I need an owners manual for a Fitness Gear Ultimate Smith Machine II or a diagram of the pulley system
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Posted on Nov 20, 2008
  • 42 Answers
SOURCE: the motor will not spin.....
The typical problems with "the motor will not spin" is a:
1. Lid-switch (very frequent): Will not drain, incomplete cycling, switch ultimately passes power to motor.
2. Belt or coupling (very frequent) - Belt moves when motor spins
3. Timer/control board (rare)
4. Tranmission (rare)
5. Motor (somewhat rare)
How do you know the actual motor is not spinning? Do you mean, the tub not spinning? Do you have a noise as if the motor is spinning?
Posted on Jan 30, 2009
jumptrout51
  • 3361 Answers
SOURCE: Whirpool Ultimate Care II washer - drips
Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
If that does not solve the leak through problem,the water inlet valve will have to be replaced.
Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
http://appliancejunk.com/forums/index.php?topic=5191.0
Posted on Nov 08, 2009
Terry Corrow
  • 10875 Answers
SOURCE: How to assemble fitness gear ultimate smith machine
fitness washer?? never heard of it
Posted on Jun 20, 2015
Healthstream half cage smith press machine
see your instruction manual, if you do not have go and free download www. fitness.manualsonline.com or www.iconservice.com
God bless you
Jun 18, 2012 | Exercise & Fitness
Powertec smith machine w/ lat tower p-rs-lto manual was missing? Need to find it?
Looking for the owner's manual and/or assembly instructions for the Powertec Roller Smith machine.
Thanx!
Feb 08, 2011 | Powertec Smith Machine (bench sold...
Washer will not drain or spin
Hi.
The machine does not spin in consequence of the drain problem. The timer will not advance to spin until the pressure switch detects that the drain part of the cycle is complete.
Common faults causing the problem are drain lines blockage and faulty pressure switch. Sometimes the pressure switch can be unlocked by cleaning the tube attached to the switch or blowing into the tube.
See:My washing machine does not drain.
To find parts and diagrams for your appliance see:Where do I find parts and diagrams?
If you need to contact a qualified technician ring the number listed on the owners manuals or see:How to get in contact with a qualified technician?
Regards.
Ginko.
Jun 10, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Directions to assemble needed!
You May have to Body Solid service for a copy of the assembly manual it looks like the PDF format has gone by by here is their PH #1-800-5563113 Ext 520 or e mail them @ service@bodysolid.com
Jun 10, 2010 | Powerline Smith Machine - Optional Pec Dec...
Whirlpool ultimate care II, Top agitator not working. I got it apart and can see the agitator dog gear not catching, unable to free the gear from the clips. Suggestions?
stand on agitator,pull top section upwards,the agitators are meant to be disassembled this way,sometimes they are stubborn,and you cannot service agitator if agit is still in the machine...
Mar 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
New Problem
remove drain pipe and make sure it is not blocked i had same problem And found money in the elbow of drain pipe blocking it up. when u r trying to turn by hand u are turning gearbox as well and is normally not easy to spin when they stop during a cycle
"If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it."
good luck
a very helpful rating is appreciated for answering ur query....
Aug 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Ultimate Care II toploading washer doesn't empty or spin after ag
Hello, I can help.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Jun 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Need to disassemble Whirlpool Ultimate Care II washer
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LSQ9564J
Click on the model that matches your machine.
The new window will give an assembly diagram of your machine. Clink on the diagrams on the left-hand side for different assemblies.
Mar 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate care II loud squeal
The drive belt may be loose, and slips on the pullys as it goes into higher gear. It may need replacing.
Aug 19, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Top Washing Machines Experts
