Question about Whirlpool Gold GI0FSAXVY 19.8 cu. ft. French Door Refrigerator with Slide-Out SpillGuard Glass Shelves, Adjustable Gallon Door Bins, Adaptive Defrost System, Accu-Chill Temperature System, External Ice/Water Dispenser and Electronic Controls: Monochromatic Sta
Ice maker line in whirlpool GI0SAXVY refrigerator
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
kweaver1
  • 3 Answers
SOURCE: water line to ice maker frozen
Check to make sure that the damper between the freezer and fridge is not broken or frozen open. Make sure that you shut off the water supply to the fridge until you get this fixed because the line could crack and then you could flood the house.
Posted on Jan 20, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
aasc
  • 1606 Answers
SOURCE: whirlpool refrigerator ice despenser
To All With This Same Problem ,
Remove the top freezer door hinge cover ( 1 screw holding it on ) , and disconnect the plug there . This will disconnect the power to the door dispensor .
Using a butter knife or small screwdriver , insert it in the bottom of the dispensor cover between the grill and the cover .
Push down and in wards , to force the bottom of the cover outward , being careful not to break the 2 or 3 built on plastic clips on the cover .
After the lower portion has been disconnected , lift the cover up to disconnect the top clips and then remove the plug on the cover .
The white piece on the dispensor now visible , is the bracket control .
The switch on the right side , is for water , the switch on the left side , is for ice . Usually , the ice switch , has a broken " spear " , which holds the switch in place . The whole bracket control , pt # 2180226 , will have to be replaced . Only 2 or 4 screws hold it on .
This part is easily replaceable by the consumer .
Just be careful when installing the switch , not to break the new " spears " and be sure to reinstall the plastic " spacers " in the same spot on the new bracket .
When reinstalling the dispensor cover , slip the top on first , and just lightly " pop " the bottom back in place .
Posted on Oct 09, 2009
SOURCE: Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
Posted on Jun 05, 2010
I have a whirlpool fridge with the freezer on top. The ice maker is not making ice quickly. How can I fix this?
Good day,
As a general rule refrigerator ice makers don't really make ice cubes very fast.
Things that could increase the production are.
1. Set the freezer to a colder setting. That control is usually on a whirlpool is called an air control.
2. Setting the refrigerator control colder, while also help since setting it to a colder setting will actually make both compartments colder.
3. The ice maker produces ice when it's internal thermostat reaches approx. 14 degrees.
You have no control of that function.
4. If the cubes are on the small side, the water valve on the back bottom of the machine may need to be replaced.
5. Along that same line, the water supply line from the house and it's fittings could be starting to restrict, not supplying enough water pressure.
The line, unless plastic, and the valve would need either be removed and cleaned or replaced with new.
Dec 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
TURN OFF FREEZER HALF TO DEFROST WATER LINE THAT FEED ICE MAKER
Just turn the refrigerator off inside on control panel. Then get a hair dryer and melt the ice away from the tube taking care not to get plastic too hot. Sea Breeze
May 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not making ice
i had same thing happen the line going to the ice maker was froze i too everything out of frezzer and let line unthaw for about an hour now works fine
Apr 28, 2009 | Whirlpool GD2SHGX Refrigerator
Ice maker water line appears to be frozen on gd5sha. ice maker won't function.
thaw the whole refrigerator for a whole day to thaw the ice inside the water line. it will reset also the timing of the ice maker.
Jul 05, 2008 | Whirlpool Refrigerators
Whirlpool refrigerator waterline is clogged
go to the back of the ref, trace the incoming water line, it should go to a two pc solenoid valve. if you press water at the front, one of the solenoid should click. the one that didn't click is the one for the ice maker. see if you can detach the water line that comes out of that solenoid. that line goes to the ice maker. you can flush it with water to clean it. be aware that a lot of water would be overflowing inside the ice maker . i hope i was able to solve your problem..
Feb 06, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker wont make ice
It is quite possible that the water line which feeds the ice maker is frozen. Whirlpool manufactures a "REPLACEMENT" water line that solves this problem. Fortunatly our problem occured while the refrigerator was still under warranty. I would suggest that anyone owning a Whirlpool product purchase the longest extended warranty available! They USED to manufacture a quality product. But I guess they just don't care about the consumer any longer. It is all about money!!
May 16, 2007 | Whirlpool GD2SHGX Refrigerator
Whirlpool Gold GI0FSAXVY 19.8 cu. ft. French Door Refrigerator with Slide-Out SpillGuard Glass Shelves, Adjustable Gallon Door Bins, Adaptive Defrost System, Accu-Chill Temperature System, External Ice/Water Dispenser and Electronic Controls: Monochromatic Sta Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
