What does f.l.a mean on a condensing unit - Heating & Cooling
  • 3,287 Answers
FLA = Full Load Amps. FLA is one of the ratings on the nameplate of an electric motor. FLA is the amperage rating of the motor when it is running at its designed horsepower and on the motors designed voltage.
Posted on May 06, 2014
Problem with GE PTAC-Model# AZ28E09DABM2 - Why won't condenser kick on when switching to AC from Fan. AC was working fine until today...Fan is still working...Pulled the unit out and could feel the h
Hummm. A bit difficult to solve this problem. Seems like the condenser outside is not working, I mean the fan of the condenser. Looks like you have a wall A/C and a wall A/C always have condensers outside the house and near the A/C. Have you checked if the fan is spinning? I don't think the compressor is at fault but check it anyway. You should be able to hear the compressor running either in the wall unit or in the outside condenser housing. The only heat you should feel is from the condenser itself. If you blows warm air, that means the fan is working, if not that means the fan is not working. But don't be confused with the fan not working because in winter time sometimes the fan is not working and some times it does. As I said, it's a difficult problem to solve but at least start with checking the situation with the fan in the condenser.
Jun 16, 2014 | GE Zoneline Deluxe Series Cooling &...
WRS6R3EW8 Refrigerator and freezer not cooling. Evaporator coil 60 deg. only. Compressor, evaporator fan and condenser fan running. Some frost on the tubing coming from condenser at the evaporator. ...
Where is it frosting, condenser or evaporator? If you mean frosting on evaporator line to compressor, probably iced up evaporator. If you mean frosting after condenser by capillary, unit short of gas/ blocked.
Apr 27, 2012 | Refrigerators
The furnace is running but there is no cool air. I change my filters every month and I flushed out the water lines last month.
flushing out water lines do you mean condensate line coming off the furnace that drain to the outside. is the condensing unit outside running when u have it in cooling mode. by condensing unit I mean the unit outside that has lines that run to the inside. does that turn on when u have it in cooling. the unit outside have two components that should turn on the outdoor condenser fan and a compressor.
Aug 21, 2011 | Ruud UAKA060 Air Conditioner
What does bucket full mean on my frigidaire portable air conditioner mean
this type of unit has a condensate drain bucket that holds the condensation that is removed from the air, this bucket needs to emptied when the light comes on.
Jul 23, 2011 | Frigidaire FAP094P1 Portable Air...
Airconditioner works only in fan mode...when picking heat i get an EE blinking signal and power light turns to red....
EE means high discharge pressure.If new unit or recently re charged gas unit, it's over charged. Other wise, it has non condensable gas. Remove all gas and replace filter direr flush out system re charge gas. Helpful.
Before doing above, clean condenser coil and check. Some times due to condenser block also discharge pressure will raise.
Jan 04, 2011 | Heating & Cooling
Danby DWC283BLS has condensation inside the unit.
wine coolers have no means of draining the condensate inside them,use silica gel(1/2 pint)to keep the inside dry(remember to dry it out when condensate happens again)
Jul 16, 2010 | Danby DWC283BLS Wine Cooler
We have a flashing vacuum condenser message on our screen -- what does this mean?
It probably means that your condenser coils are dirty and need to be cleaned up. The condenser coils are the copper tubes in the back of the machine next to the condenser fan. If just vacuuming them up doesn't sufficiently clean them then you may want to get some coil cleaner from your local hardware store or whoever sold you the refrigerator.
If the condenser coils are already clean then you may not have enough airflow. Be sure you have 4 to 8 inches of free space behind the unit to provide adequate airflow.
Mar 13, 2010 | Sub-Zero 642
Condenser is buzzing so there is power, but the
The buzzing sound is from the contactor and only means you have low voltage at the unit,Check and make sure you have 240 volts at the unit and post back.
Jun 27, 2009 | Ruud UAMB Air Conditioner
Sub zero
This means that your unit is unable to dissapate the heat where it is intended to, the condenser unit. Open the top panel and check the condenser unit to see if it is clogged with debris. It will be on the rh side and looks similar to a car radiator. If it is dirty, clean it. Also, check to see if the fan is running that blows through the condenser. It should be running whenever the compressor motors are. If it is not blowing, replace it.
Oct 25, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Unit Runs (fan and condenser) but no water?
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
Jan 08, 2008 | Comfort-Aire BHD-651 Dehumidifier
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
