Question about Nordic Track Incline Trainer X9i Interactive
Treadmill is dead.
Some children were playing with it, without the key in it, and now it does not work at all. I checked the reset button on the side but that is set correctly. I can tell the treadmill is getting electricity, because I can make out a faint red LED light near the power supply. Is there an internal reset?
    New Friend:
Have you tried turning the power off, unplugging the system . Wait 15 minutes then plug it in and power up.
Posted on May 07, 2014
bwinton
  • 83 Answers
SOURCE: Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
Posted on Apr 30, 2010
SOURCE: Buttons doesn't work...
you more than likely need a new keypad
www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
  • 103 Answers
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ swflafitnessrepair@yahoo.com I will send this to you.
Posted on Nov 13, 2009
  • 103 Answers
SOURCE: NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
Posted on Dec 16, 2009
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
Mohamed1324
reset the machine use the small button to the side of power button and proceed according. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 02, 2013 | Exercise & Fitness
Does anybody know what a bar that looks like its loading on the bottom of the screen ans nothing works means on my x7i?
Reset the machine with the small button to the side of the power button, and disconnect the machine power cord by 2 minute and toucht the small swithc with the eraser pencil make click.
Now try again. However if the problem persist try this:
    • 3
    • 4
    • 2
God bless you
Nov 29, 2013 | Nordic Track Incline Trainer X7i...
Why is facebook not working
You must reset the treadmill, and see if you have Internet and if your router is working o.k
God bless you
Instructions 1.
    • 1
    • 3
    • 4
    • 2
Nov 13, 2013 | Exercise & Fitness
My facebook, firefox. youtube all are not loading correctly. the script is on the left side of page with nothing in middle. Has little links and blocks all crowded to gether and everything is messed up....
RESET THE machine, follow this steps and fix it. God bless you
      • 3
      • 4
      • 2
    Oct 24, 2013 | Exercise & Fitness
    Pacemaster gold elite giving error code 133. Checked all connections so far and continuity through wire connecting top and bottom boards. No luck
    please reset the treadmill, follow this steps and fix it. God bless you
      • 1
      • 3
      • 4
      • 2
    Oct 22, 2013 | Exercise & Fitness
    Rebok i run RE14301, plain blue screen. It was working until my son played with all of the buttons! We have tried turning it on and off and pressing the reset button but this does not seem to have worked
    Instructions 1.
      • 1
      • 3
      • 4
      • 2
    Oct 15, 2013 | Exercise & Fitness
    Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
    1.
      • 1
      • 3
      • 4
      • 2
    Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
    Proform 550xp Treadmill in continuous incline/decline mode!!!
    i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
    1. plug in and turn on treadmill, keep red key out
    2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
    3. after red key is inserted, let go of both buttons
    **CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
    4. press stop button once
    5. press speed up button until it reads 85 (see what i mean?!)
    6. press stop button once
    7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
    Dec 30, 2009 | Exercise & Fitness
    Pro-Form Sport 1000 treadmill does not stop inclining
    Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
    Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
    Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
    Apr 27, 2009 | Proform Sport 1000 Folding Treadmill...
    Nordic Track Incline Trainer X9i Interactive Logo
    260 people viewed this question
    Top Nordic Track Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Ross Metcalfe
    Ross Metcalfe
     Atlanta Fitness
    Atlanta Fitness
    Level 1 Expert
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
