Question about Garden
Do I have to take apart mower deck on jazee sr250 to put belt back on?
  • 656 Answers
No but go to the manufacturers web site. They will have diagrams for belt routing.
Posted on May 07, 2014
  • 10865 Answers
SOURCE: Installing mower belt
The pulley at a wierd angle is the tension pulley. You may get the manual on line for free if you are lucky but not all mower manufacturers are that generous. What kind of mower do u have?
Posted on Mar 31, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: need diagram for deck belt
Try http://www.rcpwparts.com/parts.asp
Posted on Apr 22, 2009
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
Posted on Nov 19, 2009
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
How does belt go back on for mower deck
Gary, Belt diagrams can usually be found on the Deck it self or in your manual. If you do not have either check the links below or Google search your make and model# manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Service Mower
Murray Belt Graphics
Craftsman Riding Mower Deck Belt Diagram
lawn tractor deck Belt diagrams Google Search
May 29, 2016 | Garden
Need instructions how to put on and route a mower 42 deck huskee lt 4200
here is a diagram from the internet, hope it helps.
May 15, 2016 | Garden
How do I change the drive belts engine to deck on my MTD RS115/96 motor mower?
You will actually have to watch how it is done. Go on You Tube and type in what you have in the title of your question. If your model mower is not found in search...then find a mower close to it. Watch the video of that person changing the drive belts. Also I recommend you take pictures with your cell phone camera or regular camera of the deck before you start to take it apart. This will help you put it back together a lot faster and easier
Jan 01, 2015 | Mtd Garden
Need diagram on how to install a deck belt on a Country Clipper JaZee Pro SR350
I found the diagrams for my Country Clipper on the following site which has owner/operator manuals for all Country clippers. Hope this helps!http://www.demottenterprises.com/CC/manuals/OP-Jazee%20One.pdf
Oct 06, 2011 | Health & Beauty
My Motion Drive Belt slipped of it's pulley on a Husqvarna Riding Mower Model 917-289570. Do I have to remove the rear tire to put the belt back on?
i had a 2148. you remove the mower deck as the first step. feed the belt over the pulley on top the transmission, then put it over the engine pulley. then have someone push the clutch pedal in so the tensioner pulley moves, put the belt in the guide pulley and on the tensioner. release the clutch put the deck back on and you are good to go. notice there are little keepers welded to the frame for the front, engine, pulley and it is easy to mistakenly put the belt over them instead of under them.
a general rule is that a pulley shaped like a Vee takes the V of the belt whilst a pulley which is flat takes the flat back of the belt. if you bear that in mind you will not have a problem putting belts back on. also there is a little decal on top the deck showing how the deck belt and deck drive belt go.
Sep 09, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Craftsman 18.5 42'' rider dosent always engage the mower when lever is put in the on position, it takes several trys to get it to work or sometimes if you leave the lever in the on position and put the...
assuming it is a lever that inserts a tensioner pulley into the deck drive belt loop: replace the pulley AND the spring which keeps the tension on. also replace the deck drive belt. use your cell phone camera and take lots of pictures before you take it apart so you are not one of those guys asking for instructions as to how to route the belt when you are putting it back together. the parts can be obtained at lawn mower/small engine repair shops which can be found in the yellow pages and on line.
Apr 07, 2011 | Garden
How do I change the madrel on a craftsman Lt 2000 42" 17 hp? The star bolt is worn down
remove the deck from the mower, take off the blade, take off the deck drive belt, take out the bolts which hold the mandrel to the deck. put new mandrel in, reverse the whole order. do yourself a favor and take lots of before pictures so you do not have to ask how to put the belts back on. mandrels can be obtained at small engine and mower repair shops. you may just want to replace all of them while you have it apart as they are all the same age and wear.
Mar 17, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Have a 2006 145 automatic riding mower. Belt keeps
idler or adjustment pulley bearings worn allowing belt to ''run off''as it wobbles.stays on.check spring tension of idler.
Sep 20, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
