Question about Crl Automotive Vehicle Parts & Accessories
FOB stands for what? in automotive access devices?
What does FOB stand for in the automotive keyless FOBs
    New Friend:
  • 38 Answers
FOB - Free On Board (Location)
Posted on Mar 01, 2015
  • 3,289 Answers
Take your pick of definitions - there's no clear one.
what is FOB Google Search
Posted on May 07, 2014
I have a 2003 trailblazer and i bought a fob and it does not work after programing Everything thing works on my truck but the fob. Any ideas?
How was it programmed ? Was a scan tool used ?
Program All Key Fobs
To complete this programming operation, all keyless entry transmitters associated with the vehicle must be available for programming. Once placed into program mode, all previously programmed transmitters will be erased from memory upon the receipt of the programming signal from the first transmitter.
  1. Close the lift gate.
  2. Ignition ON, access the scan tool Lift gate Module Setup menu and select Program All Key Fobs.
  3. Follow the scan tool on screen instructions in order to program the transmitters. Select "Start" on the scan tool to enter the program mode.
  4. As each transmitter is successfully programmed, the scan tool will show how many transmitters have been placed into memory.
  5. When all transmitters are programmed, exit the program mode by selecting "Stop" on the scan tool. The vehicle will not respond to the transmitters until the program mode is exited.
  6. Operate the transmitter functions in order to verify correct system operation.
Program Individual Key Fob
If there are less than four keyless entry transmitters programmed to the vehicle, an individual fob transmitter can be added. This method will not erase previously programmed transmitters from memory.
  2. Ignition ON, access the scan tool Lift gate Module Setup menu and select Program Individual Key Fob.
  3. Select "Program additional Key Fob" on the scan tool.
  4. Follow the scan tool on screen instructions in order to program the transmitter.
  5. Operate the transmitter functions in order to verify correct system operation.
Apr 08, 2016 | Cars & Trucks
Program new key fob for Cadillac cts 2003
There are several methods of doing this - but your 2003 requires that you either go to the dealer for them to add a FOB with special equipment (ask if they'll do it for free - can't hurt). If you have time to kill, you can do it yourself with Method 3 as described and found at:
Key Fob Reprogramming General Cadillac Forums
Method 3 - Key Fob Auto Learn
This procedure will first erase all known key fobs. The procedure will then program a single or multiple key fobs. Method 3 is a series of three 10-minute key cycles, for a total of 30 minutes. This procedure requires that you have a replacement key fob and the vehicle mechanical key.
Important: All previously programmed key fobs will be erased upon completion of the 30-minute programming procedure. The order in which the key fobs are programmed will determine its numbering position within the RCDLR memory. The first key fob programmed will be key fob #1, and the second key fob programmed will be key fob #2. The number stamped on the key fob case is for reference only: #2 can be programmed as #1.
Do not place any known good key fobs in the vicinity of the vehicle when programming with Method 3. If the RCDLR recognizes a known good key fob during Method 3 programming, the programming mode will resort to Method 1.
The vehicle must be OFF.
Place the replacement key fob in the console pocket with the buttons facing forward.
Insert the vehicle key in the driver door lock cylinder located in the driver door handle and cycle the key 5 times within 5 seconds.
The DIC will display a message: OFF/ACC TO LEARN.
Press the OFF/ACC portion of the ignition button.
The DIC will display a message: WAIT 10 MINUTES, then it will count down from 10 to 0, one minute at a time.
When the counter reaches 0, DIC will display OFF/ACC TO LEARN.
Repeat steps 5-7 two more times, for a total of 30 minutes.
A beep will occur and the DIC will display: READY FOR FOB 1. At this time all previously known key fobs have been erased. When fob 1 is programmed a beep will be heard and the DIC will display a message: READY FOR FOB 2.
Additional key fobs can be programmed by taking fob 1 out of the pocket and inserting fob 2. If desired, up to 4 fobs can be programmed. Once 4 fobs have been learned, the DIC will display a message: MAX FOBS LEARNED, and automatically exit the program mode.
If learning less than 4 key fobs, press the OFF/ACC portion of the ignition button to exit the program mode.
Operate the active portion of each key fob in order to finalize the programming sequence and verify correct system operation.
Feb 25, 2015 | 2003 Cadillac CTS
I don't know what 'FOB' stands for, but what it IS .. it's the remote button that you use to open your car
May 06, 2014 | Computers & Internet
2005 sts wont start. Says no FOBS detected. Please help?
Are both FOBs doing this? If it's only one I would replace the FOB battery.
NO FOBS DETECTED Message on DIC, No Crank/Start Unless Fob in Center Console Pocket or Remote Keyless Entry (RKE) Button Inoperative (Replace Remote Control Door Lock, Theft Deterrent Receiver Assm) #04-08-52-008
Tell the Dealership to look at this. They should be able to fix it quickly.
Keep us updated.
Feb 08, 2011 | 2005 Cadillac STS
Keyless entry remote programming
Hello here is the instructions for programming the key fobs
This procedure will add, replace, or invalidate all key fobs. This procedure requires that you have a known good key fob available, a new/replacement key fob, the vehicles mechanical key, and a scan tool.
Method 1 is also used for the initial programming of fobs to a new replacement RCDLR. In this instance, the new RCDLR comes ready to learn the first key fobs introduced. Perform the learn procedure as outlined, with the exception that the new RCDLR does not require a known good key fob be placed within the interior of the vehicle.
Note: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Methods 2 or 3 must be used in this instance.
  1. The vehicle must be OFF.
  2. Place a known key fob and any new/replacement key fob(s) to be programmed in the cupholder inside the vehicle. DO NOT place any fobs in the console fob pocket at this time.
  3. Insert the vehicle key in the driver door lock cylinder located in the driver door handle and cycle the key 5 times within 5 seconds.
  4. The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4). → If the DIC displays: OFF/ACC TO LEARN, the known fob has not been recognized. At this time, programming will revert to Method 2.
  5. If the DIC is displaying the correct fob number that needs to be programmed, skip ahead to step 9.
  6. If the DIC is not displaying the correct fob number that needs to be changed (i.e., the DIC is displaying: READY FOR FOB 3, and you wish to program FOB 1), use the scan tool to access the following: • Vehicle Control Systems • Computer/Integrating Systems • Module Setup • Remote Control Door Lock Receiver • Program Key Fobs
  7. Select the fob position you wish to program: Note: Selecting Invalidate All Fobs will erase any known fobs and will cause the DIC to prompt READY FOR FOB 1, requiring all fobs to be relearned to the vehicle.
    • Invalidate All Fobs • Program Fob 1 • Program Fob 2 • Program Fob 3 • Program Fob 4
  8. With the fob position selected, press the PROGRAM soft key on the scan tool. The DIC should display: READY FOR FOB X (X = fob 1, 2, 3 or 4, depending on the selected position)
  9. With the DIC displaying the correct fob position that is to be programmed, place the new/replacement key fob in the console fob pocket with the buttons facing forward.
  10. A beep will occur once the fob has been learned.
  11. If programming additional key fobs and there is no DIC prompt that indicates READY FOR FOB X, repeat steps 7 and 8.
  12. Exit programming mode by pushing the OFF/ACC portion of the ignition switch. Note: Failure to exit programming mode (press OFF/ACC) prior to pressing the UNLOCK button of each key fob programmed will result in that fob being inoperative. Pressing the UNLOCK button completes the programming sequence and is require to ensure transmitter operation.
  13. Press the UNLOCK button on each key fob that was programmed to finalize the programming and confirm system operation.
Nov 03, 2010 | 2006 Cadillac STS
2002 Beetle TDI Key fobs do not work until I am
after maket alarm will help the range and give u option to auto start the car to it is way better way to do keyless and longer range and cheaper
Jul 06, 2009 | 2002 Volkswagen Beetle Turbo S
Programming a keyless entry remote
Key Fob Auto Learn
Do not place any known good key fobs in the vicinity of the vehicle when programming.
Good luck and hope this help's keep me posted, there are 3 other methods and the 5th method is a tech 2 scan tool that the dealer uses but this should work on your year of cadillac.
Jul 01, 2009 | 2003 Cadillac Deville
Remote keyless entry
I assume you are talking about the key fob. First, pry it open and change the battery. Watch which way the + goes.
If your key fob works, and the battery did not fix it, try reprogramming following the instrcutions in the owner manual. May need both fobs present at the same time.
Note; This is different than programming the anti-theft key.
May 27, 2009 | 2003 Ford Windstar
Vehicle Parts & Accessories Logo
112 people viewed this question
Top Crl Automotive Vehicle Parts & Accessories Experts
Steve
baire
Dan Horsefield
Dan Horsefield
Are you a Crl Automotive Vehicle Part and Accessory Expert? Answer questions, earn points and help others
