Can I put a lower amp fan motor on a condenser if the one has a higher amps
  • 3,289 Answers
Jason,
You air conditioning system is designed as an entire unit. All the parts were selected to work together.
The condenser fan motor has been selected to match system voltage, provide enough horsepower and RPM to spin the a fan with "x" number of fan blades with fan blade pitch or angle that will pull enough air across the condenser coil to cool the hot refrigerant gas enough so that by the time it reaches the expansion valve it will be in the ideal temperature range to provide maximum cooling in the evaporator coil.
Changing components with unlike replacements creates strain, inefficient cooling and potentially early failure of parts.
Posted on May 07, 2014
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Original AC Condenser fan motor had three wires L1
Yes, that can be confusing...hook the tan wire with the white strip onto the same line wire as the one going to the capacitor...usually the L2 wire....so then in reality you have the two tan wires hooked onto the common and the F terminals of the cap...
heatman101
Posted on Aug 16, 2010
  • 674 Answers
SOURCE: I bought a replacement Dayton electric condenser
The tan/white wire can be insulated/capped and not used. Use and ohmmeter to take a resistance reading between the tan/white wire and L1 & L2. There will be no resistance between the tan/white wire and one of the others. This will be the common wire. Connect it to one side of the contactor. Connect the tan wire to the fan terminal on the contactor and the other wire to the common terminal on the capacitor (that is if you have a 3 terminal capacitor, if you have a 2 terminal capacitor connect tan to one side and the other wire to the other). Then connect the other side of the contactor to the common terminal on the capacitor (on a 2 terminal capacitor connect the contactor to the side that doesn't have the tan wire on it).
  • 127 Answers
SOURCE: NEW CONDENSER FAN MOTOR DRAW
The capacitor may be weak if it has not been changed with the motor, which will cause excessive amp draw. Also may need condensing coil cleaning to reduce static pressure on the fan.
*Some motor ratings do not reflect what is actually needed for proper operation in some cases a higher amp motor is required.
Posted on Aug 27, 2011
Everything works. But the fan runs all the time on or off. 25/7
Condenser Fan Motor Operation ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../condenser-fan-motor-operation
Sub?ZeroShould the condenser fan motor on a Sub-Zero run continuously? Why does the fanmotor run all the time? ... Refrigerator or Freezer Fan Switch Information.
Refrigerator Condenser Fan Is Always Running ' Home ...
homeguides.sfgate.com > Insurance & Inspections > Insurance Basics
Refrigerator motors sometimes need troubleshooting over time. ... If the fan isn't shutting off there could be several reasons. ... reason a condenser fan is continuallyrunning within a refrigerator is the thermostat. ... All Fields are required. Name.
Oct 30, 2015 | Refrigerators
Maytag Performa Model # PSB2151GRW Fridge is blowing warm air and you can hear a clicking sound from the lower part of the fridge every 2 - 3 minutes. Fridge not cooling at all.
Your compressor is damaged. It must be either serviced or recharged. This is going to require a service call no matter what the solution due to the need for recharge after the compressor is replaced.
Oct 02, 2008 | Maytag Refrigerators
Amana central air codensor motor runs for twenty minutes and shuts off ! new motor ,new cantactor , and new capaciter ?
Hi, not sure which motor you are talking about, the indoor blower, or the outdoor condenser fan motor? Doesnt matter. If the motor is shutting down, its overloading and going off on its internal overload. Cools down, resets and repeats this again. Make sure you have not miss wired it. Even though the run cap and motor is new, doesn't always mean they are good. You need to look at the R.L.Amps on the motors data plate, to see what it is rated for when running.You MUST have an amp probe meter to check each hot leg to this motor to see how many amps it is pulling while under a load. If it is the condenser fan motor, and if the blade/prop is not in the right place on the 1/2 " shaft, you can move it up or down to adjust the amperage on the motor. When you do this, it causes the motor to draw either more or less air across the coil, which you need less to reduce the amperage and load on this motor. I have seen this happen many many times, but like I said you will need a amp probe meter to see what the motor is drawing. If you dont have one, just move the blade a 1/2" in one direction or the other until the motor keeps on running. This will work, just time consuming, and you will never really no how many amps its drawing.You can pick up a good clap type amp meter at Sears, a Craftsman for around $29.99. It is well worth the bucks to have. You can also check the uf's on the run cap. The voltage 370 or 440, food for thought is you can always use a cap thats higher in voltage but never lower. Make sure you have the correct MFD as I am sure you know this.So, check the voltage from the new contactor to the motor, the run cap, and most important is how many amps it is drawing and you can wrap it up. I wish you the best. Please let me know, keep me posted, and rate me if you please to.
Sincerely,
Shastalaker7
A/C & Heating Contractor.
Aug 27, 2011 | Amana Heating & Cooling
NEW CONDENSER FAN MOTOR DRAW 2.6 AMPS WHEN IS RATED FOR 1.5- 1.8 MAX HOW DO I LOWER THE AMPS ? THIS IS THE SECOND MOTOR WE INSTALL AND THIS OVER AMP DRAW CAUSES THE FUSE TO BLOW
Aug 26, 2011 | Goodman CKL60AR60 Air Conditioner
I have a" Nautilus Microtek
The motor is getting worn to the point it will stop soon. Remove the screen and you find the fan/motor directly behind it. You can try to put some machine oil on the motor shaft next to the motor housing. It may quieten it some. Recommend you replace it. Be sure you disconnect power before you do anything else. The motors and fan assembly is small in size and can be bought in Home Depot or an appliance store. If you need assistance in removing the motor/fan and installing new one, please let me know. Those brands are found at Home Depot.
Jun 18, 2011 | Kitchen Ranges
What is the electrical draw in amps or watts. I need to see if I could use it on my boat which has a inverter off of the 12 vold battery.
. You'll need to know a little more than the average amperes draw of the unit in order to use it with your inverter . Here's why : the compressor in the refrigerator is rated with two amperage ratings . One is the running amps which is usually around five to eight amps . And you must add your condenser fan and circulation fan amperage to the compressor amperge for a accurate total current consumption . However , the other compressor motor rating is what is called LRC, which stands for locked rotor current and is much higher than the running current . Usually three to five times higher than the running current . This current only lasts for a few seconds while the compressor motor is actually starting up from a dead stop . If your inverter's surge rating is not at least 20% higher than your refrigerator compressor locked current rating , you will have problems with either or both units . The amp rating for the refrigerator should be located on the main ID plate . If the plate only shows continuous amperage or wattage, multiply by 4x to obtain a estimated LCR. I hope this helps.
Feb 22, 2011 | Magic Chef MCBR440 Compact Refrigerator
The fan on the bryant high efficient heat pump moves very slow or not at all
Hi, this is a 3 ton unit. It may or may not have a variable speed fan. You are saying it turns very slow or just stops. I believe you either have a problem with the run capacitor, or you are loosing this motor. They are putting variable speed blower motors on some units now, but if you are talking about your condenser fan motor, it may have a head pressure control to speed up this motor when the ambient temperature is higher and slower when cooler, but to stop when running indicates a motor or run capacitor problem. Check the cap. for oil leaks, swollen and deformed, burned terminals. If you find this, replace it. Remove the fan guard and carefully with the power off after it has ran for a while touch to see how hot the body of the motor is. If it is to hot to touch, you are loosing this motor. If you have a clamp around amp probe or know someone who may, you can look at the data plate to see what this motor should be drawing as far as amps and compare your readings to this. You will know for sure doing it this way.
Shastalaker7
A/C, & Heating Contractor
Jun 21, 2010 | Goodman CLQ36AR49 Air Conditioner
Overheating only in traffic when I use my air-con.
You have two fans in your Nissan, one is for the engine and the other one is for the A/C. Whenever you turn on your A/C, the fan runs continuously not matter what untill shut your engine down. First you need to check the fan switch for the A/C before you go out and buy one. As for the cooling fan for the motor. There is no need to buy a fan for the engine side. Track the A/C fan wire back to the switch and let me know.
Dec 11, 2009 | Video Game Consoles & Games
Whirlpool refrigerator - condensation, ?clogged drain
The stopped up drain tube is inside the freezer probably behind the rear wall. There should be screws in it to remove it. Remove any ice at the bottome and you should be able to see it. I don't know about the wheel.
Aug 14, 2009 | Refrigerators
RV rooftop A/C trips breaker after awhile
Try removing the wires to the compressor and see what it draws when just the condenser fan is running. The motor for that fan should have an amp rating for it. If the fan is not running as fast as it should it will bog down the compressor.
Aug 02, 2009 | Heating & Cooling
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
