How to reset "cassette failure" error message on the Kyocera FS6530 mfp photocopy machine? Please Help!
Firstly I thought it to be the cassette lift motor but upon testing it I found it to be working fine. Later I traced it to the engine board with connector pin yc1 9 grounding (not suppose to be ) according to electrical sketch. Can it be reset or should I purchase new engine board?
pastorm
  • 98 Answers
SOURCE: Lexmark X422- error: "942 service scanner failure
According to Lexmark,one or both of the CCD lamps in the scanner have failed, or the CCD cable is loose or bad.
Posted on Jul 06, 2007
SOURCE: My Dell 962 Photo Printer gives error when trying to photocopy.
The issue you are experiencing with your printer i.e error 2200 is related to "Scan Carrier Stall error" I believe the steps mentioned below will fix the issue,
1. Unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
5. Plug the power cord back into the wall socket.
  1. Go to www.support.dell.com.
  2. Click on Drivers & Downloads.
  3. Under Option 2: Select a Product as printers .
  4. Locate the printer(s) 962 printer and click Go.
  5. Select an Operating System that is installed in your computer then choose downloads and look for Firmware.
  6. Download and install the firmware, then restart the computer and the printer, however please make sure that you do not restart your computer and the printer when the download and the installation is in progress.
I would appreciate if you could let me know if you have refilled the black cartridge, cause Dell printer often give error messages if the cartridges are refilled and not replaced with an original Dell one. If you have done so please replace the cartridge with a genuine Dell cartridge.
Regards
Malik Khan
Posted on Jan 26, 2008
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
M2Tech1
  • 313 Answers
SOURCE: Sharp AR 163 display L6 error
The error is for the polygon motor if you have done the test for the motor and it doesnt work I think thereis the answer because they spin so fast the motors will eventually go if it had been a little noisy p[rior to this then it has a read or seize error if you know how to take it out youcan manually gently spin it to see if it is stuck just make sure you use a clean dry cloth to cover it prior to turn as you might mark the mirrors.. Good Luck A
Posted on Jul 01, 2009
  • 22 Answers
SOURCE: Kyocera FS2000-D error message 7410:0017578
The drum is not pushed fully into the machine.Open the waste toner container door and gently push all units into the printer.Then turn off the printer at the wall.When you power back up the printer should be back to normal.
Posted on Nov 23, 2009
How to rest the error 'check for apporiate paper' fault in kyocera fs6525 mfp copier
load paper its asking for or make sure paper cassette is set for correct size check the wheel on left side of cassette is set for correct size usually LT
Jan 03, 2017 | Kyocera Office Equipment & Supplies
I have a Kyocera FS6530MFP Printer and gives a ' error in cassette 1 ' message. Any clues?
Could be the rollers in that cassette are worn and causing a delay jam (Not picking the next sheet up) Try cleaning them.
Aug 13, 2014 | Kyocera Office Equipment & Supplies
I have a Kyocera FS 6530MFP and when its in operation (during photocopying or printing), multicopies, it suddenly pops up an error on the display with the message ' cassette error ' , and abruptly sto
The cassettes have little motors on them that lift the paper up to the rollers when it's closed. Make sure there isnt a bind on the plate that lifts the paper up. If there isn't you might need a lift motor replaced. This is a pretty common issue.
www.equipmybiz.com Skelton Business Equipment Houston Copiers
Aug 05, 2014 | Kyocera Office Equipment & Supplies
Cassette failure
sometimes the lifting carriage not position than comes cassette failure.Please check the cassette box
May 29, 2014 | Kyocera FS-6525MFP
Kyocera fs-1028 mfp machine failure call service c7990
its a waste toner error put a new one in if the error persist check all the sensors you may also have to replace the drum
May 21, 2014 | Kyocera Office Equipment & Supplies
Repair kyocera fs-1028 mfp machine failure call service c7990
developer unit fitted correctly or failure of developer unit .
May 21, 2014 | Kyocera Mita Kyocera FS-1028 MFP Laser...
347 people viewed this question
k24674
jasbo
jasbo
