Question about Magic Chef CAV2000 Top Load Washer
Machine won't wash
Water would load but won't wash, it sins let out water. wash cycle will not trigger
    Problem Solver:
  • 19 Answers
You have a bad sensor which should be replaced by a technician as they have to be calibrated.
Posted on May 07, 2014
Washing machine won't go to spin cycle if there are towels in it
Washing machines have trouble if they are overloaded and the load gets out of balance. This occurs most often with towels. Open the machine and lift the towels out and put them back in evenly to get the load to finish. You will see how heavy they are when full of water. In future, try running with a few less towels and see if it works ok. You have found the other 'fix' by draining and running spin only which probably resettles the load.
May 11, 2017 | Washing Machines
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
Samsung Washing Machine won't start
Your program controller unit is working but it must be ensured that there is output on every cycle to the desired output controls. So the inlet valve must work and the motor must run when the water level is triggered by the level controller. So use a meter to check before we can suspect the controller.
Nov 11, 2011 | Samsung Washing Machines
Water will not drain out of the washing machine and won't complete cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Kenmore Washing Machines
My washing machine fill up with water, but want
This could be a faulty saftey switch on the cover
Nov 08, 2009 | GE WBSR3140DW Top Load Washer
Wash starts before water is full
most washers if put on a large load do start going around before the water has finished filling this is just to get all the clothes fully wet before the proper cycle starts to wash them it is just how the washer copes with a large load peter
Nov 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer will not drain.
I am having the same problem. I just figured out it has to do with the latch switch that "locks" the lid in both the drain and spin cycles. Place a pen/pencil into the hole on the top of the frame where the lid would fall and see if it triggers your drain cycle to start. I was able to remove all of the water by holding the trigger down, but I haven't yet figured out how to remove the top of the washing machine in order to fix the part.
Apr 20, 2009 | Kenmore 24902 Top Load Washer
My top-loading Maytag starts to fill with water when I turn it on and then completely stops and doesn't do anything more.
it could have a problem with the pressure switch.
the water supposed to trigger the start of the wash cycle and turns off the filling cycle.
it is a single trow switch that disconnect the connection of water filling and connect the wash cycle on.
maybe it is disconnecting the filling cycle but would not connect the wash cycle.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Maytag Washing Machines
Water wont drain
something is stuck in the drain pump axcess through front panel.
Sep 30, 2007 | Kenmore 44102 Front Load Washer
Magic Chef CAV2000 Top Load Washer Logo
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
