Kenmore top freezer, Refrierator shuts off with loud clunk.
This 5 year old refrig has just started turning off it's cooling cycle with a loud thumping sound coming from the compressor area. It cools just fine but the sound is loud enough to wake up a sleeper.
Re: Kenmore top freezer, Refrierator shuts off with loud...
It sounds like you may have a compressor that is working hard against high pressure due to a dirty condenser or a condenser fan not running or blocked. If all is well otherwise, the mounting springs inside the compressor may have broken or are weak. The only fix then is a new compressor.
The clunking noise you hear , is probably when the compressor shuts off , due to temp reached or when it goes into defrost . An internal motor mount spring , inside the compressor , is broken ( rusted and broke ) . The refrig can go on working for years , without any problem , except noisey , when it cuts off . To stop the noise , replaceing the compressor is the only option . I have heard of placeing objects under 1 leg of the compressor , to " re-adjust " the ballance , but thru my experience , another spring broke , causing more knocking .
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
its the compressor,
i would not spend a dime on it,
a compressor is around 200 to put it in could cost up to 200 more, then its a long shot with who will be doing the work
10 years is the avergae age of this unit so count your self lucky
and invest in a replacement
the old one may
last a year, but it will go
your loosing the center seal
sorry its not beeter news
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
Hi, As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips. If your refrigerator is running but warm, then… Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing,
check vents in refrig. make sure no blockage, freezer control should be in the middle setting,
you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
