Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Last load of towels finished and we smelled a slight burning odor.
Have not tried another load . can a bulky load cause that??
  • Whirlpool Master
  • 3,287 Answers
If you overload a dryer, you can severely limit airflow. This can cause excessive heat. Most dryer appliances have built in thermal shut off devices to prevent accidental overheating. If your dryer allows the temperature to rise to the point that articles in it smell burnt - the dryer or thermal shut off device is probably not operating properly. You should check to make sure that the filter is cleaned before every load and that the exhaust vent is clean and unobstructed. If it persists, you should have the dryer and vent serviced.
Posted on May 07, 2014
  • 262 Answers
SOURCE: wont drain burning smell
if it smells electrical then it is the motor and just because you replaced it months a go that dont meen anything i have seen them come off the shelf and be bad not saying ddty that this is your issue but it sounds like it a bad solinoid chances are very slim I would look towards the motor to find out when machine quits lean machine back on the wall so it dont fall on you and put your hand on the motor if it is hot then it is over heating and needs to be changedplease let me know what you guys find and if i can help you in any way
Posted on Jan 14, 2009
mumma_1
  • 903 Answers
SOURCE: Clothes and towels don't smell fresh after washing
If you are sure that the pump is not blocked then try running the machine on a quick wash on its own with a little bleach in the drawer.
Posted on Jun 28, 2009
  • 150 Answers
SOURCE: The washer has a very bad odor. I have tried
thedrain has sludged up causing partial blockage. soap powders cause this . check the fall on your drainage. Either attempt self cleaning or get a drainage company to investigate.
Posted on Aug 14, 2009
  • 107 Answers
SOURCE: Odor problems with whirlpool front load washer
Is the smell of mildew?
Run the washer on empty with beach and soap.
This is a common problem when the front door is left closed after use.
When the washer is not in use leave the front door cracked open. This will help in preventing mold & mildew.
Posted on Dec 13, 2009
SOURCE: Duet washer 9250ml1 leaks while washing bulky
I had a problem with my washer leaking only part of the time - not from the door, but from the base. There was also a stinky smell after I washed several loads. I couldn't find out where they smell was coming from in my wash room. It wasn't until I started getting the code F 02 that I researched a little further. It ended up that my Drain Pump was clogged - very clogged. When I opened it, it was a horrible smell. So - I solved 3 problems in one: my small leak, bad wash room smell, and F 02 code.
To reach the drain pump, unscrew the lower front panel on your washer. It was a white casing in the middle. Just unscrew & look. I believe in the newer models, they have this available to unscrew directly from the front of the washer. Must've been a common problem.
Posted on Jul 08, 2010
How do I remove odor from duet front load washer?
Assuming the odor is not a burning rubber smell or some other type of odor caused by a mechanical malfunction:
Remove the bottom of the washer (three screws I believe and above the drawer if you have one) and then open up the drain pump catch and clean it. You may want to put down some towels or even a bowl to catch water that will spill out. There are videos on how to clean this on youtube "Whirlpool Duet Water Pump Drain Catch". I believe this will solve the problem.
Oct 16, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My bath towels have an unpleasant smell after washing and drying. I have tried a few things but am sick of trying,
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
May 12, 2014 | Samsung Washing Machines
Electrical/Rubber odor after complete cycle
You have a drum roller that has a frozen bearing and needs to be replaced. The rubber smell is the wheel burning up.
Feb 12, 2014 | Bosch WFMC 3200 Front Load Washer
Burned rubber smell after replacing motor coupler, otherwise runs
The most common cause for the coupler failing is a bad gearcase. The machine should go through a neutral drain before the spin if it doesn't drain the water first it over works the motor trying to spin a full tub. No belt on this one, odor could be from the motor or the coupler starting to shred again.
Mar 01, 2010 | GE Spacemaker Washer and Dryer Electric...
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Jun 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cozy 351A 35000 btu
You might have a slight odor of gas when the burner first ignites. Some gas does escape before it completely ignites. It shouldn't smell after 2 years of use. If you can see the pilot flame burning from the top of the heater, the heater pilot assembly is pushed over too far. The pilot fumes could be escaping in the room and cause a smell.
Dec 27, 2008 | Cozy Enclosed Front Console Heater 70,000...
Burning smell from AC Unit
http://www.hannabery.com/faq14.shtml
"Odor problems can be as serious as a gas leak or as simple as a dirty air filter. But remember, a good mechanic doesn't just use his hands. He uses his ears and nose. Unusual odors could indicate a serious problem and should not be ignored.
We will go through each of the five categories and list the possible causes and things to check.
1. Electrical odor - Electrical odors are usually caused by parts overheating. Indoor blower motors are a common example. If there is a mechanical failure such as the bearings seizing up, the motor over-heats and the insulation on the wires and the motor windings themselves start to melt, causing the odor.
Sometimes loose electrical connections cause wires or plastic relays to overheat causing electrical odors.
It is possible for a very dirty air filter to cause the odor. If the airflow is restricted enough, it could cause electric resistance heaters to overheat, even burn-out.
If you smell an electrical odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
2. Burning odor - This is similar to an electrical odor only worse. It is also sometimes accompanied by smoke. Once again, this can be caused by parts or wiring burning-up.
It can also be debri such as plastic getting into the ductwork and melting on the electric resistance heaters or heat exchanger.
If you smell a burning odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
3. Gas odor - First of all, if you really smell gas and suspect a gas leak, you should open the windows, get out of the house, then call the gas company.
Now excluding that "worse-case" scenario, if you notice an odor that smells like gas and it seems to be coming out of the supply vents, it usually isn't gas. Sometimes dust that settles on the heat exchanger during the summer months burns off at the beginning of each heating season and it smell just like gas.
If the odor doesn't seem to be coming from the vents, try to pinpoint where the smell is coming from. Use your nose. If it is gas, it usually would be from a leak in a pipe fitting or at the equipment itself.
Gas odor is the one that causes the most fear. People think of gas explosions or carbon-monoxide poisoning. Well, gas explosions are very rare and carbon-monoxide for the most part is odorless.
Having said that though, don't take a gas odor lightly. If you can't locate the source of the odor and you are worried you have a gas leak, remember, open the windows, get out of the house, then call the gas company.
4. Oil odor - Oil odors are usually caused by one of two things. An oil leak/drip or an oil burner that is not working properly.
The oil leak is usually easy to spot. Just look for oil. Check the burner itself, the oil tank, filter and oil line. Sometimes it is just a matter of tightening a fitting. If there are no signs of an oil leak then it is most likely a burner problem.
This can be caused by many things, too many to list. It could be a minor adjustment to the burner to a faulty or blocked chimney. From a bad fuel pump to a plugged oil nozzle. Listen for any unusual rumbling or banging sounds or smoke or soot while the burner is running. If you notice any of these things and/or you have an oil odor, you should call for service immediately.
One other common problem today is that new houses are insulated so well and are built so tight that they run out of combustion air, causing odor problems. In this case it is just a matter of bringing in a fresh air for the burner. Call your local Heating Company to assist in a proper diagnosis.
5. Damp and musty odor - This is more common in the air conditioning mode. Sometimes attic units or very damp basements have this problem. Check for air leaks in the return ducts. Check for water damage to the ducts or air handler itself. Possibly consider having your ducts cleaned. Run a dehumidifier and see if the odor goes away.
But this odor problem is almost never due to a problem with your equipment.
Final Tips:
Keep in mind that almost all heating systems cause an odor the first time they are fired-up. And the first few times at the beginning of each heating season. Brand new furnaces are coated with oil to keep the heat exchangers from rusting. This burns off, creating a bad odor - even smoke. But it usually only lasts for about 20 minutes. Opening the windows usually solves the problem. And the first few times the backup heat on a heat pump kicks on, it smells like an electrical smell. This might last for a few days but isn't that bad. If you are worried, call for service.
Remember to check for a clean air filter and that your vents are opened. Check to see if the fan is working which mean your motor hasn't burned-up.
Check for air leaks in damp areas, oil stains or rumbling sounds, strong gas odors - these all indicate problems. Do not ignore them.
Hope this helps, remember - these are just rough guidelines and not all possible situations are covered."
Jul 28, 2008 | Sharp CV-P09FX Air Conditioner
Musty smell on towels
I had this problem last year. I was not using HE detergent. The other detergent was causing soap scum to build up in the drain hoses. After they were cleaned (it took more than one time taking it apart and cleaning), and we started using HE detergent, it worked fien with no odor.
Jul 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
200 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
