Question about Samsung ML2251N Laser Printer
How do I replace the transfer roller on my samsung laser printer?
I have a Samsung laser printer that is starting to fail to pick paper up out of the tray unless the tray is full. I assume this is from a worn out transfer roller. How do I take the olde roller out and put a new one in?
Lightbearer
SOURCE: Samsung ML2010 laser printer paper feed roller belt
I just fought this same battle and have emerged victorious! The roller cam that the black rubber belt fits around is kind of "C" shaped in cross-section. The roller has left and right hinge-pins on one end of the "C" and snaps on the other. Looking at either side of the casing that the roller mounts in, you will see the end of the hinge-pin and a typical sqeeze clip like those often found on bigger laser printer rollers. I'm sure this was designed so that you should be able to sqeeze the left and right clips simultaneously which should release the snap end of the "C" and allow it to hinge out away from the casing. Unfortunately, it appears that the designer's good intentions were never tested. If your roller is like mine, it does not freely release by just sqeezing the clips. It was a bit awkward but while squeezing one of the clips, I used the tip of a small screw driver to pry loose the snap on that side. The trick is to hold that snap out away from it's seated position while you perform the same procedure on the other side. With both sides pryed away from their seated position you should be able to hinge the roller with black rubber belt away from it's case and remove it. In lieu of buying a replacement belt I simply rotated the existing one to expose the unused part and snapped it back in place. Voila!
Posted on Feb 20, 2009
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
drifterK
  • 4924 Answers
SOURCE: Samsung ML-2571N Laser Printer - paper jammed around roller
http://www.samsung.com/us/consumer/detail/support.do?group=printersmultifunction&type=printersmultifunction&subtype=monochromelaserprinters&model_cd=ML-2571N/XAA&mode=C
this link will guide you to the site with the user guides...but in short ..all ya have to do is to be careful and to open and remove the paper...there are not many things that may be damaged in the process...but there is a certain order you have to follow in doing it ...and a few devices that has unusual safety removing gadgets...
Posted on Jun 13, 2009
  • 406 Answers
SOURCE: How do I replace the tray 1 pick roller for my
Take out the tray, and you will find a pick rubber roller at the base.
Even you may clean and use it.
Posted on Jan 07, 2010
  • 16 Answers
SOURCE: samsung printer, transfer belt error message
Check on you drim uint the gears damaged.
Posted on Mar 11, 2010
How do I get paper to feed thru my Samsung ML-1210 Laser Printer?
Dear
This model is old and may have aging defect for the friction pad and pick up roller.
You may kindly replace the above part for assurance of paper pickup. the paper is stacked vertically on the top from the back side pocket..
However the the pickup roller may be cleaned using a dampened cloth for temporary.
Thanks.
Feb 21, 2015 | Samsung Office Equipment & Supplies
Samsung CLP-300 printer not printing, the paper tray will not pick up the paper.
Often the rubber pickup roller is either worn or dirty. It is located just above the paper tray. Use a damp cloth and try to cleaning it, sometimes that helps. Otherwise you will need to replace the roller.
Jun 16, 2011 | Samsung CLP 300 Laser Printer
Paper not getting inside the samsung Mono laser printer ML-1610
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
Mar 05, 2011 | Samsung ML 1610 Laser Printer
Samsung CLP-300 paper does not seem to be catching when printing?
Hi. Kelly,
I think the issue is the due to paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam etc.. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with damp (with luke-warm water) and lint-free cloth. I hope this would fix the issue. If the Roller is damaged or worn out, it needs to be replaced.
Hope this helps! Good Luck!
CreativeTECH
Feb 15, 2011 | Samsung CLP 300 Laser Printer
Paper pickup fails causing "paper jam"
If youcan get to the rollers and clean them with an alcohol solution, then this will cut the glaze that forms on the rollers from the talc use to keep the paper separated into sheets. That glaze coats the rollers and prevents the suction action of the neoprene to pick up paper.
Feb 03, 2011 | Samsung SCX 4521F All-In-One Laser Printer
My printer pulls multiple sheets at once.
yo have to:
1. Clear paper pick up roller whit wet cloth or alcohol
2. Clear separation pad (located under pick up roller) using same way as pick up roller.
Good luck
Jun 18, 2010 | Samsung ML 2010 Laser Printer
Not picking up paper
Most new printers and copiers will attempt to feed paper several times before failing and giving a jam condition. It sounds like that is what is happening to your printer.
Your tray rollers may be dirty. Remove the tray and use a clean cloth with mild detergent to clean the rubber rollers. Do not use alcohol this will dry the rollers out. If problem continues replace the tray rollers.
May 18, 2010 | Samsung CLP 300 Laser Printer
Paper stuck - Samsung ML2010
Clean the roller with 409/simple green or water. Use a cloth not paper towel. NO alcohol. Rub it up good and it should start feeding. steven 818-888-0006
Apr 27, 2010 | Samsung ML 2010 Laser Printer
My samsung printer is not picking up the sheets of paper correctly and they seem to be sticking on the roller
It could be a dirty pickup roller in printer. Found following advice from Samsung:
Printer will not feed the paper depends on following possibility.
  • Paper Type:
    • If surface of the paper is too smooth, pick-up roller will not feed the paper.
    • In such case, try with different type of paper.
  • Pick-up Roller:
    • If the rubber roller is worn out, it will not feed the paper from the tray. There is not enough friction to feed the paper.
    • Pull the paper tray out and clean the rubber roller.
Feb 28, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Samsung ML2251N Laser Printer Logo
23 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
