Question about AVG Computers & Internet
Turn off power saving mode - AVG Computers & Internet
  • AVG Master
  • 1,087 Answers
I don't know, but as CNET only gives this program 2 stars out of five, I would get a better one. CCleaner is free and well rated.
Posted on May 07, 2014
Testimonial: "Thanks, Big Steve That has helped me a lot. Hope others use your advice in the future. Cheers Walt"
  • Big Steve
    Big Steve May 08, 2014
    Youre welcome!
  • Big Steve
    You're welcome!
My dell monitor is on power saving mode I am using the monitor with cameras so do not have a pc I cant turn the saving power mode off
Without a PC you have no control over the power saving mode. You can't turn it off without one, that comes right from Dell.
Nov 20, 2016 | Dell Computers & Internet
How do I disable power save mode
Press the Power key > Activate power saving. To deactivate power saving mode, press the Power key > Deactivate power saving.
When activated, the power saving mode turns off some functions automatically. Radio configuration in power saving mode include the cellular radio (it is set to 2G/GSM only mode), the Bluetooth radio (it is turned off) and the Wi-Fi/WLAN radio (scanning for new networks in turned off but existing networks keep functioning). The power saving mode also reduces display power consumption by minimizingscreen brightness and by turning off touch screen feedback and theme effects. In addition the vibra alerts are turned off in a power saving mode. Hope that helps Anomy.
Mar 16, 2015 | Nokia N8
Squelch won't turn off, won't go into power save mode
Power-save mode means the radio is being turned on and off repeatedly, to save power. The radio turns on, & if it hears any signals (i.e., if squelch circuit determines a station is being received), it turns on the speaker; else it turns off again to save power. So, squelch and power-save modes work hand-in-hand, and your problem is squelch circuit is either set too low, or a station is being received by the receiver. Download/look at the owner's manual and adjust the squelch circuit for a higher setting, and it should go into power-save mode again.
Good luck.
Nov 10, 2013 | Cobra LI 7020 WX-EVP Two Way Radio
LAMP KEEP BLOWING OUT. TOSHIBA 65 HM167
I had this same problem with my Mitsubishi it is when you have fast on mode set it pre warms the bulb to much. I turneed it off and now the bulb has lasted much longer Setting the Power-On Mode feature You can select either Power-Saving or Fast mode. If you select Power-Saving mode and you turn off the TV, it can take several seconds for the picture to appear when you turn on the TV again. Power-Saving mode saves more power than Fast mode. See "Specifications" on page 66 for details. If you select Fast mode and the TV is turned off, the TV will stay in Standby mode for several minutes (see Note below). If the TV is turned on from Standby mode, the full picture appears immediately. To set the Power-On Mode feature: 1 Press Y and open the Setup menu. 2 Highlight Power-On Mode and press c. 3 Press b or B to select either Fast or Power-Saving and press T. Note: If Power-On Mode is set to Fast and you turn off the TV, the following will occur for a few minutes: • The screen (lamp) lights dimly; and • The fans continue to run. This is a function of the Power-On Fast Shutdown mode and is not a TV malfunction. If you do not prefer this, set the PowerOn Mode feature to Power-Saving. When the Power-On Mode feature is set to Power-Saving, if you repeatedly turn the TV on and off in a short period of time, the useful service life of the lamp may be shorter than the average useful service life (- page 63).
this is from your manual not my Mitsubishi please rate this answer if you felt it was useful.
Feb 03, 2011 | Toshiba Televison & Video
How do i turn off power save mode using the screen buttons
I don't know if there is a monitor with a function button to turn off the power save mode.
As far as I know the power save mode of the monitor can be found in the display setting of the windows..
Anyway... If you want to turn off the power save mode of the monitor via windows display setting then here is what you need to do:
On control panel, double click display settings.. click the screen saver tab... on the lower portion Press the "power" button.. Select power schemes tab.. Change the settings of" turn the monitor off" to "never"
Click apply and then OK..
Hope it gave you an idea..
Much appreciated if you rate this help...thanks..
Uncheck the box
May 19, 2010 | Dell E173FP 17" LCD Monitor
Every time i turn on my daewo monitor it saying "POWER SAVING MODE' then turn off power auto.
Hi this means your Monitor is in power saving mode , it is trying to save power when you dont use it, Change your power saving settings and it will work perfectly
Thanks
Dec 28, 2009 | Computers & Internet
Can not turn on power save mode
san_pesca, Could be unit is not in power-save-mode, but has CCFL blacklight failure!! But that's only a guess! NO previous history was given or approximate total "ON" hrs. of use unit has seen during it's life!
12fixlouie
Nov 25, 2009 | LG Flatron L1710S 17" LCD Monitor
Power save mode
Your power saving mode is turned on.
try to turn it off, on control panel.
THANK YOU for contacting fixya.com
Oct 18, 2009 | Gateway GT5220 PC Desktop
LG W1941S-PF keeps on going on to power saving mode
Press the menu botton continuasly 35 second,if not then replace the menu botton,if not then go o the menu and disable the power saving mode..
Jul 05, 2009 | Computers & Internet
Power save mode
reboot your comp........enter setup at the laod screen go into power options and turn power save off.......save and exit
Apr 14, 2009 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
Top AVG Computers & Internet Experts
Jeff
Chris Cunningham
Chris Cunningham
Are you an AVG Computer and Internet Expert? Answer questions, earn points and help others
