Question about GE 60-983 ATP1000 Alphanumeric Touchpad
How to set time/date on ge 60-983 atp1000 - GE 60-983 ATP1000 Alphanumeric Touchpad
Date 01/31/14
Does it keep losing the date when you turn it off? or are you asking how to set the time and date?
If you're losing time and date when you turn the unit off, there's a coin cell battery on the main processor board that needs replacing.
If you just want to set the time and date - Press "SHIFT" and 12 lead keys at the same time. select "7" for date and time, use the return key to select date or time
Jan 31, 2014 | Ge Medical Systems Ge Marquette Mac 1200...
How do I set the date and time on my GE Mac 15 Interpretive ECG Unit?
http://www.frankshospitalworkshop.com/equipment/documents/ecg/user_manuals/Marquette%20MAC%2015%20ECG%20-%20User%20manual.pdf
Page 12-3 or 201 in Adobe Reader has info for setting up date and time
Mar 23, 2012 | Ge Medical Systems Ge Healthcare Mac 1200...
Need information on how to set time & date on a GE
Press and hold the STOP/SET button for two seconds, then release to access the set-up menu. The time/date setting follows the language.
The full details are in the "Changing the Settings" section of the manual (page 10 in my copy). If you need a copy of the manual, you can download one at
http://www.home-electronics.net/ge/pc/IB/29875GE1_IB.pdf
Sep 23, 2011 | GE Cordless Phone & Answering Machine...
How do I set the time and date on a GE phone Model # 29490ge-2
"REMINDER: The time and date are programmed automatically when the first Caller ID record is successfully received after set up."
The quote is from the fifth column of the first page of the manual at
http://www.home-electronics.net/ge/pc/IB/29490GE2_IB.pdf
Sep 01, 2011 | GE 29490GE2 Corded Phone
Ge eterna series - installed above oven. microwave stops working and display instructs to set time and date, then after setting time and date and starting oven again it stops after a few seconds and asks...
The magnetron draws a lot of power and the mains may be dipping beneath an acceptable level, causing the panel to reset.
Check the supply cable size and any connections.
Jan 23, 2011 | GE Microwave Ovens
Setting the date & time
You can download the manual at
Jul 10, 2010 | GE 29875GC1 Digital Answering Machine
How do you set the date and time
Apr 02, 2010 | GE 29875GE Digital Answering Machine
Ge model 27909 answering machine gives wrong time on playback
I found it on the manual, it was in programming section!
Date/Time
NOTE: Time set on handset will be transferred to the base unit automatically.
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu and use cid/vol (3or4) button to scroll to Date/Time.
3. Press menu button to enter the menu. Year 2006 shows in the display.
4. Use the touch-tone pad to enter the last two digits of the current year (range: 00 to 99).
5. Press menu button to save the year setting and proceed to date setting.
6. Date 01/01 shows in the display. Use the touch-tone pad to enter two digits for current month and day respectively.
7. Press menu button to save the month/date setting and proceed to time setting.
8. Time 12:01p shows in the display. Use the touch-tone pad to enter four digits for current time and use cid/vol (3or4) button to toggle between "p" (pm) and "a" (am).
9. Press menu button to save the setting. Saved shows in the display.
NOTE: If you subscribe to Caller ID service, the current date/time is set automatically when you receive your first CID record and will override manually set date/time.
Jan 08, 2009 | GE Lands Phones
GE Base 25942 Flashes Cl
You can download the phone manual here:
http://www.home-electronics.net/ge/pc/IB/25942GE2_IB.pdf
It explains the time/date setting (done from the handset).
Jan 04, 2009 | GE 25942GE2 Cordless Phone System
Setting time and date
here is the link to the user manual.instructions to do that should be in there.
User Manual
Oct 17, 2008 | GE 25952EE1 Cordless Phone
GE 60-983 ATP1000 Alphanumeric Touchpad Logo
95 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
