Question about Cuisinart Supreme Grind DBM-8 Electric Burr Grinder
Stopped grinding no longer grinds the beans
SOURCE: Coffee will no longer grind.
ONE COMMON PROBLEM IN THIS MACHINES, SINCE THEY ARE MADE IN CHINA, THE QUALITY OF THE BEARINGS DETERIORATE IN ABOUT EXACTLY ONE YEAR. AND THE GRINDER NO LONGER WORKS. THE BEARING BUSHING ITS MADE OF BRASS, AND THE LOAD OF THE COFFEE BEANS OVER KILL THE BEARING. ITS A RIP-OFF....
Posted on Aug 24, 2007
eagle338
  • 4889 Answers
SOURCE: Stopped working
Not to worry. This grinder can be filled till the top. This will be covered under warranty. Just give a call to Cuisinart and they will fix it for you
Posted on Feb 23, 2008
  • 234 Answers
SOURCE: beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Posted on Mar 15, 2009
SOURCE: Cuisinart DBM-8 Grinder Automatic Burr Mill stopped grinding
perhaps remove the hopper (top) and inspect to see if a buildup of very fine compacted grounds as accumulated. knock the stuff loose.
Posted on Mar 28, 2009
co7196
  • 3433 Answers
SOURCE: I have a cuisinart with brew and grind coffee
Stuck? how stuck can it be when it is supposed to be removable? Try turn ing it,
Posted on Sep 24, 2009
I have a saeco royal my machine is grinding beans but will not stop
Your question is not right.
Grinder stops on its own in 16 to 18 seconds (times out).
It may not be grinding beans an spinning free because the beans are not feeding.
You may have used oily beans or set the grind fineness at very fine powder like. This powder like fineness also clogs the grinder..
You need to clean the grinding chamber and the ground coffee outlet.
Dec 19, 2016 | Saeco Coffee Makers & Espresso Machines
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Oct 18, 2014 | Coffee Makers & Espresso Machines
My Gaggia Unica won't grind the coffee beans, it just whirs and stops making the drink
More than likely the machine is stuffed with coffee grind. Need to take it apart and clean it. See https://www.youtube.com/watch?v=JQbP2v8C-sA
Sep 20, 2014 | Gaggia Unica Bean To Cup Coffee Machine
Why aren't the beans being ground?
try pushing the beans into the grind mechanism while it is grinding or turning the grinder knob but only when grinding, or try different beans
Jun 10, 2014 | Saeco Incanto Classic Espresso Machine
My Solis Maestro takes a long time to grind and no longer grinds for espresso. How do you remove the burrs to clean them? Should they be replaces?
HI
Yes the burrs will wear out. They can be replaced. To remove the outer burr. Twist the bean hopper counterclockwise until it stops. Lift the bean hopper out. There is a cream colored ring with 2 tabs that will lift out holding the outer burr. To get the inner cone burr out is a little more difficult. We use a vice grip and grab the burr, and lock the pliers to it. Then with a quick movement clockwise on the pliers, you loosen it. Then clockwise unscrew the burr. When you install the new burr, it truns on counter clockwise until it stops. Insert the new outer burr. Push down so the tabs will lock in. Install the bean hopper into the correct slots ( 1 large tab and 1 small tab). Twist clockwise to turn on and test. Remember it must be grinding to turn to a finer grind but can be turned to a coarser grind any time.
Jan 24, 2011 | Solis Maestro Electric Burr Grinder
My cuisinart cbm-18 does not grind at below a 10 setting?
Hello, and thanks for using FixYa.
I'm guessing the problem is that the grinders blades, or the parts that do the grinding have become somewhat dull, (opposite from Sharp.) and no longer can get to the beans like it used to.
Cleaning the machine properly might improve its performance.
CLEANING/MAINTENANCE INSTRUCTIONS
1. Be sure plug has been removed from outlet.
2. Beans can be removed from the hopper by lifting off the lid and pouring excess beans out. Hold down the Manual button to cleanout any remaining beans.
3. The bean hopper, bean hopper lid, grind chamber, and grind chamber lid can be washed by hand with hot, soapy water or placed in the top shelf of a dishwasher. Dry thoroughly.
a. Remove the bean hopper by rotating counter-clockwise bringing the selector past grind setting 18, align the arrows and lift up. Make sure the hopper is empty.
b. Remove grind chamber by pulling toward you.
4. Remove the burr grinder, once the bean hopper has been removed, by grasping the metal handle and lifting up. Use the brush to remove grinds or wash by hand. Replace the burr grinder onto the unit and rotate until the piece is fully inserted. Push handle down and replace hopper.
NOTE: The hopper will not attach to the unit if the grinder has not been fully inserted.
5. Wipe body of grinder with a damp cloth.
6. Any other servicing or maintenance should be performed by an authorized service representative.
WARNING: NEvER ImmERSE UNIT IN WATER
Oct 14, 2010 | Cuisinart CBM18 Electric Grinder
What is the proper number setting for the grinder
There isn't one, because your grind depends on the bean you are using, the temperature and so on. The best thing you can do is clear the burr chamber of beans, then turn grinder clockwise until you can no longer turn the brass fitting in the middle, then turn counter-clockwise to about 4 numbers that will give you a nice starting point to setting your grind.
Feb 18, 2010 | Nuova Simonelli MDX Electric Grinder
Blade turns slowly and will not grind.
1. This fixes almost all the "beans will not feed or beans will not grind" problems unless you need a factory part for repair.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind.
Nov 25, 2009 | Cuisinart Coffee Makers & Espresso...
I bought new green coffee beans recently, roasted it myself and wanted to use it in the machine but the grinder gets stuck and won't turn. The new beans are harder and smaller than the type I used to have....
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Oct 21, 2009 | Gaggia Paros Espresso Machine
Cuisinart Supreme Grind DBM-8 Electric Burr Grinder Logo
107 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
