Question about Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2
Why won't craftman cultivator tines won't turn
Tines on tiller
-Check the locking bolt that hold the tine shaft to the main shaft. Possibly it's broken. If so replace new bolt. you should be good to go again.
Good Luck
mai
May 24, 2014 | Craftsman 17 In. Dual Rear Tine Tiller
Tines
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
May 20, 2013 | Ardisam Inc Earthquake Mini Cultivator
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Tines won't turn
Detatch the HEAD and rotate it and then install it. There is a good chance you have Jammed the Head and this should reduce the pressure and allow it to work.
Apr 03, 2013 | Ryobi GC720R TrimmerPlus Add-on Garden...
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
Own an older (1990's) American Yard Products model WER500 Weedeater rear tine rotortiller. The engine runs great but when I engage to til, the tines won't turn. The belt is fine and pulleys turn...
Yes, there are shear pins on the tines and on the wheels. Can you check to see if the belt actually moves when the pulleys turn?
May 13, 2011 | Garden
Craftman Tiller Model # 9172933311 doesn't go into ground. Tines skirt over grass instead of digging into ground and removing grass.
need to use down force and pull back to offer resistance so tines dig into ground and not walk across area
Jun 10, 2010 | Craftsman Garden
THE TINES WON`T TURN, THE MOTER WORKS THE TINES WON`T TURN
SOUNS LIKE SOME THING CAME LOOSE IN SIDE THE TRANS
Oct 01, 2009 | Craftsman Garden
Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2 Logo
65 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
