Question about Samsung Refrigerators
Freezer fan fault
Samsung rs21 showing freezer fan fault which is not working in freezer. when taking out and tested with a 9 volt battery it runs, what to check next?
bobotfel
  • 236 Answers
SOURCE: Iced up Samsung RS21 JGNS Help!!
Defrost the unit and after defrosting, with the unit unplug rotate the fan blade manually using your finger. The fan should rotate freely, the blade should not touch the fan frame. Slow rotation of fan motor can cause icing. Worn out bearing, misalign fan blade, partially burn fan motor can slow the rotation of blower motor.But if the blower operate normally, then the unit may be under charge of refrigerant. Qualified technician is needed with this problem.
Posted on Mar 05, 2008
keemo68
  • 1263 Answers
SOURCE: coolig fans dont run
the cooling fans are run by a relay it's located in the junction box. check this. there is also a thermoatic sensor located near the fans next to radiator. the fans should free spin when the engine is off this is a good indiacator that it's not the fan themselves. if the relay checks out(run engine and switch the fan relay with the a/c clutch relay when the engine reaches 180 degrees you will feel the upper radiator hose get hot the fans will turn on a short time later iof they don't it's the temp sensor near the radiator if they do it's a bad relay...please rate this thanks
Posted on Sep 28, 2008
SOURCE: Samsung RS2534 Freezer works but fridge side isn't very cold
replace the sensor and the main board
Posted on Jun 07, 2009
SOURCE: rs21/fcns fridge freezer fridge keeps
I have a Samsung Side by Side Refridgerator RS21 FCNS which has stopped cooling the fridge - the temp sticks on about 14deg. Yellow pages engineer came out and quoted a ghastly job and £350.
Called Samsung on 0845 726 7864 and they told me that the defrost heater is a design fault and that warranty on this component has been extended to 5 years. Someone coming tomorrow to fix it (for free).
Posted on Jul 02, 2009
SOURCE: need to replace the 9 volt battery in my kenmore freezer chest.
The manual does not tell you where its at but the 9-volt battery holder is located on the lower left side of the freezer. There is a small panel about 9" off the floor and towards the front of the freezer (left side facing). cd6fa25d-9930-4b53-8883-c0ebcde8413d1.03.01
Posted on Sep 12, 2010
Samsung Fridge/freezer problems
The BBC has an open complaint on these machines and you may be elligible for extended work on this
Feb 20, 2014 | Samsung RS2630SH Side by Side Refrigerator
Samsung rs21 fridge temp keeps flashing
It's a defrost sensors issue. You need to replace the evaporator assembly it will come with all the sensors you need.
Jul 24, 2013 | Refrigerators
My samsung will run fine for about 4 hours and then will get too cold. if i unplug it and then plug it back in it will then work fine for another 4 hours. please advise thank you
samsung fridge freezer srs2028 srs 2029 problems
if you a have samsung model
SRS 2026 2027 2028 OR 2029 , then you probaly need to fit the rs21 repair kit - as the srs models are the earlier version of rs21 - and suffers from the same isssues .
there is an extra component you will need as well as rs21 kit - if you look under most of the videos there is a ebay link which takes you to ebay shop where you can pruchase samsung spares
check this video out on youtube
Feb 14, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
Rs21 samsung twin cooling
These usually have one compressor and an evaporator on each side with a fan. check the fans first then the defrost timer, heater and limit thermostat.
Sep 14, 2009 | Refrigerators
SAMSUNG RS21DCNS
samsung fridge freezer problem
samsung fridge freezer diy help
Apr 27, 2009 | Samsung Refrigerators
Rs21/fcns fridge freezer fridge keeps icing up causing fan to jam on ice and water to freeze
Apr 21, 2008 | Refrigerators
Mar 05, 2008 | Refrigerators
RS21 DCNS FRIDGE COOLING FAULT
There is a fan behind the plastic. This distributes the cold air throughout the fridge. What happens is this fan stops turning due to freezing up. A temp solution is to unplug the samsung for 6-12 hours to allow the ice to melt from around the fan. This is a known design fault. It is easy to dismantle the plastic cover and defrost the frozen fan with a hair dryer, this way the fridge will only be off for about an hour
Aug 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
Refrigerators Logo
80 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
