Question about HP LaserJet Office Equipment & Supplies
How do i get my hp laserjet p1606 to copy both sides (duplex)?
    Habit-Forming:
  • 54 Answers
You need to download the different software from hp web site...
Posted on Jun 25, 2014
IB4G2008
  • 3587 Answers
SOURCE: HP LaserJet 4700DN Duplexer Jams
hmmm..check the paper for riffling(with fingers before placing in tray)..and the rollers can get slippery, after a period of time...
check your computer warranty for FREE here
Posted on Feb 22, 2008
  • 134 Answers
SOURCE: LaserJet 2430dtn printer
Have you checked the settings on the printer's menu. It should be under paper handling.
Posted on Jun 13, 2008
SOURCE: HP Color Laserjet 5550 not printing duplex
Hi, Check that the printer driver has duplex (double sided) turned on.
That's if u hav not already solved it :-)
Posted on Sep 17, 2008
  • 68 Answers
SOURCE: HP LASERJET 4250 DUPLEX ISSUE
only problem ive had with the earlier model not doing duplex was a sheet of paper in the duplexer bin . This is hard to find but if you pull out the paper tray and look in the space where the tray goes up above theres a lever which you can push and it releases the hidden duplex bin which stores the paper at half way through the double pass and if there is any paper in there then the printer will not duplex.
Posted on Oct 02, 2008
thydzik
  • 86 Answers
SOURCE: Duplex copying on HP Photosmart C8280 All-in-One
Open HP Solution Center, click on Settings, click on Scan Preferences, select "Scan both sides of original when using duplex feeder."
or
Open Solution Center, click on Scan Document, and you should have a check box towards the bottom of the window which would say 'scan both sides of the original document'. check that box and start scanning.
Posted on Jul 22, 2009
HP LaserJet 4000 Duplexer
I realize when I say this that you will be a little skeptical but I will say it anyway . the Paper may be damp - do you notice any curling from your print if only printed on one side? this is the easiest way to test for damp paper- while the paper is damp the Electrical resistance is much higher than when its dry and this is what typically gives a Light copy however once the paper has been though the Very Hot fuser rollers to \'fix\' the first side, the paper has been force ably dried and so the second side is much Stronger in toner. try a new ream of paper and see if that helps
Jan 22, 2014 | HP LaserJet 4000 Printer
We have a new hp lasterjet 4015n. It will print two sided, but it won't flip up the back side. I have my driver set to duplex print and flip up, but it won't flip up. Is there some setting on the...
I assume that you attached the two-sided printing accessory (duplexer) to your product:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01909142&cc=us&lc=en&dlc=en#N428
The duplexing has to be set in the printer's
Printing submenu
DUPLEX OFF/ON
This item appears only when an optional duplexer is installed. Set
the value to ON to print on both sides (duplex) or OFF to print on
one side (simplex) of a sheet of paper.
The default setting is OFF.
Print on both sides (Duplex) Click Print on both sides. If you will bind the document along
the top edge, click Flip pages up.
User manual:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 01, 2011 | HP LaserJet P4015N Printer
I am using auto feed on HP 4345 MFP printer, the issue is I have documents with one side printed but printer is scanning both side and printing. How can I change setting to single side from Duplex scanning...
Mr. Agarwal
you have to turn off the duplex scanning option under copy settings this will solve the issue
You can go to settings and look for Copy setup or copy settings i dont remember well but you get an option of DUPLEX COPY or DUPLEX SCAN you have to turn off this.
DO RATE MY SOLUTION PLEASE
Saleem
Jun 30, 2011 | HP LaserJet 4345mfp Printer
Auto Duplex Unit Not Working Model: HP LaserJet 2420dn I am using Windows XP and installed "HP LaserJet 2420 PCL 5e" driver. It is connected via internet and when I try to print double...
You need to go into the print driver on your Windows machine and go to the Device settings tab. One of the settings is to set whether the unit has a duplexer or not. It does not always set automatically.
Jun 23, 2011 | HP LaserJet 2420dn Printer
How can double sided print
HP3350MFP - Duplex Printing/Copying
Hello, The HP3350 does not support automatic double sided printing. The HP3390/3392 printers support this option. In order to double side on the HP3350 a manual duplex will need to be conducted, which means running page 1 through the printer, flip the page over and print page 2 for the reverse side. It may be necessary to experiment a few times to achieve the proper printing orientation. You can download a copy of the users guide from the following link.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=ca&docIndexId=64179&taskId=101&prodTypeId=18972&prodSeriesId=1161389
Jan 15, 2011 | HP LaserJet 3055 All-In-One Printer
Duplex printing availeble in HP laserjet 2015n?
HP 2015n is not able to print duplex (both sides). HP printers, which have duplex print have "d" after the product name/number - like HP2015dn, 2055dn.
Aug 20, 2010 | HP LaserJet P2015n Printer
LaserJet 5MPHP
Only if you print the first side then place the paper back into the printer to do the second side. Also referred to as manual duplexing. This printer has no automatic duplexing option.
Also keep in mind that the percentage of duplex prints you do should be very low as this printer has no method of cleaning the fusing unit as most printers do that are made for duplexing. The industry standard is 2% or less should be duplexed.
Jan 05, 2010 | Office Equipment & Supplies
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
Hp laserjet 4345 mfp. Paper stalling in reverse unit on single side copy /print. thanks pj
Clean reverse rollers and duplex roller with rubber revitalizer, carefully !
May 08, 2009 | HP LaserJet 4345mfp Printer
Not able to take print on both side in hp 9000 normal series
You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it.
Read below:
Shown at left:
HP LaserJet 9000 series, base unit—
LaserJet 9000
base unit =
• 50 ppm print speed
• first page out in less than 8 seconds
• built-in RIP-once technology
• 300,000 pages-per-month duty cycle
• 64 MB memory
• EIO expansion slots
LaserJet 9000n = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
• 100-sheet multipurpose tray
LaserJet 9000dn = base unit +
LaserJet 9000hns = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TXlj9000hns.jpg
• 2000-sheet input tray
• 3000-sheet stapler/stacker
Oct 25, 2008 | HP Compaq dc5700 Microtower - Free Flat...
15 people viewed this question
Seeker5211
Seeker5211
