Question about Maximatic EPM300 Popcorn Maker
Stripped gear on agitator motor on my Maximatic EPM-300.
I figure I will probably have to replace the motor. Any idea what the part number would be and where to get it. Also the top shrouding is damaged and I would like to replace that also.
  • 17,093 Answers
See if they have parts for that. The website is here: http://www.maxi-matic.com/home.php?cat=12
Posted on May 07, 2014
Testimonial: "Thanks I appreciate the info. I had already gone to their website but no parts available there. I emailed them so hopefully they can help me. Thanks again"
Galaxy popper popcorn machine has a stripped gear in the agitator can I buy just the gear or can I buy gear box model # g8
You will need to buy the entire agitator motor. For a G8 that is part number y8213. You can get it at a Concessions dealer, or from Partstown.com
Apr 11, 2013 | Kitchen Appliances - Others
Does not turn, keeps jumping
I got the same problem,so I disassembled the transmission box and noticed that the smallest cogwheel got stripped,but no one has given me a solution for that,they are machines made in china and neither nostalgia electrics nor any other company in the US sells replacement products.
Mar 07, 2012 | Maximatic Deluxe Popcorn Trolley Popcorn...
Where can I purchase a kettle pot for the Elite EPM 400?
You might try contacting Maximatic directly. They have full contact information as well as a web inquiry form here:
http://www.maxi-matic.com/help.php?section=contactus&mode=update
If you need your manual it can be found here:
http://kitchen.manualsonline.com/manuals/mfg/maximatic/epm400.html?idRes=493611
Trust this will be helpful.
Mar 05, 2012 | Kitchen Appliances - Others
Will not Agitate (Frigidaire GLWS1233AS1) The washer fills and then stops. If I manually change the timer to the end of the cycle it drains and can spin. I saw on older posts that this might be a...
When ya say after filling "the washer stops" does that mean it is not making any sorta sound?? if it is the transmission,agitator block,or evena stripped gear you will hear the motor running yet it will not agaitate and from reading your question i think it says their is no sounds yet instead it fills then just sits their silent,is that so??
If yes their is no sounds it could be in the area of the timer where the problem lies, since it will drain/spin i am exluding the motor, lid switch or belt as the problem.
If it does make sounds yet just wont agitate it could be a stripped agitator block, or stripped gear but,the belt would be ok since it spins
GENE
Oct 25, 2011 | Washing Machines
Our Whirlpool WTW5550sq0 does not agitate any more. Initially it sounded like there were a few gear cogs that were stripped, but it still agitated (mostly). Now no more stripped gear sound, but no more...
Hello there:
Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley. Transmission The transmission could have either of these problems: Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all. The transmission may have a worn or broken gear, or some other internal problem. If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it. Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Sep 26, 2010 | Whirlpool WTW5550S Top Load Washer
Elite Cuisine EPM 400 popcorn machine
Maximatic Deluxe Popcorn Trolley Elite Cuisine EPM 400 popcorn machine burner is burnt out. where can i find a replacement pot?
Jul 23, 2009 | Maximatic Deluxe Popcorn Trolley Popcorn...
Whirlpool ultimate care II super capacity plus ser.# LSQ8243HQO The top half of adjitator is not turning at all. Handiman1125@aol.com
If the bottom half of the agitator is turning and the spin cycle works, then the motor coupling is good.
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way). If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
The part number is 80040.
If it there is no agitation or spin, replace the motor coupling.
The part number is 285753A
Mar 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 80 series top loading washer won't agitate and is noisy
Sounds like u may have broken the coupler gear between the motor and transmission... the replaced the belt with these gears on this model... But should go fill & pumb water out and NOT spin Or agitate... IF these gears or broke or stripped... heavy loads like u  said would do this... recheck and see if wash will pumb water out But will NOT agitate or spin.. IF so the above is your problem  and is Not to hard to repair  or much money
Below is a pic with the motor remove the white piece in the middle is 1/2 of the gear system with a rubber piece in the middle (not there)  and another like gear on the motor
sounds like these gears may be broken or stripped on your washer
Oct 27, 2007 | Kenmore 24032\24036 Top Load Washer
Maximatic EPM300 Popcorn Maker Logo
108 people viewed this question
Top Maximatic Kitchen Appliances - Others Experts
George Merkley
George Merkley
raysaw
Irene Tulloch
Are you a Maximatic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
