Question about Kolpak WARRANTY-2HP 5 Year Walk-In Freezer Compressor Warranty
Compressor runs non stop - Kolpak WARRANTY-2HP 5 Year Walk-In Freezer Compressor Warranty
If the freezer isn't getting cold (or cold enough), it is probably out of refrigerant (or very low). It should be checked for leaks.
Posted on May 07, 2014
The compressor of my split a/c stops working but will pick again after some time
If your A/c is non-inverter type, then its normal.
another cause of stopping compressors are due to high amperes comming in to the compressor. (power surge or high ampere)
have your unit cleaned first, then check the amperes from your compressor using a clamp ameter.
another cause is the starting assist (a small box-like thing beside the starting capacitor). this prevents your compressor from running even if it has to. you can by-pass that starting assist thing.
Jan 09, 2015 | Heating & Cooling
Motor will not rotate when restarting, it powers up but seems to be locked
Since you have not listed the make or model compressor, I'll try to answer your question........ Is the compressor wired up correctley?
If the compressor is out of phase, it won't be able to perform at its peak level. Most 60-80 gallon compressores require at least 220-240 volts to operate creectly. Make sur all your presure switches are calibrated to the correct unit and the compressor should run wirtth no problems. Hope this helps.......................
Mar 17, 2014 | Air Tools & Compressors
When the button that control the air flow in my aveo 2005 is on defrost or defrost and floor combination the A/C compressor run non-stop even if the a/c button is not on. How do I fix this ??? Thank...
Its normal for the compressor to run any time the control is in defrost mode.
The compressor runs to dry the air blowing onto the windshield.
Check your owners manual for details.
Sep 02, 2013 | 2005 Chevrolet Aveo
Does not cool either side fan runs and compressor seems to run
2 possible issues. If compressor running, but not cooling - No freon in the system, or compressor valves are bad, not compressing freon. Ideal would be to check pressures on the system while its running. Could be some kind of restriction. most common problem i would guess low freon level. Here are 2 of my videos i have on my channel. first is leak found at evaporator coils. i used leak dye to find it, second video is replacing compressor, but had compressor completely down. installed 3-n-1 hard start kit, but compressor did not come on, so replaced compressor with filter drier. Hope this will give you an idea what to do next.
Aug 19, 2011 | Maytag MZD2766GES Side by Side...
My 1 hp. 12 gal. air compressor is not building air pressure the motor runs the pressure won't go above 20 lb.
It could be that the input air filter is badly clogged. I might more likely be that the Non-return valve on the air tank input is not sealing properly and not allowing the tank to build up pressure. This valve is at the end of the main pipe runs between the compressor and tank. It could also mean (less likely) that the poppet valves inside the compressor cylinder head are not sealing properly. Other faults could be worn rings on the compressor pistons or a bad seal between the compressor cylinder head and block.
To check the Non return valve allow compressor to build up some pressure and then loosen union nut on Non return valve. There should be some air released at first but should stop if valve is ok. If leaking remove valve and check for dirt and clean. If valve still leaks replacement is the only fix.
Sep 14, 2010 | Craftsman Air Tools & Compressors
Compressor running non-stop
Temperature setting/changes takes more than 2 hours to stabilize.If still running non stop after 24 hours use a digital thermometer to check the internal temp of refrigerator. If not cold enough it will not open the thermometer and turn off the compressor. Meanwhile, a 20 minute defrost cycle is about right.
Sep 23, 2017 | Amana ARB220ZCS Bottom Freezer...
Beer keeps freezing....Compressor/fan runs non-stop...
the thermostat sounds as though it is faulty if it is frosting the entire eveaporator and not cutting out
Sep 22, 2009 | Refrigerators
Non cooling
If the running capacitor is bad the compressor will draw above average amperage and the overload protector will cycle the compressor off. You should take it in for service.
May 08, 2008 | LG GL6000ER Air Conditioner
Everything in frig is frozen and it won't turn off.
If the compressor is running non-stop then the temp. control is not telling it that it's "cold enough". If the compressor isn't running non-stop then you should look at the air damper (little window) that lets the freezer air into the refer compartment... if it's stuck open then you will always get cold air pushed into the fridge eventually becoming a freezer in itself.
Jan 17, 2007 | Kenmore 74844 / 74842 Top Freezer...
Refrigerators Logo
26 people viewed this question
Top Kolpak Refrigerators Experts
jasbo
jasbo
Marat Brikov
Al Schrader
Al Schrader
Are you a Kolpak Refrigerator Expert? Answer questions, earn points and help others
