Ricoh troubleshooting black lines down the middle of the page
  • 86 Answers
SOURCE: When scanning or photocopying I
if you are using a fax machine, open top cover and clean roller with cotton cloth with some alcohol in it or take it to technician shop and have rollers replaced.
on scanners or all-in-one printers, this is a scanner head problem, take it for repair or buy new one (the cheapest).
Posted on May 04, 2008
disastertech
  • 62 Answers
SOURCE: Black Line in the middle of the page.
open the adf and you will see small glass, on the glass is a spec of dirt or most proberly tipex, clean the glass and line will disapear
Posted on May 11, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH AFICIO 1022 ADF scanning with a black line down right-hand side
There is a tiny spec on the scanner glass. Cleaning it will make the line go away.
Posted on Jul 11, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: hp 2420 vrtical line in page
This issue can be due to fuser. I am sure you have changed the toner cartridge.
To confirm its a fuser issue, please perform the following:
1. Try printing a configuration page from tray 1, pull the top cover, as soon as the media is 60-70% inside the printer.
This would stop the paper before reaching the fusing assy.
2. Remove the paper and check if the line exist.
If exists, fuser is not faulty.
If it does not, then transfer roller, laser/scanner assy is faulty
- If fuser is faulty, perform the cleaning page as following
1. go to configure device > print quality > create/process cleaning page
perform cleaning page 5-6 times, however, if the line is due to fuser, then fuser needs to be changed.
Let me know the next update.
- Nikhil
Posted on Nov 24, 2008
  • 990 Answers
SOURCE: Black stripe down middle of page when copying
open the top cover on the left hand side glass plateform with a narrow piece glass clean it with alcohol.
Posted on Dec 13, 2008
Ricoh aficio 2022SP prints black line across middle of page
Remove the OPC unit,clean the charge corona,charge corona grid,clean or change the OPC drum cleaning blade.
Jan 26, 2013 | Ricoh Aficio 2022 Black and White Copier
Hp Laser Jet P2055dn printing black line down the middle
The line in the middle of the page is caused by a damaged or worn fusing assembly in the printer. Here is a link to an article showing this issue on the Laserjet 2100 printer and how to replace the fuser unit. Your printer just needs to have the fuser replaced, it is part number RM1-6405 and is available from Amazon
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Jul 19, 2012 | Ricoh Aficio CL3500N Laser Printer
I have a Ricoh Aficio CL3500N When I print a vertical page there are thin black lines going down the left side of the page. What causes it?? And what can I do??
Hi, thin black lines are most likely (but not definitely) caused by something in the black PCU (photoconductor unit), either the drum or the charger. Replacing the black PCU will likely get rid of your lines. The Ricoh code for a black PCU if you don't already have one is 402448.
Jan 29, 2011 | Ricoh Aficio CL3500N Laser Printer
Grey/black shawdow like lines running through middle portion of page all the way down; looks like a roller ran across the middle of the page
just clean d optics and lens of d scanner unit if not repaired then open d dum unit and clean d paper dust
Feb 13, 2010 | Ricoh FT3713 Copier
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Black vertical lines on printed pages
check the "photoconductor unit" (pg 37 in the Maintance manual)
ours was doing it with the magenta and saw a faint 'scratch' on the roller. will attempt to replace and report back if this fixes it.
Apr 09, 2008 | Ricoh CL4000DN Laser Printer
Black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Feb 26, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Feb 20, 2008 | Ricoh Aficio CL2000N Laser Printer
Vetical lines printing on page
If the lines are blue, check the color PCU.
Oct 25, 2007 | Ricoh Aficio CL3500N Laser Printer
12 people viewed this question
k24674
jasbo
jasbo
