Question about JVC RX-5000V 5.1 Channels Receiver
What is wrong? My jvc rx-5000v was off for approx 1 month. Upon turning it on I am seeing the overload msg, even if I disconnect all output. Please advise!
    Scholar:
    New Friend:
  • 54 Answers
Hmm, was it plugged into the wall outlet during this time? Could be it was a victim of a power surge or brownout.
Posted on May 11, 2014
3 Suggested Answers
  • 979 Answers
SOURCE: "OVERLOAD" APPEARS
Have a service shop check out your protection IC and related network...accordianman
Posted on Oct 25, 2007
omnishredder
SOURCE: My stereo reciever (a JVC RX 5000V) was dropped onto cement floor, ever since the overload appears and flashes at me. I'm thinking it may be damaged but is there something simple I can do to maybe
give it a trial as you never know until you test
Posted on Mar 30, 2012
When i turn on receiver JVC rx-6032v it says overload
Overload indicates a short in the audio output semiconductors, check speaker wires for shorts, if okay! you will need a professional to assess cost to replace outputs.
Mar 20, 2012 | JVC RX-D402 Receiver
How do you balance sound between two speakers. Where is the balance control? JVC RX5000v
On the front panel ONLY:
1. Press ADJUST so that the MULTI
CURSOR up/down buttons work for
adjusting the sound.
2. Press MULTI CURSOR up/down
repeatedly until "BALANCE"
appears on the display.
3. Press MULTI CURSOR left/right to
adjust the balance.
• Pressing left decreases the right channel
output.
• Pressing right decreases the left channel
output.
please rate my solution.
Jul 04, 2011 | JVC RX-5000V 5.1 Channels Receiver
Hello. I have a JVC RX-6042 and when I play music, DVD's or any other sound, it cuts out, either after 5 seconds or 5 minutes, it always changes. It cuts out faster at higher volumes. A few months ago it...
Generally speaking, an amp protects itself from heat, shorts and overloads. I'm thinking heat.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 03, 2011 | JVC RX-6042 Receiver
JVC RX-7030V - Overload - Protection
the transtistors are mounted to a large heat sink. and yes all 4 main trany's need replaced. you can go to the library and look in sams photofact for the service manual. the part #ers are on the transistors. have fun and good luck again.
Mar 09, 2010 | JVC RX-7030V Receiver
The screen says overload
disconnect all your speakers and if it still does it, the unit is bad. if not, then youve got a bad speaker. connect them 1 at a time til you find it. good luck
Feb 10, 2010 | JVC RX-6008V Receiver
Overload comes on after start up
disconnect all speakers to see if 'overload' goes away.if it goes away then you might have a bad speaker.If OVERLOAD is still there with no speakers connected .Then audio output circuit needs repair in unit..
Jul 30, 2009 | JVC RX-6008V Receiver
My jvc rx-6010v is OVERLOADING?
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. (JVC - and others - say SIX ohms, but 8 is the "standard" you should use.) Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: The internal overload protection system you mention is designed to help prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized JVC service center must do this. Note, though, that if you have attempted to "cheat" the system several times, damage CAN be done that requires servicing.] But, before you take the unit in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 10, 2007 | JVC RX-6010V Receiver
"OVERLOAD" APPEARS
Sep 06, 2006 | JVC RX-554V Receiver
JVC RX-DV5SL
disconnect the output devices and see if it clears. If it does, connect up the disconnected devices up till the reciver overloads again.
Sep 02, 2006 | JVC RX-554V Receiver
JVC RX-5000V 5.1 Channels Receiver Logo
73 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
