Question about Viking DFUD042 Built-in Dishwasher
How do i get the bottom spray assembly off?
Bottom spray bar doesn't turn / ran water through backwards didn't change. moves freely
    Problem Solver:
  • 5 Answers
USUALLY, there is a knob that holds the spray arm on the shaft coming up from the pump. Hold the spray arm and turn the knob the opposite direction than what the arm rotates. there might be a blockage in the shaft which can be seen when the spray arm is removed. the other blockage might be in the inlet to the pump which is on the bottom of the pan where there is a removable screen below which you can see the food/ debris grinder and below that the impeller to the pump. clean out both if you can. Caution - dont leave any screws/ hard items in the impeller cavity.
Posted on May 07, 2014
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
Bottom agitator brush bar doesn't rotate.
First, check to make sure the brush bar is on. The switch is right next to the machine's on-off button, and it is easy to accidentally turn it off when you turn the DC 25 on or off.
Next, check for and clear any obstructions in the brush bar housing.
Finally, check for belt wear and replace if necessary. There is a very video online showing the procedure.
Jul 21, 2012 | Dyson DC25 All Floors Bagless Upright...
The upper spray arm doesn't seem to be moving or spraying water properly. It does move freely
Assuming top spray arms are clear of debris It sounds like your pump/motor assembly is bad and needs to be replaced.Thanks
Feb 01, 2011 | Frigidaire 24 in. GSB5712BC Gallery...
10 yr old Kenmore dishwasher was leaking, cycling ok but dishes are not coming out clean. Took about bottom spray unit, found a split plastic round ring about 1.5" dia. Could this be the problem or what...
The ring fits just under the spray arm and the split is normal. When you tore the spray assembly apart, did you clean the screens at the bottom (if white hard-water deposit, soak in 50:50 hot water and white vinegar)? Make sure none of the ports in the deck are plugged with food deposits. Check both spray arms for plugged spray holes or split seams. The upper arm moves from water pressure alone--no motor. Make sure it spins freely by hand. We had to try different detergents to get away from a gritty deposit on glassware. Did you fix the leaking problem? Inspect the gasket seal around the door for damage or hardness and check the latch for holding the door closed firmly. Hope some of this helps!
Oct 17, 2010 | Kenmore Dishwashers
Chain will not rotate; which part needs to be replaced?
Try to turn the chain by hand--if moves freely, the clutch assembly under the cover may be overly oiled. Remove the bar and chain, then wash the clutch drum and shoes with carburetor spray cleaner. Make sure the chain brake is not set. Hope this helps!
Sep 13, 2010 | Husqvarna 450 e-series 18" Chain Saw
Son's can pedal 12" bike
Yes, something isn't turning freely. It's either the front wheel, the back wheel, or the pedals and chain. Lift the bike off the ground and turn the front wheel by hand. If it doesn't turn very freely, it could be the hand-brake is dragging or the hub bearing is too tight. Try the back wheel in both directions. It should move freely in the forward direction. When rolling it backwards it is normal for the pedals to move too if this bike has a coaster brake (that is the kind of brake that is applied by pushing the pedals backwards.) It the back wheel moves forward freely, but backwards is a problem, then try the pedals by hand with the rear wheel off the ground. If this doesn't turn freely, the pedal crank bearing (a.k.a. bottom bracket) is too tight. Once you have identified the problem take it back to where you got it. It should be easy to fix, or they should replace it.
Jul 28, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
The middle and top spray bar does not seem to
Is there enough water getting into machine. I it fills until the float shuts off water valve the the pump or motor may be bad.
Jul 10, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Rotors not turning during operation
Confusing..You say in one line Rotors not turning during operation. next line says
The top & bottom blades are able to move freely?
Il try & help anyway.1st the water level may not be high enough to load the the wash motor & spray water.2nd the dishes or cutlery may be hitting the arms.
May 30, 2010 | Zanussi 24 in. ZD686 Built-in Dishwasher
My KitchenAid washer will agitate, but the upper agitator assembly is not turning and I hear what sounds like marbles moving/slipping. Can I take that top piece off to look at it?
Based on your description, the problem is likely the self-rising tube that comes from the base (bottom) water feed tube. It may not be rising to engage the top assembly....
If it fails to rise all the way, the water will just spray into and on it and cause it to wobble versus rotate.
Pull up on the bottom feed tube - just to confirm that it will move freely...... (food, soap scum and age can prevent it from moving freely.) Clean and retry the washer.....
Nov 07, 2009 | KitchenAid KAWS700L Top Load Washer
The dishwasher is not cleaning the dishes at all, so far I have done the following: Checked both sprayer arms and they move freely and do not appear to be clogged (I ran stiff wire thru holes in each The...
Heating element may have burned out. Check water temp during wash--should read between 130 to 140 F.
If not the heating element,you may have to replace pump-motor assembly or wash impeller.
Hope this helps.
Aug 12, 2009 | Kenmore Dishwashers
Viking DFUD042 Built-in Dishwasher Logo
103 people viewed this question
Top Viking Dishwashers Experts
Mike
ray gallant
Ronald Rissel
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
