after I had issues with the cable box. Those are resolved, but I can't get it to turn on. Anyone have any ideas on how to fix this?
Patience may be the key--It may be substrate charge phenomenon--
Disconnect everything from the TV, including power cord and all ins & outs and wait awhile (3 days is sufficient) to let the internal charges bleed off. Reconnect TV and try it again. It sounds like a power surge (or lightning strike nearby) jammed a temporary "substrate charge" onto TV's circuitry.
May 05, 2015 | Westinghouse Televison & Video
My tv wont stay on
There's a problem on the power supply board. You can get parts here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 11, 2015 | Westinghouse Televison & Video
Westinghouse SK19h210Sd black screen with sound only
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 06, 2012 | Westinghouse SK-19H210S Television
I have a 52" westinghouse
Ok you have a lot of things going on here. Your first thing with the lines can be your T-con board or your Signal board or the screen itself. The second thing black screen you would have to be more specific? Is your back light on and you have no image? If that's teh case then I would replace the T-con board or the Signal board. If by black screen you mean there is no light on the screen from the backlight inverter then your BAcklight inverter or the backlight itleft might be bad. and ontop of that you might have the problem that we started with also. You can get westinghouse parts from www.interliquidparts.com You have to order by part numbers so you have to get the number from the actual part of your TV.
Jun 13, 2011 | Televison & Video
Hi, My name is Anali and I recently purchased a Westinghouse TV from Target. I had it plugged into the wall and working one evening. The next day when I went to turn it on again the red button would...
Hi Anali. That sounds like the powersupply is bad. The tv has a one year manufactuers warranty. Take it back to Target and exchange for another one. Hope this helps.
May 27, 2011 | Televison & Video
Jun 10, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
ROLLING TV SCREEN
After 2 days of problems with it, I finally fixed it by unplugging it and plugging back in! Works like new.
Apr 03, 2008 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
LTV-27w7 blackscreen
Have you tried unplugging overnight? Sometimes mine gets screen garbage and that clears it up. Of course, now it says "Auto Scan Required" every time I power up. Maybe I should've grabbed that after Xmas 32" at Fry's for $400.
Dec 25, 2007 | Westinghouse LTV-27w7 7 in. LCD HDTV
Oct 13, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
193 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
