Question about Philips Televison & Video
Why "humming" sound from lcd Sylvania 6615L television?
On video 1 and video 2 there is a humming sound . . . no sound when a channel is selected.
  • Philips Master
  • 16,181 Answers
Unplug what ever is plugged into the televsion jacks and see if it is still buzzing. If it is, this is an internal issue. If it not, then it is a bad cable or connection of outside interference.
Posted on May 06, 2014
4 Suggested Answers
  • 112 Answers
SOURCE: I have a Samsung TV
you have to change the sound system its lockated in sound :D
Posted on Sep 22, 2010
  • 8909 Answers
SOURCE: can you go to Video
In a word, no.
Posted on Dec 17, 2010
  • 1156 Answers
SOURCE: I've lost the sound on my Sylvania 24" television.
hi, OK FIRST......Both the cable box AND your TV can lock up and cause NO SOUND....except for that hiss you're hearing.
So, UNPLUG BOTH UNITS FOR FIVE MINUTES, and then plug them back in and see if you still have the sound missing....
NEXT, if there's no sound, look on your remote control for the MTS button....if you press it and it says SAP on your TV screen, keep pressing it until MAIN pops up on your TV. That's for MAIN sound, SAP is for Separate Audio Programming.
Also,why the TV does not bring out sound when on TV is because the TV region does not work in your country where you are right..
In other to fix problem like this,What you need to do for the TV to work in your country, you will need to convert the TV to a region that will be able to work with your countries region.
TO fix this,please contact a specialist repair man to fix it up for you.
Also,In what position is the switch that can switch between internal or external speakers? If you connect any of the line audio outputs to a VCR or DVD, do you get any sound at all? If all of your tests to check Audio do not work, then I'm afraid you will have to have a competent technician look at your set. Considering it is a 38" Widescreen CRT w/HDTV, it could be worth fixing.
Hope it helped.
Posted on Jun 13, 2011
No sound on channels
Its a 19 inch set which means:
1 If a single speaker put ear to set to see if any sound or a low hum can be heard from it at all.
2 If set has a headphone jack on it see if sound there
3 If above fail either the speaker/s are bad or you have a audio circuit problem which on a set of this size is not cost effective to repair------------buy a new set.
Dec 05, 2012 | Sylvania 6419TA 19" TV
Some channels have no sound, other channels are ok, one channel sound goes in and out....what do I check for?
Problem :
some channels have no sound.
Solution:
Theres nothing wrong with your TV, is a misconfiguration of your Cable / Satellite box.
Check in the Setup of your Box the language option and select "Channel default"
hope to help you.
Please Rate my solution
Aug 18, 2010 | Sylvania LC320SLX 32 in. LCD TV
How can I input my sylvania 27" into video 1 or video 2 without the remote? The menu does not offer a game option nor a video 1 or video 2 option.
Here are the instructions for the TV.
http://www.sylvaniaconsumerelectronics.com/pdf/om/6427TE.pdf
They do not say how to select Video or Game mode without the remote. Try connecting a vcr or game to the input and do the Channel Pre-Select process to see if that will pick up the input as part of the Channel Scan. If it does you will be able to get to Game or Video using the channel up/down buttons. Another option is to get a replacement universal remote that has a code for your TV and will assign a button for Game or Video.
Jul 29, 2009 | Sylvania 6427TE 27" TV
I have DirectTV and a DirectTV remote RC64. I can
Here are all the codes I have
10171 10096 10187 10020 10381 10024 10030 11314 10186
here is how to set up without a code:
mode switch set to TV
PRESS & HOLD Mute and Select buttons at the same time UNTIL light blinks twice
enter 9911
keep pressing channel up until the channel changes on the tv
Maker sure to test the VOL button, if volume works
PUSH select key to set the code
THESE PROCEDURE CAN BE USED WHENEVER A REMOTE KEY IS NOT AVAILABLE.
CHANGE THE LAST NUMBER, 1 TO
2 for AUX1 (VCR and DVD)
3 for AUX2 (Audio Devices)
Mar 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
No audio on channel
The TV is not the problem. The tv don't know what chanel you are on and the sound works or it don't
Dec 22, 2008 | Sylvania 6615LG 15 in. EDTV-Ready LCD...
Slight Hum when tv is off
Doesn't sound like the tv is off...I would contact the company.
Jul 11, 2008 | Sylvania LC320SS8 32 in. LCD Television
Sylvania TV stuck in Game mode remote no longer works
go up to your TV and go into the menu. Go to the channel selection and run the auto select for channels. This will take some time but the TV will end off the first channel found, the only thing is you cannot get back into video mode without the remote
Mar 26, 2008 | Sylvania 6413TC 13" TV
Sylvania 6620LCT 20
throw it in the landfill there are no replacement parts.
Oct 09, 2007 | Sylvania 6620LF4 20 in. EDTV-Ready LCD...
Televison & Video Logo
51 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
