Question about Sony STR-DE675 Receiver
Headphone jack on old sony amp silent
My sony amp str de 675 sometimes clicks and looses the center speaker sound. No ive also noticed that the headphone jack has stopped working. Plugging the phones in automatically mutes the speakers ( i hear a click ) but there is no headphone sound anymore. What could be failing?
  • Joey May 13, 2014
    I found the culprits. One is the headphone relay, and the other is the center speaker relay. They seem semi-stuck because if i press down on them slightly or give them a little tap, they spring back into action. I guess i need to change them. Oh the amount of disassembly pain I have in front of me ;)
I have had fuses blow before. Open up the unit after it has been unplugged overnight(this may loose your settings). There are six screws, 2 on each side and 2 in the back top. Check the fuses, I believe there are 3 of them. If the fuse is blown, you can order them online. Hope this helps
Posted on May 07, 2014
  • Joey May 13, 2014
    Both fuses were ok
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Maybe there could be a loose wire inside try taking it apart and searching for any thing loose do you have a warranty on it
  • Joey May 13, 2014
    Loose or bad relays, two of them :)
5 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: RCA RT2760 problem
sounds like you may have blown the internal amplifier circuit.you a handy sort of person?
Posted on Apr 20, 2008
spqr163
  • 37 Answers
SOURCE: Sony center speaker and rear speakers don't work all the time
try using another speaker for the center channel and the left speaker, also watch your ohm load, most of the want a 4 ohm load. try to narrow it down to see if it is the speaker or the amp.
Posted on Mar 13, 2009
micromatikal
  • 2777 Answers
SOURCE: I have been using my
It sounds like the system still thinks the headphones are connected, that is if you are sure the regular speakers are connected correctly. Usually this can be easily reset. Just turn the system off, then unplug it from the power source for at least 5 minutes to ensure all power is drained from all capacitors in the system. Plug it back in and turn it on and attempt to play something.
If it still does not work it is possible the built in amplifier for the speakers has failed, or the headphone jack has faulted out and thinks it is permanently plugged in. You can try plugging back in the wireless speakers and seeing if they still function, then unplug them again to attempt to reset that headphone jack.
Thanks, let me know!
Tim
Posted on Oct 30, 2010
  • 21 Answers
SOURCE: i have a Sony STR-DE945
It's probably your fan.
The system runs hot, as it supplies a lot of power to push your speakers.
The system knows that without a fan, it will overheat. If the fan gets hot, the system will throw its self into safety mode, to keep it from burning its self up.
Have a tech check your fan.
Posted on Nov 19, 2010
The 1/4" headphone jack broke on my Sony STR-DE 485 receiver. How do I replace it and what it the part number?
1-683-763-11 is the p/n for the headphone board. Should be easy to replace. Just unplug the old one, take take the screws out, and put the new one in.
Mar 30, 2013 | Sony STR-DE485 Receiver
Sony STR DE835 receiver - no sound from speakers and headphone jack
The problem is in the audio output semiconductors, they have shorted causing the fuses to blow and it is in auto protect mode to prevent further damage. I recommend a professional to assess.
Mar 10, 2012 | Sony STR-DE835 Receiver
Hello, I have a Sony STR-D85 surround sound system. I need to connect my phone to the system so that my phone's music plays through my surround sound speakers. The front of the console has a headphone...
Headphone jack is an output not input jack. Your going to need a cord to go from your headphone jack(output) of your phone to audio input on your receiver. The cord has a mini stereo plug to the phone and RCA plugs of left and right to your receiver auxiliary input. Good luck..
Jul 15, 2011 | Sony STR-DE485 Receiver
I have a sony str de-475 amplifier and the centre speaker stops working after about a minute. leave amp powered down for a while and it works again but only for about a minute
Try replacing the center speaker with one of the left or right speaker and run it for sometime ( do not connect the center speaker to any other channel ). If the system does not cut off the center speaker connection this way indicates a short in your center speaker.
But with the L/R speaker if the system still stops working you have a hardware problem and will need professional help to fix. 5.1 amps are complicated and difficult to access even for an experienced technician.
Jun 22, 2011 | Sony STR-DE475 Receiver
Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
May 21, 2010 | Sony STR-DE675 Receiver
I have the sony: STR-DE 685. The sound in the
This sounds like a very poor connection. Please make a new splice on speaker and receiver. This should take care of this for you.
Feb 26, 2010 | Sony STR-DE597 Receiver
Sony STR DE 197 Reciever with No Sound
I have the same unit. My best recommendation would be to remove all speaker wiring, and try new wiring with another pr of speakers,since the "outdoor " speakers were rained on. the protect mode that the unit went into sounds like it did because the speaker outputs were shorted due to the rain, so ensure that the speaker output terminals are not shorted and dry...also see if output is still availalable at the headphone jack...if it is, the pre-amp section is still good , in which case the protect mode and no volume output out of the speaker jacks may mean that youve blown the ouput trasnsistor finals.
I hope this helps.
bobbymaximus
Jul 28, 2009 | Sony STR-DE197 Receiver
No sond from speakers but with headphone jack
there is no problem with the amplifier audio,check some resistors or disconections near the spkr terminals.
Oct 21, 2008 | Sony STR-DE605 Receiver
No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Dec 06, 2006 | Sony STR-D665 Receiver
Sony STR-DE675 Receiver Logo
91 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
