One of my olive Bluetooth indoor outdoor speakers has a static short sound. We took back the first ones due to the same problem, now these have the same problem :/ can you help?
  • 17,173 Answers
What are you plugging it into for power? This may be the problem OR it might be picking up interference from something else that is electrical that is causing a spark.
Posted on May 06, 2014
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
My charging port is broken what sould I do on my soundlogic xt indoor outdoor speaker
Buy a new one for $24 and be more careful I am afraid.
Amazon com Portable Rechargeable Wireless Bluetooth Indoor Outdoor Party...
The only other option would be to take it apart and see if you can find a good electronics parts store.
http://www.rs-components.com/index.html
Dec 10, 2016 | Heating & Cooling
My Soundlogic XT party speaker does not conect to my pc. It can bluetooth to my phone or play an sd card or use aux cord for conection to cd player. There is no driver everything is internal. I posted the...
Hi Christina
At the link I've provided below, there is at least one other person who has asked the same question.
The answer given there was that you can wire your speaker using the cable provided to your headphone connection on your PC.
Hope this helps.
-Steve
SoundLogic XT Bluetooth Indoor and Outdoor Party Speaker Retail Packaging...
Mar 07, 2015 | Audio Players & Recorders
Can't find and need manual for Terris bluetooth outdoor speaker #45305
I hope you might get some information about Bluetooth outdoor speakers from Terris. http://dockkiiou.com/outdoor-bluetooth-speaker-terris. You can also go for airplay speakers also if you have issues with the existing one. Read here the differences between the two http://audioindustryupdates.weebly.com/blog/which-one-to-choose-airplay-or-bluetooth-wireless-speakers
Dec 01, 2014 | Radio Communications
Jbl problems
You will need to reread the JBL directions. Most portable systems are fairly straigt forward. There usually a button with the bluetooth symbol. Press and hold till it starts blinking. Then go into settings, bluetooh on your S5 and look for the JBL.
Sep 07, 2014 | JBL Charge Portable Indoor/Outdoor...
Why is Mr Slim MS-SGF24VC outdoor unit working when indoor unit off
Possibly a bad control board in the outdoor unit. Pull the disconnect outside to stop machine, wait 10 seconds and out back in. White mist was likely frost built up on indoor coil due to condenser running without the fan.
Jun 11, 2017 | Heating & Cooling
Have outdoor speakers but will not play sound, they are connected to a xantech pa1235x and the indoor speakers work but not the outside ones
Check the reciever and verify if you have a selector swicth pressed for A speakers and B speakers and see if this helps...
Some recievers will only power A or B, not both at the same time.
Lets not assume your outdoor speakers work. Would be helpful to know if you have tried to disconnect the inside set and plugged the outside speakers in those stereo jacks. If no sound, your speakers may have loose wires on the inside of the box/cabinet/case or they could be no good period.
If they do work, and the system does not provide all four jacks to be powered at the same time. You may consider buying a pair of piggy back rca jacks. Plug in the indoor and outdoor speakers into the same connectors the indoor ones are on now.
That way at least you can run them all at the same time from the speaker connector where you have the indoor speakers hooked up..
Hopefully you'll find something useful in this
Good Luck
Respectfully
Jun 09, 2011 | JBL N24AWIIBLK Speaker
Sony STR DE 197 Reciever with No Sound
I have the same unit. My best recommendation would be to remove all speaker wiring, and try new wiring with another pr of speakers,since the "outdoor " speakers were rained on. the protect mode that the unit went into sounds like it did because the speaker outputs were shorted due to the rain, so ensure that the speaker output terminals are not shorted and dry...also see if output is still availalable at the headphone jack...if it is, the pre-amp section is still good , in which case the protect mode and no volume output out of the speaker jacks may mean that youve blown the ouput trasnsistor finals.
I hope this helps.
bobbymaximus
Jul 28, 2009 | Sony STR-DE197 Receiver
Connecting an outdoor MP3 player to an NAD C352 Amp
you could get a bluetooth dock and cables or just get a saeltech bluetooth speaker and run it off your computer .It will let you run your i tunes or media player and go thru your playlist or artist songlisting can also be operated remotely on the speaker unit ! Volume And tracks!!! swamp ratt!!! AAEE!!!!
Jun 02, 2009 | NAD C352 2-Channel Amplifier
Lost almost all sound in both speakers
Test the speakers on a bench if possible with a different receiver and some new wire. Or if you have a multimeter check the impedance, should be 8ohms if it's got a short, it will read 1..... or ....1 If the speaker wire when connected to the outdoor speaker is not siliconed, it acts as a wic and will oxidize the wiring and cause a short. do you have a separate volume control for them? and is that volume control indoor or outdoor? is it connected to a receiver or amplifier? The fastest test though would be to hook up the rock spkrs directly to another unit. If you still have trouble, reply and I will help you troubleshoot further. Hope this helps
May 24, 2009 | Insignia Simulated Rock Outdoor Speakers...
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
