Question about Yamaha RX-V995 Receiver
How do you connect a Nakamichi surround sound system to my Phillips tv model 42PF7220A/37
    Scholar:
    New Friend:
  • 54 Answers
I'm confused. The message header shows a problem with a Yamaha RX-V995 receiver.
As for connecting a Nakamichi (or any surround system) to a TV - the only connection would be the Monitor output (video connection) to an appropriate video input of your TV.
If it is a Nakamichi, it is a little older and probly predates the invention of HDMI cables. My guess is you will either use the S video output or Composite video output to the TV's input with similar connections.
This allows you to route whatever video sources you have connected to the Nakamichi to the TV.
Posted on May 11, 2014
How do i connect my pc to my phillips home theatre system through an hdmi cable
The best way is to connect your laptop to a spare HDMI input on your TV first, then use the AUX OUT from your TV to the AUX IN1 of the Phillips Home theatre system using a standard RCA cable.
The only catch with this is that you will have stereo analog audio, NOT digital surround. However, by pressing the "SURROUND" button of your Phillips HTS remote you can switch the audio output to multi-channel surround, stereo or party mode.
What is the model number of the TV you are using?
Oct 23, 2012 | Philips HTS-3565 Theater System
Vertical Line on Phillips 42PF7320A/37
Hold down the cursor button towards the green line, it's really that easy...
Mar 07, 2010 | Philips 42PF7220A 42 in. Plasma Television
Red lines on plasma screen.
you may want to check out your buffers.
for cheap buffers check out hssparts.com
thank you
Dec 11, 2009 | Philips 42PF7220A 42 in. Plasma Television
I have a phillips 42pf7220a/37 and 7 blink led
The Ymain Board is out if you have the back of the tv exposed disconnect the ymain board and then plug in the tv set and turn it on. the light should remain green and no longer flash. If this happens the Y main and upper and lower buffer boards should be replaced
Jun 15, 2009 | Philips Televison & Video
No audio from cable through surround sound
you have to go to the setup for the TV audio and change it to audio out, not speakers.
May 07, 2009 | Philips Televison & Video
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
Vertical lines through the right side of the screen
Sorry sounds like you have a bad panel Try changing picture format if the lines don't dissappear or change bad panel
Apr 17, 2008 | Philips 42PF7220A 42 in. Plasma Television
Phillips TV- Plasma Model #42PF7220A/37
A tech will need to come out. When the tech do come out have him unplug the Y main and see if the led goes solid greem if it does have them replace the Ymain and the Y upper/lower boards. Most likely that will be the problem.
Feb 29, 2008 | Philips 42PF9630A 42 in. Plasma Television
No sound when using dish or regular tv
This may be old news but just in case ...
Typically you need to consider the surround system as the central point for sound distribution (and in newer receivers, the distribution point for video signal as well). So you need to think of your TV and Satellite as sound sources and connect them to the IN side of your surround sound system. From the back of your TV then, look for the Audio OUT (commonly Red for right and White (or black) for Left. Connect these to the IN on the back of the surround system. Likewise for your satellite box. Then make sure you select the appropriate source on the surround system. If the system supports the video signal, you can route that as well. Beware that you'll need some sort of simulation (provided by the Phillips unit) to upconvert stereo to surround ... check the manual online. If you post model numbers for the Phillips and satellite units, we might be able to direct you more specifically (provided we can find manuals online)
Feb 24, 2008 | Audio Players & Recorders
Yamaha RX-V995 Receiver Logo
104 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
