Question about Whirlpool Dryers
Why wont whirlpool duet dryer model WED8300SW1 heat?
Whirlpool dryer wont heat
    Problem Solver:
  • 8 Answers
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
Posted on May 07, 2014
jsrock516
  • 5911 Answers
SOURCE: My whirlpool dryer (Duet) will not heat. What
If your dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop and compare.
If you need further assistance, please post back and let me know. I hope you find this information helpful.
Posted on Dec 23, 2009
  • 401 Answers
SOURCE: Whirlpool Duet Dryer not heating
FIRST YOU SHOULD CHECK YOUR BREAKERS MAKE SURE BOTH ARE ON. YOU NEED 110V TO RUN THE MOTOR BUT 220V TO HEAT.IF THAT IS FINE IT MAY BE A SENSOR OR A ELEMENT.
Posted on Jan 15, 2010
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Dryer ( gew9200lw1): no heat
If your dryer runs, but does NOT heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
Replacement parts (if required) can be found at the following websites:
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need. The heating components are usually listed under the "Bulkhead" section.
NOTE: In many cases the problem is NOT the heating element. The heating element has protection devices that are designed to regulate the heat temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Read through the information I provided and, if you have any questions, please post back and let me know. I hope you find this information is helpful.
Posted on Feb 25, 2010
  • 949 Answers
SOURCE: the dryer works but there is no heat
If the breakers are okay and you have power to the dryer the problem would be one of two issues.
The first and most likely is the thermal cut off. This is a small temperature activated fuse that will trip if the air flow through the heater is poor, this is usually due to a plugged lint filter or restricted vent pipe between the dryer and outside.
The second is the heat element itself has gone bad. You can measure it with an ohmmeter or physically inspect it for breaks. The image I have attached shows both. The T cut off is part 47 and the element is part 14 both visible with the lower panel taken off. The lower panel has 2 screws visible while laying on the floor looking straight at the panel.
The part numbers for the components are 279973 (cut off kit) and 3387747 (heater)
Posted on Apr 24, 2010
  • 24 Answers
SOURCE: replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
Posted on May 25, 2010
Whirlpool duet dryer wont heat model wed8300sw1
check for 220 volts at dryer it will not heat on only halfe breaker, check heater for continuity and all the thermostats and sensors
May 07, 2014 | Whirlpool Dryers
Why my whirlpool duet dryer wont heat model wed8300sw1
Are the thermal fuses ok? If you're in the back of the machine clean out all the oose, lint, fluff or whatever that causes the heat build up.
I have a whirlpool Duet gas dryer, model ggw9200lw0. It will glow then heat up but switches off right away.
It sounds to me like your flame is not getting enough air. Make sure that ur screen is clean then clean your dryer vent. The easiest way to see if it is your dryer vent is to take the vent off the back of the dryer. If it runs good without it then you need to clean it. If the dryer heats up a couple times then wont heat up after that then you need to replace the coils
Aug 26, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Why won't the dryer heat
the heater element and/or the stats may need replacing
cheap on ebay.........
cheers
Jul 28, 2017 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool Dryer heats and hums, but does not spin. Mod WED8300SW1.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 13, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryers Logo
81 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
