Question about Scotts EasyGreen Rotary Spreader
The plastic hopper sliding door broke off. Don't suppose there are any replacement parts. are there??
Looks to me like the 2 rivets that hold the sliding door mechanism to the hopper would have to be drilled out if there was a replacement part.
    Top Expert:
  • 3,698 Answers
Www.scotts.com/.../scotts-spreader-part.
Posted on Jul 06, 2014
How do I remove the front driver side power window switch on a 2008 Buick Enclave
Armrest Door Pull
Remove Rubber Cover
Remove 10mm *****
The first step is to pry out the plastic trim plate behind the chrome colored door release handle using a small flathead screwdriver.Then remove the 10mm ***** behind the plate using a ratcheting wrench with an extension bar attached.
Next pry out the rubber cover at the bottom of the door pull located in the center of the arm rest. Use a Torx T-25 (star bit) screwdriver to remove the two screws.
Remove Torx T25 Screws
2 T-25 Torx & 1 10mm *****
Pry Up Arm Rest Panel
Use a flathead screwdriver to pry up the rear of the plastic arm rest panel. There is a plastic hook at the front of the panel, so only pry it up from the rear edge.
Lift Rear End First
Plastic Hook At Front of Panel
Power Window Connector
After you lift out the arm rest panel, you'll need to disconnect the power connector for the window and door lock switches.
Push Connector Release Tab
Power Connector Unplugged
Two More T25 Screws
Push on the release tab with a flathead screwdriver and pull out the power window / door lock connector.Use a Torx T25 screwdriver to remove the two screws located below the arm rest panel.
Remove T25 Torx Screws
Outer Edge of Panel
Push In Center of Fastener
Then move to the outer edge of the door panel and locate the two small round fasteners. Use a small screwdriver to pop in the center pins of the two fasteners.
Pull Out Plastic Rivet
Black Plastic Fastener Removed
Remove Lower Fastener
Pull out the two plastic rivet fasteners and set them aside in a safe place.
Pull Panel Away From Door
White Plastic Pop Rivets
Pull Off Sail Panel
Grab the door pull in the arm rest and tug it towards yourself to disengage the pop rivet friction fasteners that hold the panel to the door frame.Move to the top corner of the door panel and pry off the triangular "sail" panel. On some vehicles, the sail panel contains the tweeter speaker.
Lift Panel Off Door Lock
Pull Out Door Pull Cable
Lift the door panel off the door lock button and tilt the top of it out towards yourself.Use a pair of needle nose pliers to gently lift the metal ball at the end of the door opener cable out of the mechanism.
Disconnect the door cable from the back side of the door panel.
Door Pull Cable Removed
Disconnect Power Mirror
Then disconnect the power connector for the side view mirror by lifting up on the release tab. Slide the power connector off the plastic anchor on the metal door frame.
Slide Connector Off Anchor
Unlock Connector
Connector Detached
Look behind the door panel and locate the large wire connector with the pink lever lock. Swing the lever open to unlock the connector and separate it from the socket.
Door Panel Removed
Power Window Motor
10mm Bolts
Now the door panel can be completely removed by lifting it up and off the door frame.To replace the power window motor, remove the 10mm bolts.
Stock OEM Door Speaker
Remove 7mm *****
The stock "OEM" speaker is held in place by a single 7 mm *****. Remove it with a socket and ratcheting wrench.
Pry Off OEM Speaker
Speaker Removed
Disconnect Power Plug
If the speaker is stuck to the door frame, gently pry it off with a small flathead screwdriver.Disconnect the speaker's power plug by pressing the release tab with the small flathead screwdriver.
Fits 5.25", 6.5", 6.75"
Re-installing Door Panel
According to the Crutchfield website, the 2008 to 2012 Chevrolet Malibu's front door speakers can be replaced withaftermarket speakers in the following sizes: 5 1/4", 6 1/2" or 6 3/4" speakers with the use of a bracket.If you'd like to reduce road noise, make your car quieter and also improve the sound from your speakers, I'd recommend applying some Dynamat Sound Deadener on to the metal door frame.
Re-Attach To Anchor
Plug In Power Side View Mirror
Re-Insert Power Connector
To re-install the door panel, first hold the panel close to the door frame before re-connecting the large wire plug. Swing the pink lever closed to lock it in place.Slide the socket for the power side view mirror back on to its anchor and insert the power plug.
Lock Power Connector
Pink Lever Locked
Re-Insert Door Pull Cable Ball
Insert the metal ball at the end of the door opener cable back in to the door handle mechanism.Slide the black plastic cone part of the cable back into the slot in the door opener assembly.
Door Opener Cable Reinstalled
Hang Door Panel On Frame
Gently lower the door panel down on to the edge of the door frame with the door lock switch through the opening at the top.
Line Up White Plastic Fasteners
Push On Sail Panel
Push Door Panel In Place
Move to the bottom of the door panel and line up the white plastic pop rivet fasteners with the holes in the metal door frame.Push all around the door panel to re-insert the pop rivet fasteners.
Re-attach the sail panel at the top corner of the door frame.
Push Panel Flush Against Frame
Insert Side Edge Fasteners
Insert Larger Piece First
Next move to the side edge of the door panel and first re-insert the larger piece of the two fasteners. Then insert the smaller "pin" piece of the fastener into the middle of the larger piece.
Insert Small "Pin" Piece
Install Lower Edge Fastener
Tighten 2 T25 Torx Screws
Re-Attach Power Connector
Insert Front Hook First
Insert and tighten the two Torx T-25 screws located under the arm rest.Re-attach the power connector to the plastic arm rest panel.
First insert the hook at the front of the arm rest panel and then snap the rear end in place.
Pop Arm Rest Panel In Place
Tighten 2 T25 Screws
Replace Rubber Cover
Insert and tighten the two T25 Torx screws into the door pull cup. Then replace the rubber cover over the two screws.
Tighten 10mm Door Handle *****
Replace Door Handle Trim Plate
Malibu Door Panel Replaced
Replace the 10mm ***** that goes above and behind the door opener handle and tighten it. Pop in the plastic trim plate behind the door handle.
Apr 10, 2016 | Buick Cars & Trucks
My window regulator is broke. Trying to fix it but the window is down. How can I get the window up
if you have the door panel off, then you will have to detach the mechanism from both the door and glass, then gently wrestle it out. once you detach the glass, it should easily slide up. a trick I use is a couple of lengths of duct tape over the top of the door to hold the glass while I finish with the mechanism. patience is key.
Mar 08, 2013 | 2003 GMC Sierra 1500
Window regulator replacement in 1988 olds cutlass calais (non-motor). How do I replace the window regualtor?
1985-1998 Oldsmobile Grand Am/Achieva/Calais/Skylark/Somerset
REMOVAL & INSTALLATION
Door Glass and (manual) Regulator
See Figure 1
Fig. 1: Common window attachment
SEE ILLUSTRATION #1 BELOW
1. Remove the door panel.
2. Remove the water deflector from the door.
Be careful not to tear the water deflector when removing it from the door.
The "water deflector" is also known as the "dew wiper"
3. Connect the power window switch/window regulator handle.
4. Lower window to full down position.
CAUTION
Use extreme caution when operating the window with the door panel removed. The window regulator can cause severe personal injury if body parts become entangled in the mechanism.
5. Remove the window run channel.
6. Move window to the half down position.
7. Remove the window retaining nuts.
8. While holding onto the window, lower the regulator to the full down position.
9. Remove the window by sliding it towards the rear and rotating the front of the window upward.
To install:
10. Position the new window in the door.
11. While holding onto window move regulator to half up position.
12. Install the nuts. Roll the window to the full up position.
13. Install the rear run channel.
14. Install the plastic water deflector. If necessary, secure with waterproof adhesive
15. Install the door trim panel.
Window Regulator
See Figures 2 and 3
Fig. 2: Location of the front door window regulator-1995 vehicle shown
SEE ILLUSTRATION #2 BELOW
Fig. 3: Exploded view of the rear door window regulator-1995 vehicle shown.
SEE ILLUSTRATION #3 BELOW
2. Remove the plastic window deflector. Be careful not to tear the deflector when removing it from the door.
3. Remove the door window assembly.
4. Remove the bolts securing the regulator to the door.
5. Remove the nuts securing the upper regulator guide.
6. Using a 1/4 in. drill, drill out the regulator rivets.
7. If equipped with power windows, detach the electrical connector.
8. Remove the regulator through the large access hole in door.
To install.
9. Install the regulator to the door, and attach the electrical connector if equipped with power windows.
10. While holding the regulator to the inner door panel, insert the rivets, and secure them with a rivet tool.
11. Fasten the regulator bolts and upper guide nuts.
12. Install the door glass, and inside door plastic panel.
13. Install the inside door trim panel.
14. Install the plastic water deflector. If necessary, secure with waterproof adhesive.
Fig.1---------------------------------------------------------------------- Fig. 2
Fig. 3
Oct 03, 2011 | 1988 Oldsmobile Calais
How to replace power window regulator 2002 dodge dakota
Purchase replacement part first.
If you need motor only it might come without regulator.
Either way when you have the new part(s)
It will give you an idea of what has to be removed
look for plastic covers (round) or screws and remove them under the covers are screws also remove those.
neer door handle there is always a screw or tab.
on the pull handle (big one) there are 1-2 large screws remove those.
look near mirror area and remove any plastic covers. may be tabbed or screwed in??
usually lifting lightly and looking under the trim with a flashlight will tell you what is holding it.
remove plastic from around handle area.
pry lightly on the bottom and see if you have to lift up or straight out.
either way usually an up and out motion is required at same time.
tabs lift out easily while the push in plastic tabs may be more strong. if they stay in the door remove them later with trim tool. looks like a dandelion puller. then put them back on the door trim whre they came from for later installation.
If door has plastic film pull it away from the door and don't get the black stuff on you. Sticky!
Then find if regulator is bolted in or pop riveted in.
remove bolts or pop rivets and dont pinch your fingers but separate window glass from regulator.
This is the fun part you will have to find a hole to pull it out of. usually there is only one choice. and that is the biggest hole there.
Mar 04, 2011 | 2002 Dodge Dakota Club Cab
How do I replace the drivers side door latch on a 1995 Oldsmobile Ciera? Is there a diagram available? The sliding door lock seems to be a problem removing the facing.
If you slide the door lock slider to the unlock position you can grab a hold of the end of it and pull towards you it's only held on by a clip embedded in the plastic. Once that's removed remove the trim panel behind it to gain access to the door handle assy.. The handle is riveted on to the door skin so you will have to drill out the rivet after that the handle will slide towards the front of the car about 1/2 inch and its free just disconnect the lock rod and install your new handle it sounds like a lot but is actually very easy
Oct 24, 2010 | Oldsmobile Cutlass Ciera Cars & Trucks
The door handle popped when trying to open the door from the inside. i pulled the handle too hard (because the doors were frozen shut). what part may i need to repair the door handle. the handle itself is...
remove the inner door panel and see if you just pulled the linage rod loose from the clip to the door latch if so it is just a plastic clip or it could have a threaded end and you might be able to just reinstall it into the metal clip and adjust it accordingly.Hope that helps.
Dec 26, 2009 | 1995 Oldsmobile Cutlass Ciera
Replacing front headlight bulb . Instructions for
With the hood open, you will see a long flat flexible plastic cover running across the front, above the headlights. It is riveted in with plastic rivets. Hold the outer part of the rivet, and pull up the center part. Then remove the whole rivet. Remove the plastic cover. (When you put it back on, insert the outer part in the hole, then press the center part down into each rivet.)
You will see a sidelamp and headlight assembly. Look down between the sidelamp and headlight, there should be a black plastic clip or latch that holds the side lamp to the headlight. (The clip is down a hole, in the bracket holding the headlight to the body). You will probably need a long screw drive to get down in the hole to release the clip. And maybe a flash light to see down the hole. Put just enough pressure to release the latch, it is plastic, and if you press to hard it could break. Once released the side lamp will pop forward a bit. The sidelamp section can be pulled forward. a bit. However, there is a long plastic part on the Sidelamp Section that slides into a metal hole in the Fender. It will break if you try to pry the sidelamp section out sideways.
Next you will see two top-mounted bolts holding the Headlight Assembly in place which can easily be accessed and removed. Removing the bolts will loosen the entire headlight assembly.
Some instruction say you can remove the headlight and side assembly as a unit. Do not do this! If you try to remove the headlight assembly without detaching the sidelamp you could break either of the lights or the connection assembly.
The Bulb Assembly twists out of the back of the Headlight Assembly, and the bulb can then be replaced. Be careful not to touch the bulb with your hands or with any grease.
Many of the parts are plastic and can break, so do this carefully and patiently. It sounds a little complicated, but once you learn how, the whole job only takes about 20 minutes.
Hope helped. (remember rated this).
Oct 19, 2009 | 2002 Chevrolet Cavalier Coupe
I have a '93 coleman, cedar tent trailer with a broken rear bed. The bed extends through the end of the track and comes off the rail. I'm looking for a diagram, parts list, and repair advice.
I have the same issue. It looks as though the rivets broke off. I have yet to reattach the slide mechanism. Normally the slide mechanism is stopped by a peice of emtal about 1./2 the way down the slide. Either new rivets or some flush head screws might sole your issue.
Oct 19, 2009 | Coleman Sport & Outdoor - Others
Plastic Guide rail on sunroof broke
I just purchased a used yukon xl. Both plastic rails are broken.
Solution: Drill out the blind rivet. Start with 1/8 drill bit and remove the head off. The plastic broken part can now be removed.
Install a blind rivet through the new plastic rail and use the rivet gun to squeeze the rivet in place. Make sure it is the right length.
get a grip gage and determine the right rivet for it.
very easy job.
Jul 01, 2009 | 2003 GMC Yukon XL
Rear window regulator broke
The regulator is attatched to the glass using the rivets through plastic disks. You need to drill them out before the glass can be removed.Save the plastic parts for reassembly.Good Luck
Aug 25, 2008 | 2002 Ford Explorer
Scotts EasyGreen Rotary Spreader Logo
165 people viewed this question
Top Scotts Garden Experts
Scott Campbell
Scott Campbell
Rod Doney
Rod Doney
Are you a Scotts Garden Expert? Answer questions, earn points and help others
