Using a Motorola Rdu 2020 radio while using a regular pair of head phones I can only hear through one ear and the headphones work in other things
  • Audio Player... Master
  • 17,093 Answers
That radio does not have stereo. The heaphones are for stereo. If you look at the plug you will see three distinct areas of connetion for the sound. The tip, the midlle and the shell, The jack on the radio only has two inside it.
Posted on May 06, 2014
I have a motorola HT820 Bluetooth stereo headphone. And I want to pair it with my Nokia 3110c. But every time I search for the paring device it shows no result. How can I pair my headphone with my nokia...
Make sure your headphones are turned off. Hold call button for 6 seconds, until you see the light steadily lit. Now pair with your phone: Motorola HT820, and type passkey: 0000. Done!
Dec 18, 2010 | Motorola Mobility HT820 Wireless / Cable...
I am having trouble programing VOX to work on motorola rdu 2020 2-way radios
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Instructions for setting the VOX sensitivity are on page 33.
According to the manual you program the VOX using the CPS (software). Three things which usually cause end-user problems are:
1) Failing to set the sensitivity to a number 1, 2, or 3.
2) Failing to have the radio shut off when plugging in the audio device (headset or earpiece)
3) Failing to use a VOX capable audio device. (Not all headsets and earpieces are VOX capable. Many with inline PTTs are not.)
If these items or instructions do not help, stop by your local Motorola dealer to discuss the problem.
Best regards.
Sep 22, 2010 | Motorola RDU2020 Two Way Radio
How do i get it to connect to my ipod
ok, this is a bit complicated of a matter so ill make it as simple as possible. First of all, the first generation iPod Touches DO NOT have bluetooth capability, so if your ipod is a first generation you cant use bluetooth. Second, the iPod must be running on the latest firmware, which can be updated through iTunes. Third, iPod Touches CANNOT pair with bluetooth headsets (such as the ones you use with a cell phone the go over one ear) however they CAN be paired with bluetooth HEADPHONES (go over your entire head to cover both ears) now assuming you meet the above criteria, the option for bluetooth is in Settings>General>Bluetooth On. place the device in pairing mode and it should be discovered. if it is not, you are using an incompatible Bluetooth Device. Hope This Helped! Remember to Rate
Aug 25, 2010 | Motorola Mobility Bluetooth...
Only left head phone works on Motoroloa S9 Bluetooth on LG Xenon
It's supposed to be that way. The S9 has been designed to comply with US law that you can only receive telephone calls through one ear while driving - it's a "safety" feature to allow you to hear the road and your surroundings when driving
Oct 17, 2009 | Motorola Mobility S9 Headphones
Pairing Motorola S9 headset with PC
i have try this before i couldnt do it untill i tryed using the same bluetooth brand as my head phones worked straight away
Jan 25, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Motorola Talkabout T5700 and Audiovox GMRS 1582CH headphones
Unfortunately yes. More often than not the pin/wiring arrangements are different, if not the physical sizes and dimensions, not to mention electrical characteristics such as impedance, common ground, ptt and VOX feature. If it is just an earpiece or headphones that is required, then any such accessory would do and it would be a matter of replacing the plug and/or rewiring the connection points.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 15, 2008 | Radio Communications
Music problem
i dont know how to download music on the motorola s9
can u help me please
Jun 02, 2008 | Motorola Mobility S9 Headphones
Blue Tooth Stereo Headphones and KRZR
From what I can tell and after researching the same issue it is the KRZR. I called both Verizon tech support and my bluetooth tech support.
There is no solution
If you notice some of the functions in the Blue tooth Pairing/connection menu functions don't even work. (The on off for instance and the settings) After it is paired. I tried my bluetooth with other phones and it works fine.
I am going to the Verizon store to complain untill i get a different model.
In short the KRZR software is defective
Dec 26, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Problem with heaing incoming and outgoing calls unless using speakerphone
I can't hear people that call me unless I put them on speaker phone. Called Motorola and they had me reset the phone but that did nothing. Any other suggestions?
Thanks.
May 30, 2007 | Motorola Mobility RAZR V3
59 people viewed this question
 Grubhead
Grubhead
